Mar 14, 2020 21:29:38 GMT
About 1/4 tank...fresh fuel. The plugs were pretty sooty before I got it running earlier in the day. I cleaned them all up then checked I was getting a spark at each...which I was.
Since I cleaned the carbs and tried to start it again, the plugs seemed dry when I pulled them out. There is a clear inline filter just before the carbs which I a can see filling up ok.
Last Edit: Mar 14, 2020 21:31:07 GMT by sarkie83
Darkspeed
Club RR Member Number: 39
Mar 14, 2020 21:32:19 GMT
There is no substitute for splashing fuel direct down the carb and knowing that there is some there.
Mar 15, 2020 12:00:52 GMT
New day, level head back on So rechecked the carbs from yesterday. First of all - a lot of moody I’m-not-talking-to-anyone-as-the-car-is-annoying-me time researching first of all made me realise that the port between carbs 1-2 & 3-4 are not supposed to be capped off: They are a reference for atmospheric pressure for the float bowls...who knew.. Next, I’m sure how I’d measured the float levels, but that was wrong, so started over.While I was at it I noticed that one of the needle valves was not springing back..so that needs to be replaced. So progress...hopefully.
Last Edit: Mar 15, 2020 12:06:10 GMT by sarkie83
Mar 15, 2020 22:36:48 GMT
It’s a facet posiflow one ... I was running one of the generic bike ones, but it lasted all of about 45 seconds before it packed up. Almost certainly way to much pressure. Some bikes only run 1.5 psi Get the matching bike pump the goes with the carbs. It will still easily make the power. I reckon you are flooding or over fueling. And low pressure regulator are wibblepoo unless aircraft standard and expensive.
I fitted the new needle jets and reconnected everything backup, but I was still getting very odd behaviour...one day it would run, the next it wouldn’t... I had also been having an issue with the throttle cable. Originally I had cut the end off the stock one and somehow fitted the solder-less nipple to it. However the connection on the carb end is a pain to get to on the car, so after a few times of removing and reinstalling my cable looked like this: (Btw a tip I have since found out is to dip them in superglue to stop them from fraying) On the last refit, I used a bike brake cable and used a dremel to trim the end to size for the carb and and used a pear type nipple at the pedal end One of the days it was refusing to start I took the advice here of splashing a bit of fuel down the carbs. It would run until the vapours ran out..so it did seem to be a fuelling issue, even though I’ve got a clear filter fitted at the carb end and can see it filling up when the pump is running. I bought a complete bike pump/filter off eBay a few weeks back so was all set to fit that. However, when i was preparing to fit it, I noticed the pipe from the pump was kinked cause of how I’d run it....surely it couldn’t be that simple....oh YES...YES IT COULD! It’s running nicely and starts pretty much consistently on the button joem83 - I think there are good vibes about
shin2chin
Well done. It took me years on and off to get my zx6r carbs working on my 924 but now it's more reliable than its ever been and also sounds amazing. You won't regret doing it when it's all working and tuned up.
So...we have a spanking new MOT...yeah boi I always find emissions the most concerning...especially when you’ve changed fuelling setups, but we we’re all good: I took it the long way round beforehand (as I’ve only taken it for a quick spin round the block since fitting the carbs), to give it a bit of a clearout. First time I’ve had it over 20mph since fitting the bike carbs, and wow does it beg to be revved...it’s fantastic!! Everything is forgiven and the past is the past Sat greeting me with a fresh ticket: Taken on the way back...I was being a bit of an attention whore...and loving the looks... haha
Last Edit: May 9, 2020 21:37:53 GMT by sarkie83
May 19, 2020 17:24:30 GMT
It’s been really nice not to have to concentrate on getting the Capri ruining for once, so I’ve just been able to drive and enjoy it! I’ve got some soundproof material on order so I can refit the door cards and make the interior a nice place to be again. I did one of those nice satisfying low priority jobs today - fitting a remote battery solenoid. Now I’m using it, popping the bonnet each time I take it out to reconnect the battery is a pain. I’d seen the Chinese remote battery solenoids you can get, but I’m not fussed about a remote control, plus they are £40ish. Instead I found a continuous 500A relay (think it’s for a JCB something...) pretty cheaply. Nice and easy to wire up... activated by a switch in the cabin which I can hide away:
May 21, 2020 20:35:12 GMT
Anyone familiar with Capri’s will be used to having to carry one of these around: As the boot worn boot struts have a habit of giving way and whacking you over the head when your directly underneath Old one removed, and the ends of the one ones swapped into the new struts. I also pressed a bit of nylon tubing over the metal bush to take up some of the slop. After Which now means I can finally bin the old pole I’ve been carrying around in the boot I didn’t take any pics, but I also sorted the drivers door lock which wouldn’t lock when you pressed it down...so nice being able to fix things with a squirt of WD40 substitute innit
cjhillman
May 22, 2020 23:59:02 GMT
It’s been really nice not to have to concentrate on getting the Capri ruining for once, so I’ve just been able to drive and enjoy it! I’ve got some soundproof material on order so I can refit the door cards and make the interior a nice place to be again. I did one of those nice satisfying low priority jobs today - fitting a remote battery solenoid. Now I’m using it, popping the bonnet each time I take it out to reconnect the battery is a pain. I’d seen the Chinese remote battery solenoids you can get, but I’m not fussed about a remote control, plus they are £40ish. Instead I found a continuous 500A relay (think it’s for a JCB something...) pretty cheaply. Nice and easy to wire up... activated by a switch in the cabin which I can hide away: Very interested in this! Are you worried about your Capri bursting into flames too? I'd love to see a wiring diagram for this. Not mega up on relays but, if you've gone through my thread you'll see I had some Capri wiring issues that resulted in smouldering wires... its safe to say it has the battery cables off 90% of the time.
May 23, 2020 13:55:57 GMT
haha, it's a combination of factors...mainly because it doesn't get driven a lot, and the easiest way to stop me coming back to a dead battery is to disconnect the battery. Also i've never bought a specific battery for it..i just seem to end up using batteries scavenged from other cars (it's got a pukka Ford branded one at the moment taken from my diesel Fusion from when it started getting weak last winter). Finally, security - as lets face it, the locks are rubbish on our cars!! I dunno if it's a Capri thing, but I have stripped out meters of old, curse word and just plain weird wiring from mine over the years. It also seems to be a mix of automotive and domestic stuff looking at what came out from behind the dash. Mind you...my top tip...if your washing machine ever breaks down...strip it for parts! Sell the drum as a 'fire pit' and hang onto the wiring loom as it's great for car stuff (decent quality, nice mix of colours, etc...) Basically a relay is just an electrical switch that lets you turn on a higher powered circuit from a lower power one. Often you don't want to put a switch inline with the circuit you are controlling. If you did that, a lot of the wiring throughout a car would have to be a lot thicker to cope! A good site is: 12voltplanet.co.uk They've also got some common real world examples, and some handy guides like how to size wire for your needs.. For what i've done, this is the simplified diagram (the real thing looks slightly different as I’m using a 3 pin switch with an LED indicator) Also, dunno if you were ever on capripower or Capri World fb group (think you are, as pretty sure i've seen you post)...but this is pretty much your Capri wiring bible
Last Edit: May 23, 2020 14:31:17 GMT by sarkie83
cjhillman
May 23, 2020 17:29:22 GMT
Great info mate! I'll definitely get to this mod when i've finished when its rolling. I've experienced relays with my Dixie Horns on my Escort but, never got it right and my Dad's mate sorted it in the end. I am on Capri Power but don't update it a lot. Also on the Capri Laser page. Capri wiring seems to be odd. Everyone seems to mention some form of electrical germlins or fires. I got stuck in to mine with the blower as I had a small black plume of smoke turning up when i pressed a few buttons. In retrospect it could have been the radio wiring as that looked burnt but someone has also messed up the headlight relay (headlights work fine) and there is a white wire running all the way from the back of the dash plug to the headlight. All slightly worrying. hence why i was excited to see your relay mod Good to see your enjoying this now mate. hopefully not to far behind you. Just waiting for the historic tax to come back.
Sept 19, 2020 19:54:21 GMT
I haven’t had the Capri out since we took it to one of the drive in movies at one worth about a month ago. Plus July/August are normally rubbish and wet anyway... I really need to get the carbs set up properly at some point - the trouble is finding somewhere to do it. It’s ok, but there are some symptoms of them running a bit lean...Revs tend to hang, and especially in the eve when it’s colder it gets a bit hesitant at light throttle. Funds aren’t great at the moment so I thought I’d have ago with shimming the needle main needle jets as I’d read somewhere that this can often overcome issues of running lean. Mine don’t have the adjustable grooves, so it’s a case of putting one or more 0.5mm washers: Plus it was an excuse to replace the soft easily wrecked cross head screws with allen head ones. Like most people from a non-bike background, I didn’t even know they are a different standard (JIS) which is why they often get wrecked by non JIS screwdrivers! Unfortunately it didn’t have the effect I’d hoped for. The revs didn’t hang but it put a serious dent in responsiveness and felt very bogged down. Oh well, it was worth a go. I need to have a bit more of a read up on tuning bike carbs...and probably give balancing them a go. I was chatting to the guy who rents the lockup next to me who’s into his scooters and he was saying that the jets all overlap a lot more than on the original Webber, so it’s probably worth playing with the air screw. Whereas I think on the old Webber all that did was set the idle mixture setting. I also had a go at fitting the sound deadening material I bought a while back which didn’t get wrecked when the lockup got minorly flooded 😡 That turned out to be a satisfying job and one step closer to getting the interior sorted. Btw has anyone got any recommendation for a replacement for the moisture barrier? I’ve seen you can get something like this from screwfix www.screwfix.com/p/capital-valley-plastics-ltd-vapour-barrier-green-300ga-20-x-2-5m/12869 but I was also wondering if cutting up an old rubble sack would be just as good?
Sept 19, 2020 21:06:50 GMT
Sept 27, 2020 19:53:41 GMT
Only a minor update and no pictures (not much to see!). I adjusted the mixture screw on carb no.3 as that was the one that would sometimes spit back. 1/4 turn at a time until the spitting was gone. Took it for a little drive and it felt a bit smoother - so that was a nice improvement for 15 mins work. With the filter removed and revving it up I can see some disparity in how much the vacuum slides move. Roll on payday so I can give balancing the carbs a proper go.
Sept 28, 2020 5:37:21 GMT
Hope I'm not too late, if you have speakers in the doors (it's been a long time since I've been in a Capri but it looks like you have) then the best moisture barrier replacement is more sound deadening material
It makes the door into a better enclosure for the speaker and makes the door even more pleasant to close
Sept 28, 2020 9:44:26 GMT
Some self adhesive closed cell foam is a good addition over the silent coat. Depends how quiet you want the cabin.
Sept 28, 2020 20:58:24 GMT
Hope I'm not too late, if you have speakers in the doors (it's been a long time since I've been in a Capri but it looks like you have) then the best moisture barrier replacement is more sound deadening material It makes the door into a better enclosure for the speaker and makes the door even more pleasant to close Haha no, the rate I get stuff done on the car is a bit more of a glacial pace
Jan 31, 2021 12:55:20 GMT
Last Edit: Jan 31, 2021 13:04:39 GMT by sarkie83
cjhillman
Jan 31, 2021 23:49:00 GMT
Nothing earth shattering in terms of updates. I did start cleaning the 2.0 block up: I did have a mate helping me out but COVID restrictions means that progress has stalled a bit. I had a fail fitting the oil seal and ended up cracking the casing - clearly I was doing something wrong! So I bought another casing with oil seal already fitted from ebay... Other than that - I’ve got a few bits at the powdercoaters waiting to come back (headlight surrounds, few brackets, etc...) I also replaced the starter motor with a high torque one, as especially after not being used for a while - every little helps to make it easier to get going again. I've seen some of these starters on ebay for about £45 but i'm not sure if they have the ballast connection that the origional has. Did you notice a big difference? I could do with a bit of extra waft for mine I think. Looks like your making good progress.
