Sept 1, 2010 12:53:38 GMT
Had it out for a drive drive well it seems to have like a wheel bearing noise from the rear noise gets faster as the speed increases Don't forget to check for other sources, the wife's ML did this but after I looked underneath was just a loose exhaust heat shield rubbing on prop shaft, hence noisier with speed, silent at idle!
btc
Beta Tester
Sept 1, 2010 16:49:25 GMT
good point will have alook tomm its just been fitted with a new exhust from the cat back
btc
Beta Tester
Sept 4, 2010 15:28:30 GMT
Right had a good look at the jeep today defo needs handbrake shoes but the rear brakes are getting very hot and it feels like the back end is moving about hard to describe if I turn on fuul lock it few like the back end is locking up any idea as to cause and how to fix Thanks
