Sept 15, 2010 19:06:54 GMT
Sept 15, 2010 19:14:56 GMT
same thing has happened to me before, I seem to have had an issue on one of my cars where condensation built up in the drum, which would occasionally mean they seized in place. My brakes were well maintained. eventually one of the linings just parted company from metal backing. I think my shoes were either ferodo or pagid ones
Sept 15, 2010 20:18:07 GMT
I've had the same with an escort Mk 6 a couple of years ago, friction material was rattling about in the bottom of the drum when i took it off. I also had a 306 GTI6 where the front pads were coming away from the backing plates, scary.
Sept 15, 2010 20:23:56 GMT
This is disturbingly common on clios, 106s and saxos (which all share the same rear brakes)
I've had it happen on 2 of my cars, and seen it on another two.
The bearings sometimes pull apart when you take the drum off (they bind onto the stub axle) you can probably just clean it and put it back together. Run some emery cloth over the stub axle and grease it so it slides back on nicely.
Last Edit: Sept 15, 2010 20:25:47 GMT by cobblers
Sept 15, 2010 20:27:02 GMT
If anyone else here reads practical classics there is a warning on page 1 of this months issue warning of counterfiet brake shoes and pads that break up and delaminate under normal braking conditions. The scary thing is that they can be good inpersonations of respected brands and some motorfactors and places on have been selling them without realising they have them. This was mentioned on another forum I frequent in more detail than the PC warning. Scary stuff really
Sept 15, 2010 20:53:26 GMT
The ones that broke up on me were from main dealers and halfords :s
will
Sept 15, 2010 21:24:47 GMT
Seen the broken shoe thing allot with dirt bikes over the years and would put it down to moisture inside the drum. Had it happen to pads too put never on a car always on dirt bikes. Taper bearings come in one or 2 piece don't know what type these run but if it feels good still slap on the grease and refit Nice pics
hairymel
avatar by volksangyl
Club RR Member Number: 207
Sept 15, 2010 23:28:10 GMT
had a pad disintegrate when sharply braking for a roundabout a few years ago. much pedal pumping ensued. brown trousers that day on inspection all of the front pads ,although fairly unworn, were delaminating and could be prized off with a screwdriver
whats that burning smell?
oh curse word :-(
Copey
Sept 16, 2010 23:38:28 GMT
how could it have happened? its french Dave, fallin apart is what they do lol
Sept 17, 2010 7:54:41 GMT
Your right there copey! Ive replaced all the shoes now but the handbrake mechanism is ridiculous on these things and seems to make no sense! Back on it tonight after Ive pressed the bearings into the drums (what a stupid design!!! To get to the handbrake mechanism you have to buy new 30mm nylock nuts and try not to split the bearings when you take the drum off - curse word. Give me an old ford any day!
Copey
Sept 17, 2010 9:30:39 GMT
that just sounds stupid!!!
Sept 17, 2010 9:32:43 GMT
Don't diss the rear brakes on a clio til you have to change the front disks on a newish transit!
bortaf
Sept 17, 2010 12:38:59 GMT
Don't diss the rear brakes on a clio til you have to change the front disks on a newish transit! Na peice o pee them, all you need is the patience of several saints, some luck, fairy dust and several FBHs
R.I.P photobucket
