Aug 27, 2018 20:41:58 GMT
SiC - yep, 'twas me, I'm in on a driving holiday For info I found another chain of bunkhouses offering cheap accomodation www.st-christophers.co.uk/hostels Today was spent playing at a local water park - first attempts at stand up paddle boarding were "ok", falling in the first time did wonders to wake me up ! www.croftfarmwaterpark.com/watersports/ Prices for equipment hire were fine but I felt £2 for a cup of instant coffee in a plastic cup was taking the mickey TIp : I found out afterwards they do cheap deals on Bank Holdays (AM only) I'm also tempted to try the sailboarding - if anyone has any advice can you PM me I've also lost my satnav which is making navigating *really* interesting - how did we ever survive using just roadsigns and our inbuilt sense of direction.* I used it to find Bath so I had it then, I've emptied the car today and can't find it so I have no idea where it's gone. I'm not looking to my next visit to my ex as I borrowed it from her and it looks like I'll have some explaining to do * Note for our younger readers - there was a world before satnav & google
Last Edit: Sept 18, 2019 6:46:46 GMT by nomad
vulgalour
Club RR Member Number: 146
1972 Hillman Hunter Estatevulgalour
@vulgalour
Club Retro Rides Member 146
Aug 27, 2018 20:58:38 GMT
I remember the 'navigating by road signs' being decidely disappointing and not at all challenging on my driving test. At that point all my navigating was done with an out-of-date road atlas (remember those?) and going in the right feeling direction. I can still do it, but it's much scarier now, people seem to give you so much less time to figure stuff out as you're driving and are incredibly impatient with anyone that's a bit lost.
Satnavs are one of the few modern conveniences that really are just that. They're an amazing bit of kit.
Aug 28, 2018 11:45:12 GMT
Gave up on my sat-nav here after around a fortnight. There's two problems: 1) All the cities that make up Metro Manila use the same ten (or so it seems)street names, endlessly repeated. All dead politicians or clergy (except the woman that invented banana ketchup) 2) They swap names if a new politician dies or an old one falls out of favour so often, Garmin can't keep up. Map book, and Google Street view for the landmarks, do for me. Luckily I've a good memory for maps once studied. Gave the Garmin to Madam. She doesn't use it for navigation, but likes to watch her little red car on the screen.
She's not lost if she can see where she is. Look! The cars right there!
Sept 4, 2018 20:18:44 GMT
Last Edit: Sept 18, 2019 6:48:37 GMT by nomad
Sept 4, 2018 20:57:25 GMT
As I'm touring in an unfamilar part of the country, I asked if anyone had a workshop and welder I could make use of before my MOT. Many thanks for the folk who got in touch, all offers were very much appreciated ! Special mention goes to scimjim who - out of the blue - let me know I was near him, and he had a spare workshop I could use. I left an IOU for lots of RR brownie points if / when the next batch get handed out One of the main jobs I wanted to do was to make sure the sills were 100%, which involved cutting out a small suspect patch. A few hours on Day 1 were spent sourcing some suitable steel, and using it to make & fit an inner sill patch. The outer sill was cut back to solid metal and more sheet was shaped to fit the hole, then fitted. Day 2 was spent seam welding the outer sill, and minor fettling (looking at the borderline overheating, tightening a distibutor clamp bolt that was loose, reseating a plug lead that was loose in the distributor, tightening a sparkplug that was visibly loose, moving ignition timing to it's "happy place" etc). After the visits to Jims, I made a start fitting the NOS (or just OLD ?) door draught excluders I got from the tat auction at RRG, another small job but well worth doing I also poured a bucket of water over the radiator after a run. Checking it a few minutes later showed a few rad colums are flowing well (obvious as the water exaporates from them quickly), shame the other 90% are doing not-a-lot. It looks like the rad I got a heavy duty core fitted to just a few years ago is now causing my overheating problems. Not impressed
Last Edit: Sept 18, 2019 6:55:49 GMT by nomad
Sept 5, 2018 12:51:47 GMT
Perhaps the rad just needs a back flush? looks like you found some nice places to stay
vulgalour
@vulgalour
Sept 5, 2018 15:31:34 GMT
Glad to hear you got the workshop space you needed in the end. It's quite brave doing all this living with the Hillman stuff trundling around the country.
Sept 5, 2018 19:28:19 GMT
I think , If i remember correctly, that i used an aluminium Honda civic radiator in mine off Ebay. It needed some rejigging of the coolant hoses, but it was alot better James
Too many projects, not enough time.
Sept 10, 2018 19:35:44 GMT
It's quite brave doing all this living with the Hillman stuff trundling around the country. I have total confidence the Hunter will get me where I want to go, worst case I can fix most faults with a screwdriver and pair of pliers By comparison - I bought a nice sensible modern daily last year that has let me down twice so far (1 dead starter that gave no warning, the other fault cleared itself by the time the RAC came out so I don't know what the problem was - it might fail again...) Time for a few motoring hints / tips / thoughts... For touring, try to make sure everything you have works from 12 volts (cigarette lighter etc) and fit at least 2 lighter sockets (1 "ignition live", 1 "permenant live"), and connect a couple of car USB hubs so you can charge phones etc even when the car is parked Make sure you use plenty of insulation tape on any exposed connections to stop the magic smoke escaping - it would be very silly not to. Oops! The overheating is now fixed (at a cost of 2x 2 litre bottles of genuine hi-octane Cola) left to soak in the radiator overnight and shaken regulalry. Temp is now a lot happier - and so am I It's always difficult to decide what spares to carry, when I'm on a touring holiday I try to have 2 spare wheels (lessons learned from RRG'16 ), a spare distributor, and a spare fuel pump. I fitted the spare pump at Jims workshop last week and it fixed the problem of fuel draining overnight which is good I did have a slight problem (possibly on Port Talbot ring road ) when the arm snapped on the "new" pump. I now know I can swap a pump on a busy dual-carrigeway in less than 5 minutes. I also know you get a much nicer class of insults in Wales when your old car breaks down Haematite (not Hermatite !) always appeals to me - you can now get magnetic lumps which are very handy for holding pace notes on the dash (may not work with modern plactic cars). For anyone passing near Haverfordwest (South Wales) I suggest you visit the places on the list given to me by the chap running the last campsite I visitied - all are "a bit special" Expect photos of random seaside places in the next update
Last Edit: Sept 18, 2019 6:57:33 GMT by nomad
Sept 22, 2018 7:46:22 GMT
My Mig is a bit industrial (the largest single phase unit that ESAB do) but you're welcome to use it in a month when I'm back in the Uk if you slip us some cash for the gas depending how long you're going for!. I'm in Ivybridge, Devon.
1987 Supercharged BMW R1150 Citroen 2cv Hillclimb Monster 1995 Renault Master Mk1 Race Transporter 1994 Mazda MX5 Mk1 / NA Road Going Class Hillclimber 1991 UMM Alter II Crew Cab OM606 SuperTurbo Diesel MegaUMM Overlander 1992 UMM Alter II Station Wagon 1980 UMM Cournil - survivor - resto project 1979 Lomax 224 2014 VW T5.1 Transporter Kombi Highline
greencarfritz - the offer is appreciated but I'm hoping I'm sorted, MOT is booked for later this week so I'll know for sure then. Car-related news ... I called into a rather large junk shop and found a set of genuine Halfrauds locking wheel nuts still in the packet for £3* * bargain price as the application list on the back said "Chrysler" (ie Hillman) was different to "Hunter" and both were different to "Hillman", so a 66% chance the nuts wouldn't fit. Worth a gamble, and even better when I found they do fit I also noticed Speedy Spares were selling NOS carbs for £40, a quick phone call later and the rebuilt engine got a shiny *NEW* carb It's too early to tell what difference it will make, but it's already clear that tickover is a lot smoother
Last Edit: Sept 18, 2019 6:59:22 GMT by nomad
At £40, that's a no-brainer! Shame he didn't get two.
djefk
Hang on, that’s a SU, not a stromberg!
1972 Hillman Hunter Estatepeteh1969
@peteh1969
Club Retro Rides Member 107
Hang on, that’s a SU, not a stromberg! It's still a carburetor at the end of the day regardless of make.
vulgalour
@vulgalour
It's an SU HS4C as we found out today when Nomad popped by to do some upside-down welding. In the Hunter manual I had to hand (as you do) it seems the HS4C is a revision of the HS4 that amounts to moving the jet adjustment screw from an awkward spot underneath the carb to a more convenient spot on top.
Phil H
Club RR Member Number: 133
1972 Hillman Hunter EstatePhil H
@philhoward
Club Retro Rides Member 133
It's an SU HS4C as we found out today when Nomad popped by to do some upside-down welding. In the Hunter manual I had to hand (as you do) it seems the HS4C is a revision of the HS4 that amounts to moving the jet adjustment screw from an awkward spot underneath the carb to a more convenient spot on top. And there was me thinking it was just an application specific choke linkage rather than a relocated jet adjuster! I’ve never seen one of those before - nice to have though.
I've had the car running in the past with SU & Stromberg carbs, the factory manual shows both types + webber so I guess any could have been factory fitted. The new carb is labelled for a Hunter but I've never seen a HS4C type before so it took a while to work out why the hex nut at the bottom of the carb was missing. It also made it impossible to follow the well known "adust the mixture using the hex nut below the carb" instructions When I visted vulgalour * to weld a patch, we (he) found out the carb is a HS4C - this soon lead to HS4C setup pages www.scribd.com/doc/32945491/SU-HS-Type-Carb-Kit-Servicing-and-Tuning-Guidesucarb.co.uk/technical-hs-type-carburetter-hs4c-hs8-dismantling* It was good to catch up, the welding & info was appreciated
