Jun 16, 2013 20:33:44 GMT
I don't quite understand what you were saying here.. Explain, please? The bigger the hole to fill, the larger the contact area to the other panel that is going to be welded = stronger. polo6n1600i Ive sent you a PM, hope something good can come of it, thanks for the info. Cheers everyone Ah, I get that. Thanks for the explanation. But surely, most spot welds don't have a contact area larger than 4 or 5 mm in diameter? That's why 8mm seems a bit like overkill, I've used 8mm holes before and it feels a bit clumsy so I switched to 5mm holes... here's hoping I didn't sentence my car to death
Jun 18, 2013 14:33:31 GMT
Thought you may like this. Purchased new away back in the 60's by my Grandfather. Was sold in 1983, then re purchased by my late Father again in the late 90's. sadly sold on and think she now lives on the Isle of Whight. If any one see's her, knows her or even has pics it would be great. Love your restoration, epic work there for sure.
Jun 23, 2013 19:42:54 GMT
The bigger the hole to fill, the larger the contact area to the other panel that is going to be welded = stronger. polo6n1600i Ive sent you a PM, hope something good can come of it, thanks for the info. Cheers everyone Ah, I get that. Thanks for the explanation. But surely, most spot welds don't have a contact area larger than 4 or 5 mm in diameter? That's why 8mm seems a bit like overkill, I've used 8mm holes before and it feels a bit clumsy so I switched to 5mm holes... here's hoping I didn't sentence my car to death I wouldnt worry. I also use larger size holes as the tip of my welder is larger so it makes it easier for me to see what I'm doing aswell. Lostsoul : That camper looks ace, you wouldnt have any interior shots would you? June part 2 Ive been busy this weekend. I really wanted to get this stage over so i was determined to get it all done. With the body finished i started to prepare the shell for the primer. Quite a bit to get it ready. I went to my work and borrowed the D/A sander and smoothed down a lot of the inside. I used a combination of sander/wire-brush/wire-wheel and polyabrasive discs. I then went over all the bare metal with the acid to eat any leftover pitted rust and then loads of water followed my degreaser. Then the bit i have been waiting ages to do, the primer! I even bought myself a mid-range spray gun for it. Need to stop borrowing the works stuff so often. I used up the remaining litre and a half i had left. And one with your handsome host Now i am happy. Now that the primer has been applied on the whole body i feel that this chapter has ended for me. Phew, what a relief. I look forward to starting on the suspension.
remmoc
Jun 23, 2013 20:29:12 GMT
Absolutely stunning workmanship , top quality repairs .
Jun 23, 2013 21:07:52 GMT
That looks great the work you have done on this is unbelievable and the fact it's going to be modified makes it even better fair play to you, keep up the great work...
fogey
Jun 23, 2013 21:37:03 GMT
Being a 'fogey', words like 'awesome' don't generally feature in my vocabulary - but hey, AWESOME!!
Jun 23, 2013 22:03:22 GMT
I absolutely love your project and skills!!
Jun 23, 2013 22:19:15 GMT
Sorry I don't, but trust me I am working on it.
My Uncle was going to look at his Mums house, but is currently in hospital with Leukemia and another source that thinks owns the van is struggling to contact him. Every pic I find of a Dormobile is external.
In 2001 it still had only 37,000 miles on her and was great fun.
I'm still picture hunting though.
I must admit I always cringe when people use the term "EPIC" but when a project goes from this to this With such a almost obsessive attention to detail if this project maintains momentum then it could almost hint on being an EPIC project.......... Thank you for all the motivation and education in this build........
joeytalent
ITB Everything.
Congratulations - looks like a huge step forward getting it all in the one colour!
very nice..
I will keep following this. love the van and the work you're doing to it...!
wns
Citroen HY 1962 Toyota CROWN MS75 1972 Toyoya CROWN MS75 1973 Toyota CROWN MS67 1972 Toyota CROWN RS56 1968 Toyota CROWN MS57 1969 Datsun 120a coupe 1975 VW LT31 1995 Volvo XC70 cross country 2007
Jun 24, 2013 10:06:26 GMT
If the rest of it gets the same treatment its going to go way past Epic.
Top work fella.
steveg
Jun 24, 2013 10:25:57 GMT
There can't be many 'new' shells out there looks brilliant !
steveg
Jun 24, 2013 10:26:31 GMT
Last Edit: Jun 24, 2013 23:55:08 GMT by steveg: Double post sorry.
Jun 24, 2013 19:23:38 GMT
A Great Milestone reached, well done
hamps
www.medwayrscentre.co.uk
Jun 24, 2013 20:37:27 GMT
Quality work mate as always.
eurogranada
Jun 25, 2013 10:07:19 GMT
Top job!! And great inspiration for those of us stuck in their own weldathon... (like me)
Jun 25, 2013 15:56:06 GMT
I don't post alot on here but i am an active lurker. I have been following this thread for a while but re read it start to finish over the last couple of days. Absolutely fantastic! Still the best thread on here documenting work you can truly be proud of! Well done.
This is still a treat to watch, perfect work. Can't wait to see more.
WOW is all I can say, spent the last 3 hours at work reading through this thread!!!
Very well done on all the work you have done so far and for keeping the motivation going for so long!!!
If you ever fancy relocating south I would happily employ you!!!!
Tom
