The airleak on stock Lada carbs is usually spoted on mounting base, even what the gasket is OK. The mounting base can be crooked so check it. Base is thin and needs to be screwed gently. If the carb looks that was taken off many times and installed again, it's recomended to chack the base. The fastest way to find the airleak is to spray some aerosol on the connecting parts till the engine runs.
^^ Thank you. That is very helpful. I have been looking in the wrong place for air leaks. I will fit new gaskets today.
Another Saturday spent carb fixing Seems to have done the trick - just need to tune it now!
EmDee
Committer of Autrocities.
Club RR Member Number: 108
1996 Lada Riva - MOT passedEmDee
@emdee
Club Retro Rides Member 108
I love these. have a pic:
Nov 10, 2010 17:22:12 GMT
nice sticker How's the carb working now?
Nov 14, 2010 16:18:44 GMT
Right - previous issues are sorted, but a new one has just developed. I was on a long journey, 350m round trip. I was going along the motorway fine, but when I came of the final sliproad and joined a minor road, suddenly the car was hiccuping when I tried to accelerate. I dipped the clutch and the idle was fine, and the car will accelerat when the throttle is completely pressed. What has happened? To put a bit of background to it - I have filled the tank 10 miles previous. When I pulled away from the junction at the bottom of the sliproad, I accelerated quite quickly.
Any thoughts?
purplevanman
Way too orangey for crows
Nov 14, 2010 18:24:05 GMT
could be dodgy petrol but given previous problems I would suspect summat else Sounds like a carb clean would be in order or try redex in the fuel?
ruffgeezer
Attracts french tat.
Nov 14, 2010 23:21:23 GMT
What sort of carb are you running?
^ It's a Russian Weber copy with an ECU and lambda feedback for the cat...
Hmm - mid range problems only, with idle and full power OK. Maybe a partially blocked main jet or a blocked emulsion tube progression hole?
Nov 15, 2010 21:15:17 GMT
Fixed it. Dismantled carb, got the meths out and set to work. An hour and a half later, I was out for a drive and experiencing more power than ever!
Nov 15, 2010 21:17:13 GMT
Good stuff - it's always nice when things go according to plan.
Do you have an in-line fuel filter on this? If not then it might be worth fitting one, especialyl if you have picked up a dirty batch of fuel.
Nov 16, 2010 16:20:20 GMT
What now?!
markbognor
Club RR Member Number: 56
1996 Lada Riva - MOT passedmarkbognor
@markbognor
Club Retro Rides Member 56
Nov 16, 2010 16:54:42 GMT
There's a set of 4x98 7x13 minnilight style wheels on the bay at the moment. ;D
speedy88
"Nice Cortina mate"
Club RR Member Number: 118
1996 Lada Riva - MOT passedspeedy88
@speedy88
Club Retro Rides Member 118
Nov 16, 2010 16:58:31 GMT
Let the mouse out?
Could be bearings. Does the sound go away if you warm it up?
Nov 16, 2010 17:00:45 GMT
There's a set of 4x98 7x13 minnilight style wheels on the bay at the moment. ;D I've just bought wobble bolts so I can go to 4 x 100.
Nov 16, 2010 17:11:46 GMT
Stick a bit of rubber pipe in your earhole and wave the other end round the engine. Makes it easier to pinpoint where noises like that are coming from. A high pitched squeal echoes off everything and can be hard to source.
--Phil
Nov 21, 2010 16:01:13 GMT
Last Edit: Nov 21, 2010 16:03:42 GMT by Fennec
