purplevanman
Way too orangey for crows
Nov 12, 2010 22:27:27 GMT
^^^ thats the stuff !! Lewis, ours is the same, don't get used to it though as it has been banned so it's just a matter of time till you can't get it anymore only problem is nothing else compares when it comes to degreasing :/
There was a guy in the States who had used carb cleaner containing Trike to clean a panel before welding. He seriously messed himself up (permanently!) as the heat from the welding struck the cleaner and created a cloud of Phosgene. There was a thread on here about it some while ago with a link to his blog. Really scary stuff.
I welded a Dolly Sprint tank once.
It was washed and aired out for months.
As soon as I touched it with hte welder it caught fire!
I discovered that I can do the 100m quicker than that Bolt bloke! ;D
Koos
used to work with this stuff in the 80's degreaseing stainless cutlery in heated tanks with extracters & its not flameable but is evil stuff.
theres more to life than mpg & to much power is just enough.
Nov 14, 2010 10:30:50 GMT
Here's how I got the GTM tank to use the pump and sender from the MR2. Note flat topped tank: (Not a brilliant pic.) Filled with water, with a lot of fairy liquid in it, then used an old SU fuel pump to circulate in the vent tube and out of the feed for half an hour into a bucket - so any petrol sat on top of the water reservoir - no chance due to the fairy liquid. Grinder action, and a bit of fitting later: Much more work later, including a sump for the pump, internal coating with POR and a nice lick of paint: And i'm a health and safety officer/advisor. Just be uber careful.
'83 GTM Coupe. 4A-GE Powered '00 GTM Libra Auto. Ick. '71 Detomaso Pantera. Current Resto '89 GMC Safari Tow/Kip bus '05 SAAB 9-3 Daily '71 Siva Moonbug. Not even contemplating resto yet.
