75nut
Sept 19, 2012 20:12:27 GMT
Got a little done today. Spent it taking the spare wheel well out. Used spot weld cutter to remove all the spot welds. Cut the well out with angle grinder with cutting blade and then chiseled the remains away Then used the wheel well to make up a template for the panel I'm going to weld in using the holes left over from removal for pug welds. But unfortunately the sheet metal I get is not quite wide enough to do it in one go so Il have the weld a bit more on. I started to knock in some strengthing strips, firs ttime doing this, going to flatten them a little and shape a bit nicer, but will defo do the job. Oh found more bodge, boot seal area, full of filler over rot!
90 Alfa 75 3.0 V6 Cloverleaf 79 MGB Roadster 88 Saab 900i Convertible 94 MK1 MX5 1.6 05 Volvo V70
75nut
Sept 22, 2012 20:48:21 GMT
So got on the boot floor wheel well filler panel again today. Found a bit of BMX piping ( I had cut some up to make a go kart for my daughter) that has the same profile as the swage and mounted on a piece of box steel to make a former to try an improve them. Swapped over form the big hammer to my proper metal working hammer which instantly gave a smoother finish, and then dressed it over my former with a flat head. Looking better. Last attempt was the best and using a blunt chisel to go round the edge gave a better shape All welded in from underneath. In reality its all going to get covered in heavy stone chip so the ripples would never have been seen but I just wanted to know it was the best to my ability. By no means perfect and being as I was trying to match the alfa swages which made it hard I feel. All seam sealed in now ready for the paint etc. One more thing ticked off! And hopefully easier brake pad changes in future!
Last Edit: Sept 22, 2012 20:49:27 GMT by 75nut
Sept 23, 2012 12:00:29 GMT
That came out quite nice and I like how you went about it. Some racers have done this for aerodynamics, looks like I have another project for my Alfetta.
1987 Alfa Milano/75 1979 Alfetta Mille Miglia 1976 Alfetta GT race car 1970 Lancia Fulvia 1.3 Rallye S 1968 Fiat 850 spider
75nut
Not got alot done as been sorting my daily, 92 Saab 900 Convertible for MOT, as per my other thread. But yesterday I got a few odds and sods done. First to sort was the rotten centre prop support jobbie (there to catch it I guess if it drops). The top was completely rotten. Bottom ok after a wire brush Took out spot welds and chiselled the top off Cut out rot and welded in new edge The wire brushed, zinc primed and stonechipped, covering the area I would be spot welding to Plug welded new panel over top, did not see the need to replicate the oval shape, its just allows access to the bolts. Then zinc primed and stone chipped whol thing after grinding off the plug welds Went back ,wire brushed off the seam sealer that had reacted to the spare wheel panel I had put in and re applied, it seemed not to like zic primer but ok with red oxide. Left to dry as it will then get hammerited,sptone chipped and waxoyled. A delivery of bits had arrived, bushes, anti roll bar and a frame, figure mas a well do all while its all out. A frame bush got burnt out, anti roll bar I pushed out. Id had painted it before as the bush had been ok, but now want everything as new its not good enough. Pressed the anti roll bar bushes with sockets and vice after they had spend a few hours in the freezer and I had heated the hole. It got a paint after Painted yoke and add he new poly bushes, all ready for new bolts, which currently I don't have lol! The gearbox mounting bushes are also to be replaced with brand new (she should be tight as a drum after all this!) , but the bolts where solid ,so the propane weed burner came out to remove those pesky hex bolts! Worked treat Will also get a coat of paint ready for the new bushes. The A frame bush is in freeze awaiting installation. Thats all , cheers
75nut
Weather was good so ditched the office and cracked on! First up pressed the the new poly bush in the A Frame after freezing it and using a puller The fitted the new gearbox mounts Set about the prop When your front donut looks like this is time to do something lol!! New one ready to go on , and yes I'm leaving the metals bands on untill its all fitted on car! Also got a rear one , this is the old one, its total useable but some very small cracking present and I don't want to take it all off again anytime soon Decided to leave the support as its ok with no cracking so the new one will be sent back to EBSpares or sold off cheaper on here Gave the tubes a light coat of paint and lightly bolted the new donuts on Then added my new Poly centre donut , and as you can see had a brain freeze and bolted the yolks to each other not just the donut, time to dig out the extra set of bolts lol! So here is how it is, lightly bolted ready to re instal once the aframe and gearbox are back in. Intresting to notice someone already marked the nip bolt
75nut
Jan 15, 2013 22:39:10 GMT
Built up the gearbox with calipers and pads again today, ready for the plan install of all the running gear tommorow finger crossed weather permitting
75nut
Jan 16, 2013 21:42:58 GMT
Well stuff is finally going back on Finished building up the gearbox and AFrame today. I also got the prop back in on the front mounts and the centre support ready to connect the gearbox tommorow. No pic as my phone battery ran out and by then the sun was going down and it was bloody freezing!! I'd been working all day in 4 layers lol!
EmDee
Committer of Autrocities.
Club RR Member Number: 108
Fleet Update pg10EmDee
@emdee
Club Retro Rides Member 108
Jan 16, 2013 22:40:29 GMT
Hero.
11.7/10
75nut
Cheers mate, much appreciated mojo boost
75nut
Jan 22, 2013 12:17:50 GMT
Got a little more done yesterday. I got a new helper when he heard I had new Donuts! Luckily I remebered I needed to fit the anti roll bar before the gearbox , so it went in with all its new Superflex bushes Forgot to take a pic of it in. That was about it, did not have any time to do more, but did find this, can someone remind me where it goes before I bolt everything in and find it was suposed to go in first!
75nut
Big Win today! This is back in As is this! As you can no doubt see that my man handling has removed some of my nice fresh pain so a touch up is needed. Also the cover blew of in bad weather and there is mud on my nice new black underseal. But I guess no worse than its going to be after driving 10 yards down the road lol!! So need to put fluids in gearbox, run it up to 5k and tighten the bolts on prop (do I remove the metal bands before or after this now the bolts are in?) attach the brakes and bleed them and attached the clutch pipe and bleed and I can bung the wheels on and go for a spin round the yard!
Tis a bloody great job you are doing..
Bicycle x1 Alfa Giulietta (now wife's) Alfa 156 BMW 630i Honda rc36
75nut
Cheers mate , much appreciated!
75nut
Feb 16, 2013 20:41:42 GMT
So I went on to make a new clutch pipe, refit it and bleed the slave cylinder. Having had alot of issues with the clutch fork and getting alot of advice I found the bearing in the housing that has 2 flat sides had moved, luckily you can get your fingers in there, so I managed to get it lined up and the fork in. But now the fork is in place there is no movement, and I am wondering if the clutch plate has seized. Also bleeding the slave cylinder, the pedal keeps going to the floor , despite fresh fluid coming out the bleed nipple and all the air being out. Use the standard method of having someone pump the pedal and then tighten the nipple when its down but the pedal still hits the floor and stays there. I have checked the connections and there is no leaks. So currently the fork is not moving and the clutch pedal is going to the floor. With the fork not moving it would not allow the slave to move in and out, presumably that would be affecting the bleeding
75nut
Feb 23, 2013 21:29:40 GMT
Oh so it's all sorted!
Got the other type of pressure bleeder as suggested and it worked a treat! I needed to put some air line tape on the bleed nipple as some air was being pull through the thread. Finished it off iwth old fashion maunal bleed with father in law pumping pedal.
The issue with the fork was simply incorrect positioning as I needed to put my fingers in through the hole and turn to get the flats of the bush inside inline with the fork.
So I then filled the gearbox and reconnected the rear anti roll bar.
Next job is to run up the car to 5k to settle the new donuts that are not fully tightened yet and then torque it all up and hope that marking all the nuts and bolts has kept the prop balanced.
75nut
Bit more done today. Gearbox topped up Here's what I used to bleed the slave Gearlever out and the push at bottom pressed out with rubber hammer and a socket. Cleaned and greased and pressed back in with the kindly donated seals. Could not find the rubber boot for the bottom of the gear lever for love nor money, so until it turns up a rubber glove gave us its life for a good cause. Exhaust went back on , been given a tart up coating o silver high temp paint, and trimmed some universal poly mounts Turned her on and purring like a kitten again! Only concern (hopefully you guys can say if it is a concern or not!) was that out of gear one of the drive shafts (passenger) was turning while the other was not. So why is one engaging while its out of gear?
Do you have a limited slip? USA 3.0 had them. But even with out there is often enough drag from the oil to cause 1 shaft to turn. You should be able to hold it by hand, if so, no worries.
75nut
Yes it does have a LSD.
The lads on the 75 forum said the same thig , re the drag, so cheers for putting mind at rest!
Always worry a litte as this is by far and away the most I've ever taken off a car.
Fleet Update pg10stealthstylz
@stealthstylz
Club Retro Rides Member 174
First time i've read this, awesome stuff. Whats on the back of the engine on these just a flywheel in a little bellhousing? Or is the flywheel and clutch in the transaxle?
