Evening all - I had a busy weekend after a 7hr round trip to collect the new wheels fri night and the bottom end gasket set arrived sat morning.
The new rims - personally i love them....
Dish
And a couple on the car
Then the gasket set in question
The engine in question
Stripped down the few bits left on the front of the block
Water pump
Oil cooler
Left hand balance shaft cover
Oil pump
Gave the block a good clean off - no blasting etc here as i don't want shot anywere near it.
Flipped it over to remove the gurdle
Gurdle off and thoroughly cleaned
Bearings inserted in to the block and lubed up
Bearings in the gurdle and lubed
Crank cleaned and layed in to the block
Locktite 754 rollered on to the gurdle as instructed in the workshop manual
Gurdle and oil strainer fitted
And torqued down
Next it was piston time
Make shift rinsing tank
Rubber hose on the rod bolts to protect the cylinder walls
First one in the piston ring compressor
And shes home
torqued up
All pistons fitted
Oil pump cleaned off
more locktite
Block cleaned
Pump fitted
New O ring on the left v old on the right
The O ring goes here
then the washer
Nexts the oil cooler
Internals cleaned and new O rings fitted
Cooler back together
With a new gasket
Cooler refitted to the block
Left hand side balance shaft seal removed
This very thin plastic shim is important - i've replaced it with new
Balance shaft seal replaced
And refitted to the block
Last but not least the water pump
crispy old gasket
gone
new gasket
And refitted but i forgot to take a pic
Getting a bit carried away i decided to put the cam box back together too
New seal
Gear on
Nearly there - end plate refitted
Done
This brings us to tonight - before i could do anymore i needed to clean up some more bits
Pullys
flywheel
the important sump and cam box bolts
And a couple of other bits
Just washed and dryed these bits
The degreased and hot washed the rest
Breather pipes all cleaned and dryed - some of these are perished and need replacing
Sump bolts and the other more delicate bits in the fine hand shot
I didnt want to go mad on these so they got the fine shot too
This pully needed the coarse shot - i did it by hand in the coarse hand shot as it was awkward to get into the resess.
Looking better
All of these looking better too
Some spray grease to stop them from flash rusting and into a bag
Painted the sump bolts up
cleaned these off
And painted these too
Hit these with the wire wheel
finally painted the cam box bolts and called it a night
Thanks for looking ;D
