tome30
Sept 23, 2011 15:12:29 GMT
Another home made catch canRobinxr4i
@robinxr4i
Club Retro Rides Member 143
Sept 23, 2011 15:17:23 GMT
Looks good I picked up one of these for the same reason (although being lazy I've yet to actually make it!) BTW To Air filter/carb To atmosphere
tome30
Sept 23, 2011 15:19:33 GMT
BTW To Air filter/carb To atmosphere Did concider it.
Sept 23, 2011 15:41:32 GMT
That's a pretty good idea. I wish I'd thought of it before I threw my old bottle away...
Sept 23, 2011 18:23:17 GMT
That's a pretty good idea. I wish I'd thought of it before I threw my old bottle away... You could say you lost your bottle (i'll get my coat)
1939 Francis Barnett Powerbike 1971 Honda C90 1992 Mitsubishi Lancer 1.5 GLX 1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van
Sept 23, 2011 23:26:35 GMT
Nice idea - I might just nick that one.
My lazy cheapo version is a squash bottle with two lengths of garden hose stuck in the top - one from the crankcase and one to the carb. Most of the fumes end up in the carb.
Last Edit: Sept 23, 2011 23:40:05 GMT by jrevillug
93fxdl
Enter your message here...
Sept 24, 2011 11:47:46 GMT
like the idea, but a couple of ideas to reduce the fuming have you got the correct filler cap are any other breathers blocked as in the past i have had problems like yours and blocked vents etc caused the problem ttfn glenn
Sept 25, 2011 15:55:41 GMT
bottles in satin alloy or black are in poundland bought one few weeks ago with same intention good call
Another home made catch canBenzBoy
@benzboy
Club Retro Rides Member 7
Sept 25, 2011 18:57:28 GMT
Ingenious! I love seeing things adapted like this - may have to pick up a few next time I'm passing Pondland.
Sept 25, 2011 19:42:16 GMT
Genius.
tome30
Sept 25, 2011 20:13:08 GMT
Fitted it today, I'll get some pictures up, looks alright! Doesn't appear to have stopped the blue smoke under acceleration, but I'll check the new air filter fitted today in a couple of weeks to see if theres any less 'oiling'
Sept 25, 2011 21:08:04 GMT
a catch-can doesn't remove virtually ANY oil vapour from the crankcase fumes..... You'd need a far far greater surface area, with cooling (alloy case, with airflow over it, etc) to remove even 20% of the oilly vapours
Catch-cans do look pretty mind you
tome30
Sept 26, 2011 7:36:50 GMT
93fxdl : I do have the correct cap and no other breathers seem blocked, but thanks for the suggestion. Chairchild : I agree, I don't actually think it'll do anything.
Sept 26, 2011 8:53:09 GMT
sure its not valve stem seals ?
Sept 26, 2011 9:00:58 GMT
oil vapour/fumes affects octane rating too. i fitted a diy catch can on my golf mk4 turbo. stopped the intercooler sludging up too
tome30
Sept 26, 2011 9:14:30 GMT
sure its not valve stem seals ? I've been told this many times, but have absolutly no idea what to do about it, or how much it'd cost? A friend explained they (Stem Seals) wipe excess oil from the pistons?? and if they're shot then the oil gets through and is burnt?? Sounds wrong.
VIP
Sept 26, 2011 10:13:22 GMT
Stem seals are a relatively simple job. It's simply the seals around the inlet/exhaust valves which prevent oil in the head from getting into the combustion chamber. When they wear, they allow oil from the head to get burnt along with the fuel, hence the blue smoke.
It's a case of whipping the head off, pulling the valves and renewing the seals.
However, I believe that stem seals usually show up as blue smoke upon starting, and on overrun, rather than on accelaration.
Blue smoke on accelaration is either excess oil into the carb breather, or -more seriously- piston ring wear. It could also be a head gasket failure where the fail is between an oilway and a cylinder.
Last Edit: Sept 26, 2011 10:18:21 GMT by VIP
tome30
Sept 26, 2011 10:30:42 GMT
However, I believe that stem seals usually show up as blue smoke upon starting, and on overrun, rather than on accelaration. Actually what I discribed as acceleration, would be from a stop. Its everytime I pull away from lights for instance, or if I rev the engine, on the down revs the smoke pops out. So sounds like stem seals then. I'm gonna google the procedure....Thanks.
tome30
Sept 26, 2011 20:10:18 GMT
