Hi heres the round up for this weekend
Bought a new welding mask (I'm not sure if i like it yet)
First up i set about removing the front carpet
making sure not to loose any of the fixings
I wanted to get at the offending gearbox tunnel
The carpets done well for 34 years of service
Is there supposed to be a lump of chip board here??
At this point i though oh toss whats it hiding, luckily nothing its quite tidy underneath
engine out again!
to get to the underside of the tunnel so i could see what could be done about the lack of space
After much fecking about i decided to move on to something else (more on the tunnel later)
Here is the next offending area
time to fit the new Corsa B brake assembly - this one below \/
spot weld time
after a quick sand over they all became apparent and i drilled them out with little drama
a bit crispy underneath, that's not a problem!
then it was out with the old brake assembly
to gain better access for some more drilling
I was careful with the important ones in the corner not to drill through.
Time to get brave and cut a big hole - it will become clear why I've cut so much out
more spot welds successfully removed
part of the heater blower plastic needed removing
to gain access to cut out some more metal
So as seen when others have added the corsa B brake assembly (like Darcy's below) you need to raise the whole assembly to get the pedal height right without cutting the pedal arm etc.
to avoid having a raised platform area i want to raise the height of the whole area so it looks more original and strengthen it while I'm there.
I will be following this line
In order to do that it was necessary to chop some more
getting there now
all the spots behaving again
a quick sketch
ready to be transfer ed to 2mm sheet
I then had to move to my phone camera as the batteries on the other one went flat so pic quality isn't great from here on in.
I set the corsa B assembly up on a threaded rod so i could adjust the height to suite
then set about the lower part of the bulk head to remove the holes left by the old brake assembly and generally strengthen the area with some more 2mm
this lot needed cleaning off first
as so
area below the rule needs filling first
I started with this
Some bending
And welded that in
Stage two the top part, roughly marked out
more bending
i used a piece of box here instead of angle to get the correct radius
as so
Tweaked these edges up with the mole grips
so it fits here
as so
Drilled the spot weld holes
Cleaned the edges off and tacked it in
And some more welding
in nice and level
finished off the welding
It could have come out worse
Hopefully it mirrors the other side to a certain extent
Once its all sealed up it will blend in well
Thanks
James
