May 10, 2012 20:31:06 GMT
cheers today started on the engine conversion... my jx td is using a little bit to much oil so found a good 1.9d (1y) from a golf 3 to put in my van started disassembling in and outlet gone distr. cap of
May 28, 2012 19:47:39 GMT
finally got cracking on the body work again... the pretty battered rear corner cut out and found a piece from a donor bus
May 28, 2012 19:49:24 GMT
new piece fitted and welded grinding and cleaning the whole lot some debrasel on the welds after that was sanded applied some normal filler also bought a DA air sander, love it wish I bought it a few years ago
been busy lately... new corner now filled and sanded along with the side panel and slinding door prepped the car to prime tomorrow not perfectly straight but I don't bother... it's had a tough life and don't want a bus full of filler so it's reasonably straight will be painted satin anyways so that'll mask some of the imperfections...
got up early yesterday to spray some epoxy primer on the bus: and fixed the step on the passengers side: that's one side finished
got some more work done tonight cut the rot out and folded a new piece ground down and sprayed some zinc primer over it also resealed all the body seams since I've "grinded" them out before I primed the panels some sealer on the drivers side step as well now drying, next up is the new front!
Jun 12, 2012 21:29:18 GMT
sanded and primed the door and B pilar yesterday then started with the new front panel found some quality repairs... and a little dent.. then out came the spot weld drill
and of you go! new panel fitted once i was happy with the result welded and glued the new panel in place
and there was the interior as well. I bought it really cheap but it was a little nasty... So my girlfriend removed the original fabric, washed it and sewed some new shiny fabric on top of it. girlfriend happy
mirafioriman
My next project.......
Looking good. Lots of progress recently you must be so pleased now it's painted
That blue is perfect, if you'd told me you were going that colour I would not have believed it would come out looking that good. The white roof finishes it off well, I'm hoping you stick to the black plastic hubcap type trims on white painted wheels.
75nut
Nice work, just caught this thread! Can I ask, what is debrasel? I googled bu could not find the info
90 Alfa 75 3.0 V6 Cloverleaf 79 MGB Roadster 88 Saab 900i Convertible 94 MK1 MX5 1.6 05 Volvo V70
thx!! volksangyl, what do you mean by black hubcaps? I changed the 15" mercedes wheels for the original 14" steelies with the chrome hubcaps... but will try this week what the weels look like in white... and debrasel: www.debrasel.nl/but it's a dutch website so you probably won't be able to read it... It's a type of aluminum bondo that get's rock hard. You have to sand it with an angle grinder if you leave it on for 2 days before sanding... you can even tap wire in it for screws/bolts etc. I almost always use it for visible welds that require bondo...
Jul 12, 2012 22:04:10 GMT
some progress... The old oil consuming TD lump the "new" 1Y golf III engine made it more buslike... when removing the engine from the bus found out that the clutch was all worn and cracked so had to buy a new one... mounting.. time for the new diesel to go in hope to get the rest done tomorrow...
Sept 12, 2012 20:05:57 GMT
hmmm, looks like i forgot this topic here! Lots have happend since last update though... rebuilding the van: since I didn't have an exhaust that would fit but I still had the TD damper and I didn't want to buy a new one. So I made my own connection between engine and damper: renewed the filler cap modified the bootlid because the 1Y dieselpump sits higher then the original one fitted a second battery
Sept 12, 2012 20:07:24 GMT
Sept 12, 2012 20:10:28 GMT
