Jan 13, 2021 20:26:15 GMT
Good job on the headlining. What technique did you use to get rid of the wavy bits? I recently did the headlining on my Avenger and haven't got the heatgun on it yet to tidy it up. I'm not looking forward to it to be honest. I use the heat gun, use a bit if heat on it and then let it cool off, you may need to do it a few times but I'd reckon using an off cut and trial you heat gun on it to get a feel for how to get heat into the fabric and how much you can get away with.
Jan 20, 2021 17:21:13 GMT
Jan 20, 2021 17:25:17 GMT
Jan 20, 2021 17:26:25 GMT
the third one is a 1500 deluxe from 63 but dismantled in bits but with a very good body
Jan 20, 2021 17:46:43 GMT
I will move the white one when it passes the German TÜV on it is a 1200 Deluxe from 66. The grey 65 one will stay so I am getting it ready for a German TÜV inspection and will use it asap when we have nice days with no snow salt etc. the other 2 I will keep for further project time and put them in storage
Jan 20, 2021 17:51:23 GMT
I quickly ordered some steels from Retroford and fitted 205-60-13 Avons now when I sort out the suspension I will drop it 2" and enjoy it.
I quickly ordered some steels from Retroford and fitted 205-60-13 Avons now when I sort out the suspension I will drop it 2" and enjoy it. That's an amazing collection you have, it's funny i have just ordered a pair of 7's for the back of my Cortina. What have you used for the front as I'm not sure if I'll run 5.5" or 6?
It has been a while since I up updated the thread but I have been working on the Coritna I promise! Moving on from the last update I managed to get a new windscreen and fitted and now the Cortina looks more car like as opposed to just being a shell. It's made by Pilkington if anyone needs a reference - use the SAP number Whilst waiting for some parts to come I made a start on fixing some leaks I had found/created. Firstly the steering box drop oil at a rate that would make BP blush so I figured whilst the lid was off I would turn a new filler cap as the replacements are only available in the rebuild kits which isn't worth the money when the bearings are fine as they are. A few hours later I had a new cap and tethered so that I don't lose it! The lathe needs some attention as I found it has a lot of backlash and the drive belt assembly is worn. Not only that I need to learn to work in thou! On a roll with fixing leaks I addressed the drip on the rear diff which meant taking the axle apart as you need to remove the half shafts before removing the diff - not a fun job! With the axle back together I finished off the handbrake which I need to take some photos of as it's one of my favourite things about the Cortina. It's wonderfully over engineered for something that doesn't work! I've spent the last 2 weeks trying to diagnose a problem which I thought would be easy but appears to be far more involved than I imagined, I had some problem getting the Cortina to fire up. Cranking had gotten slower and hard work so the battery was replaced but the problem persisted so the starter came off and was stripped and checked. Nothing was out of place so it looks as though the bearings are the issue as the replacement turned the engine much faster than the original had. The next issue was that I'm not getting a consistant 12v to the coil resulting in me wiring it directly to the battery which helped but hadn't sorted the issue. Wiring wise the switched live wire which this is part of has many joints and feeds the majority of the other cirtcuits so I believe there is a fault in there and I'm considering removing it all together with a single feed to a 12v bus bar and using that to simplyfy the circuit and also add more fuses as the horn, heater, radio and wipers are on the same fuse. this won't be a quick solution but I am drafting up a new loom design to show how it will work before making the change. What I need to do is work on that in the background whilst I get some jobs ticked off the list otherwise I won't keep the project moving along which is something I need to do - any way I hope you're all keeping well
Hi Jim, on both Cortinas we have gone for 6 x 13 all round. the white one has 175-70-13 fitted and they fit on the car and clear the front strut, on the grey car there are 205-60-13 fitted and they have about 2 mm clearance to the strut so I have fitted 5 mm spacers to give it some room. I have 20 mm spacers to fit on the back to fill the wheelarch if required. On the wiring side I have found on these older cars that the voltage gets lost in the wiring due to corrosion and higher resistance so just replacing the lot helps to get rid od a lot of problems and fitting relais where possible are a great mod. Take care Gavin
Screen looks good. Mine needs replacing as it’s full of grinding rash (Not done by me) making it hard to see out of when the sun is on it. Nice to see a bit of lathe action too.
On the starter Ford used to use a 10 tooth pinion, and later changed to 9 teeth, I remember my dad changing them on his Classic and Cortina to improve starting, perhaps this could be the difference.
Screen looks good. Mine needs replacing as it’s full of grinding rash (Not done by me) making it hard to see out of when the sun is on it. Nice to see a bit of lathe action too. I have a feeling that was part of the problem with mine, I don't know if we have the same screen or not but I did see on the MKOC facebook page (it's a dark and tormented place) that other screens are available from a few places -I'll get the details but I believe someone is making heated front screens which I wish I'd known about as that is something I like about my fiesta. That would also mean I could drive the Cortina in less than optimal conditions which is frightening on many levels! I must admit I enjoyed the lathe use as it's been more of an ornament the last few years, I know it has its flaws but I think it would be a fun side project once I have the Cortina on the road. On the starter Ford used to use a 10 tooth pinion, and later changed to 9 teeth, I remember my dad changing them on his Classic and Cortina to improve starting, perhaps this could be the difference. I didn't know that - I'll check the one I've removed but I don't recall seeing teeth mentioned on the owners club site when I ordered it, it's not much effort to remove it and count. As I was in the garage this morning working on battery cable routing I took a few photos of the handbrake - I'll give it another tweak but with the brakes needing bedding in I'm sure they'll improve in no time at all.
Last Edit: Feb 8, 2021 11:06:07 GMT by jim
The only one you seem to get now is the 9 tooth one which works better anyway.
When I rebuilt the minor with all new parts the brakes needed adjusting regularly for the first 500 miles, pedal improved massively after only 20 or 30 miles though.
Last Edit: Feb 8, 2021 11:18:17 GMT by kevins
Feb 14, 2021 18:47:50 GMT
I know that putting the quaterlights in first was the wrong thig to do but I wanted to do a trial fit and get a feel for fitting the brackets and test the fitment of the rubber. Having got a feel for how to fit the glass I started on the passengers side with the first taking an hour and a half! towards the end the last door I fitted was the drivers side and it took 20 mins I have only now managed to fit these door mirrors I've had sat for years waiting to be more than trial fitted - I may be able to see slightly more behind me - not that I'll have much behind me when I'm on the road!
I had found that there is an air leak on the inlet/exhaust manifold so figured I would take the opportunity to wrap the exhaust manifold as it sits close to the inlet, I have heard mixed reviews about wrapping manifolds. It is a painted and lacquered manifold but for the moment I'll leave it as it is.
Cool 7’s. What size tires are you going to for?
I'm not sure yet, I'd like something more road based than performance but not ditch finders spec
Do you have any recommendations?
broady
East Midlands
Mar 11, 2021 22:14:02 GMT
Happy to take full responsibility
