I have a 1974 Daimler Double Six and, now that the repairs to the body are drawing to a close, am looking at the other systems on the car which need overhauled. I had a look at the fuel lines and pipes first of all.
Inside the boot is like a snake pit but everything is fine because it is protected from the elements and the previous owner replaced several pipes trying to get to the bottom of a blockage problem.
There are really only two runs of pipe on the outside. The feed on the passenger side and the return on the driver's side.
The feed is 5/16" diameter and the return is 3/8" from what I can see
5/16" fuel feed pipe from engine runs under car and has join at rear seatpan area
male threaded fitting on end is soldered/brazed to pipe
2nd section screws on here....
....runs up over rear subframe....
....comes back down behind subframe....
....squeezes in through hole in boot....
....where it comes out and joins to 3rd piece via rubber hose
2 pipes with olives are feed and return pipes that sit inside boot connected to fuel pumps/valves then run under exhaust silencers to the fuel tanks. one with bead instead of olive is feed pipe (end which enters boot). middle pipe is larger 3/8"
As you can see in the pics the pipe is a bit crusty in parts and has snapped behind the rear axle. How would you go about repairing this. The Jaguar part nos are unobtainable (C.36431 for the short 2nd piece and C.37997 for the long front one). I don't really want to replace the whole system with metric fittings and you can't seem to get metal brake pipe now anyway. I have found these links for copper pipes and fittings in various sizes. Would it be possible to splice a copper repair section in using the compression fittings and olives available or would it be better to make a whole new one up in copper? Could it all be replaced with hoses?
www.vintagecarparts.co.uk/products/159-container-copper-tube-12
3/8" copper pipe
www.vintagecarparts.co.uk/products/158-container-copper-tube-9
5/16" copper pipe
www.vintagecarparts.co.uk/products/com-ol-container-solderless-fitting-compression-olive
olives
www.vintagecarparts.co.uk/products/deu-container-equal-ended-union
these things look like they could replicate joins
3/8" copper pipe
5/16" copper pipe
olives
