Jul 17, 2012 22:01:47 GMT
mrs car is currently out of action so most of my attention has been on that instead. However just got a few pictures sent through Big thank yous to Dez for doing them.
Last Edit: Jul 17, 2012 22:02:16 GMT by damien4884
1977 datsun 810 180b estate
This is a really inspirational project, thanks for sharing!
Jul 23, 2012 10:10:08 GMT
Got another 2 weeks off work now, well I quit so I can work on the datsun ;D 2 weeks and new jobs starts again! With some good weather forecast I thought it was about time to attack the roof, I have not been looking forward to this day at all. Its involves removing the screen and welding along the front edge where the roof has as much tendency to bend and warp as a sheet of paper. First thing was getting the bonded screen out, all the trim had already been removed to have a quick look at what is needed. It took about 15mins to get screen out, I used a 20mm bladed packing knife to cut the bonding. Leaving me with this: This exposed the rusty bits, its not as bad as I thought it was going to be, these datsuns seem to rust out on seams but on one side only. Theres another bit the other side at top but no picture yet!?! The bit at top of screen was first to attack. I cleaned it all up with wire brush in the grinder, cut and bent an L shape (15 and 16mm) done a bit of stretching on both sides to make it fit well. Welded it in and ground it down. Finished repair along roof Cut off a section of scuttle and repaired bulkhead and refitted scuttle bit. By this time the sun was directly over where i was work so had a break then decided as the bonnet was in the shade i could start sorting that out. By the time i had done that and had some lunch, the sun had gone over the house and i could go back to passengers side and get the floor welded up This list should be by the 20th but with the mrs car breaking down and the weather i've probably lost a good week or so, pushing the deadline back to the 27th, not too much of a problem just means less shakedown miles before the gathering. rear corner - nearly there DONE rear valance - few plugs welds DONE boot opening - think theres 2 small repairs to do DONE drivers arch and repairs to inner passengers arch and repairs to innerpassengers sill - repair to front edge passengers floor - small repair to leading edgefront wings - repairs and gapping CLOSER front panel - repairs to both edges CLOSER doors and bonnet - few localised repairs windscreen and roof - not looking forward to these nearly done Filler - splodge here and there Repairs to rear side window frames NEARLY DONE Next on the list is passengers sill, then that should be passengers side all done ;D
Last Edit: Jul 23, 2012 16:23:56 GMT by damien4884
bstardchild
Club RR Member Number: 71
Jul 25, 2012 21:46:58 GMT
You really have been craacking on with it - well done
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Jul 26, 2012 17:41:39 GMT
That is one stirling effort, well done and keep it up!
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
Jul 26, 2012 20:51:44 GMT
The welding around the window is all done, ground down, painted and window is back in. I'll probably get the sill done tomorrow and get the passengers wing sorted out then I can move onto drivers side for finishing off. rear corner - nearly there DONE rear valance - few plugs welds DONE boot opening - think theres 2 small repairs to do DONE drivers arch and repairs to inner passengers arch and repairs to innerpassengers sill - repair to front edge NEXT JOB passengers floor - small repair to leading edgefront wings - repairs and gapping CLOSER front panel - repairs to both edges CLOSER doors and bonnet - few localised repairs windscreen and roof - not looking forward to these DONE Filler - splodge here and there Repairs to rear side window frames NEARLY DONE Should get the wheels tomorrow
Last Edit: Jul 26, 2012 20:52:35 GMT by damien4884
Jul 28, 2012 12:03:16 GMT
Jul 28, 2012 12:45:47 GMT
cracking work, glad to see that Barnet Supplies got you the gas sorted nice and quickly Bookmarked now
Jul 28, 2012 17:55:10 GMT
They did well, the offer had finished but still well worth it, and they are about 1 hour away if I'm desperate. I don't know but does their own guy deliver it all the time or is it just cos I'm relatively close by?
Jul 28, 2012 18:22:42 GMT
I guess it was because you were local, mine was sent by carrier
Jul 28, 2012 21:17:00 GMT
This is coming along great, I have massive respect for anyone willing and able to weld up a Datsun.
Jul 28, 2012 21:21:27 GMT
This is coming along great, I have massive respect for anyone willing and able to weld up a Datsun. haha. they're not ALL this rusty..... actually.... this one doesn't look to bad.....
Last Edit: Jul 28, 2012 21:22:28 GMT by Al Ramone
Jul 30, 2012 14:04:48 GMT
good luck with ur project mate...
cant hardly wait for the result
datsun rooocks... lol
Jul 30, 2012 15:47:33 GMT
rear corner - nearly there DONE rear valance - few plugs welds DONE boot opening - think theres 2 small repairs to do DONE drivers arch and repairs to inner passengers arch and repairs to innerDONE passengers sill - repair to front edge DONE passengers floor - small repair to leading edge DONE front wings - repairs and gapping CLOSER front panel - repairs to both edges CLOSER doors and bonnet - few localised repairs windscreen and roof - not looking forward to these DONE Filler - splodge here and there Repairs to rear side window frames NEARLY DONE Few bits off the list and a few bits closer to being done. Heres a few pictures of the screen repairs, this has all been finished off tidied up painted and had the screen refitted. Then keeping with the passengers side i attacked the wing and front panel Got the second bit welded into front edge. Then welded up the sill so i could sort out the rear edge Tried the wing back on Tacked the inner bit on whilst on the car, removed reshaped the middle then welded up
Last Edit: Jul 30, 2012 16:06:34 GMT by damien4884
rear corner - nearly there DONE rear valance - few plugs welds DONE boot opening - think theres 2 small repairs to do DONE drivers arch and repairs to inner DONE passengers arch and repairs to innerDONE passengers sill - repair to front edge DONE passengers floor - small repair to leading edge DONE front wings - repairs and gapping DONE front panel - repairs to both edges DONE doors and bonnet - few localised repairs windscreen and roof - not looking forward to these DONE Filler - splodge here and there Repairs to rear side window frames NEARLY DONE Had a good go at it today. Attacked the rear arch, which is the main bit holding me back from MOTing, apart from a few mechanical bits. Then reshaped the rear quarter panel i made a while back, i did do the curve using quite a lot of guess work so not too bad. This is where my camera battery got a bit low and i couldn't find the charger. So theres a few pictures of bits that will not be seen again and i'll put some more up with the end result. Rear edge of sill into arch has seen better days and had a patch on inner arch. Chopped all the grot out Made this out of the left overs of passengers sill i got from datman I made the other 2 bits for the repair and welded them in. Small repair got welded in above the sill section i made and all done around the arch!
So had some fun with a can of lynx today, in between taking another car for MOT, Repairs, Retest and VIC check. (please excuse the amount of colours I'm trying to keep it protected and use up all the odd aerosols i have) The wheels are 7.5 wide compared to the 8 wide alloys from before and i wanted to keep a similar amount of stretch. Luckily the wheels had some 185's on them, so i could have a tester. I just need to get some decent ones and some 205 or 215's for the rear. **Top tip if you go to the lengths of blowing your tyres on, your better off with less propellant and working up rather than too much to start off with **
laks
Aug 12, 2012 17:39:49 GMT
Very nice work!
Time for some progress!! Few bits to bring us up to date, drivers wing and scuttle are in high build awating top coat (not really ready to be doing it but made a nice change for something to be all one colour!) They got taken back to bare metal, filled, zinc primed and high build primer. As I'm coming towards the end of the welding i've decided to hit one corner at a time and finish it all off before moving around to next bit. So first place was the area that needed most attention, the passengers rear quarter. These are the first bits to get attention Chopped out the rot Repaired (still not entirely got the hang of shrinking!!) Moved onto rear edge of sill The bit that goes to the arch is just tacked on so i can make the inner sill and inner arch repairs and weld them in first so i don't have to get under car to do the welding! Its now raining so I'm dodging the showers with a bit of card and some scissors so i can get the inner bits made ready to weld in when it stops.
retrolegends
Glad to see you have made some progress, any thoughts on a final colour?
