Dec 28, 2012 13:38:32 GMT
Jan 23, 2013 15:33:14 GMT
. To cold to be out the garage Ginger .
Last Edit: Jan 23, 2013 15:50:18 GMT by gingexr2t
teaboy
Make tea, not war.
Jan 23, 2013 19:14:07 GMT
. To cold to be out the garage Ginger . You need some long johns, Ginge
retrobastard
Tits or tyres means trouble
Jan 23, 2013 23:29:21 GMT
. To cold to be out the garage Ginger. You need some long johns, Ginge Yep can vouch for the warmness, my 1st year with thermals or "long johns" (got thermal t-shirts to) and will never not wear them in the winter now!!! Just need thermal socks now lol .[/quote]
Mar 20, 2013 10:04:08 GMT
. Been a little while since i've posted an update, Main reason is i've been a bit lazy, and been waiting on bits to arrive. 1st off i was on the MK Motorsport Supra Diff kit group buy through Passion Ford so needed to leave the engine, box, exhaust etc in place until that arrived so i could check everything fitted ok, Well i recieved the kit about 6 weeks or so ago but as my car is shorter than the standard and my prop being shortened 10mm to much MK was going to make my diff to prop spacer that extra 10mm to take up the difference, only problem is i'm still waiting for it :-( So all the kit is fitted but i'm held up taking the engine out to get it back upside down. Gonna have to ring him tomorrow as my message arn't getting answered. anyway, pics of said diff fitted I've been debating since the start of this project on wether or not to fit a 6 point cage as i want a standardish looking car, but after driving my old XR2 turbo which is cage i decided i needed one as it just makes the car feel really tight, So been on the look out for a while as i didn't want to pay to money for one as i needed to cut it up a bit to fit my floor. So i managed to get one off a member on here Joe, so a day trip form Cardiff to Preston and i had a 6 point cage with rear diagonal, Now i'm fitting a full interior so the diagonal had to go and the front and middle legs needed shortened to suit the floor, with this done new feet plates were made out of 3mm plate and welded on, and under side plates cut to match, Also managed to get an extra bolt fixing in the front tubes (see pics). Due to the diagonal being removed i decided to add an extra fixing to make it an 8 point by tying the main hoop into the front set belt B pillar fixing. After i'd finished welding it all back together i realised the lower front seat belt rails would not fit, So they were cut down with a hole drilled into the cage then insert into hole and fully welded so there now part of the cage :-) :-) :-) :-) PICS :-) On the front legs i welded a nut to the new foot before welding the foot and leg back together so as to get an extra fixing in :-) Hopefully it wont be 3 months until the next update :-) Ginger .
teaboy
Make tea, not war.
Mar 20, 2013 20:29:30 GMT
Nice work Ginge, I love reading this thread. If I had the time, money and shed space I would love to build one of these.
Mar 23, 2013 10:43:14 GMT
Cheers mate,
Hopefully gonna get the engine and box etc out over the next few days :-) Can get it backon the spil then and get the raised boot floor welded in.
Ginger
Mar 23, 2013 13:01:12 GMT
Very very impressed at this work log!!!!
Best of both worlds too!!! Escort looks and cossy power and drive chain!
Brilliant workmanship too!!!!
Keep up the good work!
Mar 24, 2013 14:51:34 GMT
Excellent work, gunna be a beast!!!
Mar 26, 2013 11:51:37 GMT
. Progress report. Well i've made a cock up :-) not unfixable though, I've got an MK Supra diff kit but i had fitted the centre prop bearing on with a block spacer on the wrong side causing limited forward and backward adjustment, this ment that the prop looked 10mm to short, not an issue as Mark from MK made my diff to prop flange 10mm thicker only to find that it's now 10mm to thick. Not a huge issue as Mark says it can be machined back down. Anyway after being a bit feed up i decided to look at the front Recaros, I have 2 sets Escort and 2wd Saff. Now i had looked at using the complete Escort seat on the Sierra runner but this pushes the seat 35mm upwards due to the Escort bases being higher Escort Sierra So after a good look over the 2 pairs of seats and measurement taken i found that the rear/back rest part of the seats were the same fitment and the base parts you sit on are exactly the same apart from the cloth pattern :-) So the 2 set were taken apart and i now have Siescort Recaros . Now i have a Sierra base with the Escort centre with the Escort back section that flips forward :-) :-) :-) :-) :-) :-) Flip forward The centre console came out of the donor Sierra and the cloth is a perfect mate:-) Because i've made my own rear end and not used the Sierra floor i have plenty of room behind the arm rest so should have a gap between it and the rear bench :-) And because of the rollcage i had to fit the seat winders on the inside as the touched the cage Also never noticed it before but the side bolsters on the Escort seats are deeper than the Sierra ones Escort Sierra And the other pair that'll be perfect for a 4 door or Orion. Thats another job ticked off :-) Ginger .
Mar 26, 2013 16:36:59 GMT
Love to see a good load of fabwork! Good going You gonna weld the plates that the cage bolts to onto the underside of the car?
teaboy
Make tea, not war.
Mar 26, 2013 19:57:45 GMT
Seats look really good
hamps
www.medwayrscentre.co.uk
Mar 26, 2013 20:54:41 GMT
Wicked loving it
Mar 28, 2013 18:37:33 GMT
Love to see a good load of fabwork! Good going You gonna weld the plates that the cage bolts to onto the underside of the car? Hadn't planed on welding the on mate, I might do when I get it back upside down. Not sure if there's any benefit from welding them on. Ginger .
Mar 31, 2013 20:08:36 GMT
Keep looking at the way you've widened your arches and thinking I could do it with my van..... but I'll probably just buy narrower wheels They'd be easier to finish off I was doing away with the kit, gonna take a lot of time to get them right so the kit fits perfect. Ginger .
unitybonez
Blowing Pintos
Amazing chassis work mate, truly amazing. I really cant wait to see it sitting on the ground...
Sent from my ouiji board.
MK2VR6
Mk2 Golf GTi 90 Spec
Now that's proper engineering. Good Lord! Watching with interest!
Aug 15, 2013 13:18:33 GMT
Awesome mate,a lot of thought is going into this car.
