mr
they're from Ali Express. i have the app on my phone. price for the pair inc post and taxes was under a fiver. they come with an allen key too that amazingly didn't round off straight away. there are links too between the central two nuts for putting the main pos and earth wires under
Got the car from 105 bhp at the crank to 152 at the wheels.nitrous going on next.....if it ain't broke,keep bolting on go faster parts until it is........ www.fordgranadaclubuk.freefo.de
mr
Last Edit: Jul 7, 2021 9:24:40 GMT by mr
gess
That golden heat reflective tape is looking good, hopefulle it also does what it says on the tin :-) Will there be a startup in the near future? It can't be much more that needs to be done for sure. Really looking forward to it.
mr
Gess, once I've sorted the engine bay I'll probably be dropping the tank off so I can seal it. The tow bars gone so it shouldn't be a big job.it seems there's no fuel in the tank now anyway so to sort the internal rust issue I want to get some tank sealant into it. The turbo timer arrived today but having looked at the instructions I've stepped back..... Thankfully mk2 cossie has offerred to fit it ( it's his sort of thing) so I'll leave it to him..... At least it will be done properly. Then it's just tidying up the paintwork scratches where I've been working on the car. I would like to fit a harness bar across the rear of the car (also suggested by mk2cossie) which will be fitted under the rear arch roll cage mounts and run across the width of the car. Been busy doing stuff on my sons 19 year old mini so not had much time to play cars. Also picked up an ancient seagull boat engine a few weeks back thats been eating up my time. Hadn't run since before 1970.....I've just got it running😁
mr
Jul 10, 2021 23:56:42 GMT
Someone mentioned the rear seat belt clips...... I won't say which mot inspector said it...... but they're now gone.
Last Edit: Jul 11, 2021 0:29:39 GMT by mr
mr
Jul 13, 2021 19:06:17 GMT
gess
It looks a bit like a Moon lander with all the gold wrap and the silver turbo heat bag :-) Do ypu have any kind of ducting to get cold-ish air to the filters or do you rely on air getting past the headlights and radiator?
mr
gess,not yet . i was messing around yesterday trying to work out the best shape to make up a heat shield.there are holes or press outs up the sides of the radiator cowling. i may move the washer bottle and run some ducting into that . or i could run ducting from the bulkhead as my bonnets raised at the rear.i could even add a small 12v fan just to help draw fresher air into the air filter area.really not decided yet.ill come up with something eventually
mr
Good old Ali Express 🙄 now have this....... Under 15 quid Inc delivery and taxes
mr
Jul 15, 2021 19:55:15 GMT
Last Edit: Jul 15, 2021 19:57:16 GMT by mr
gess
Nice job on the Seagull engine. It really cleaned up well. We used to have an old outboard engine on a boat we had, it was a Crescent from around the 60s, white and orange, with the throttle located close to power outlets on the engine. It would give you a little buzz if you didn't watch your fingers when throttling.
I guess it tokk a fair bit of time to polish the stems.
mr
to be fair, the chrome was in reasonable condition. the flywheel had lost its magnetism and it couldnt generate a spark which stumped me for a while . you need to run a drill on the flywheel for around 10 minutes to re energise it ,so that was actually a free repair. the flyheel is now painted in gold caliper paint as we had some left over from my sons mini. its only a 3 bhp motor so should be fine on our small inflatable. i've filmed ( like i always do) the resto from start up until now too. fresh fuel and a general clean up and the thing started up first pull. you really cant beat old british made stuff. its the most simple thing ever. most parts are now painted or cleaned so its looking much smarter than it did. our thottle on this is a thumb controlled one on the steering stick thing.its a bit smokey but thats where i was re energising the wheel with the drill. i took the spark plug out and was putting oil into the cylinder to prevent and damage
mr
Jul 21, 2021 15:44:10 GMT
After butchering the last transfer I ordered another and also repainted the tank too. Turns out, the transfer comes with an idiots fitting guide.... That this idiot didn't spot before. Anyway, only a few bits left to sort on this now it should get some beach action soon.another interim project out the way. I was talking to my late grandads wife today and she was so chuffed I'd saved it, kinda made it more special. So until my new boost controller arrives...... Here's today's tinkering. Will laquer it tomorrow
mr
Jul 25, 2021 17:42:33 GMT
mr
Jul 29, 2021 21:31:10 GMT
Last Edit: Jul 29, 2021 21:31:32 GMT by mr
mr
mr
mr
mr
Aug 10, 2021 14:49:03 GMT
mr
Aug 29, 2021 23:05:55 GMT
Last Edit: Aug 29, 2021 23:07:14 GMT by mr
