Jul 28, 2012 15:51:30 GMT
Had a look at the exhaust, tightened up one of the brackets, little quieter but the middle box is rattling a lot so either a straight through pipe or a replacment is on the cards. Handbrake does not work at all now :roll: Next job, Distributor. IMAG0231 by hoopsontoast, on Flickr The vaccum advance unit seems to work OK, but the bracket it advances barely moves without a lot of pursuasion, and the springs/top arm are quite loose. I think a recon one is on the cards or a 123Dizzy.
Distributor sent off to get a 123 conversion ;D New rad recore should be done in the next week or so, and need to order some brake shoes then we should be up and running for the gathering!
MrSpeedy
East Midlands
www.vintagediesels.co.uk
I shall be interested to see how you get on with the 123 dizzy and wether or nor they're worth the money
So will I Thought it did not sound too bad, its just over £300 But it would be £45 for a recon dizzy from the TDC, but they have no stock or £170 from Rimmers! Then add £100+ for a decent Electronic Ignition kit. And this is a plug and play solution and the standard 123ignition Distributor is £245 on its own, which would require modification to fit onto an 1850/Delco.
Aug 10, 2012 16:35:48 GMT
If you are interested I have some solid steel carb mounts for an 1850/HS4 setup. They made a big difference on my old 1850 but won't fit my new one because it's got HS6s. PM me if you are interested James
pitzey
Aug 10, 2012 20:36:34 GMT
nice motor check my sprint out its on here ;D
1982 dt125mx restored,(sold)
1986 mini being restored,(sold)
1974 dolomite sprint (sold)
2005 saab 9-3 convertable hirsh (sold)
2001 golf gti
2006 jaguar 2.2d premium sport black
1972 triumph stag mk1
1978 carmine red dolomite sprint
Cheers James, PM sent. Pitzey, will have a gander.
Aug 16, 2012 10:42:43 GMT
Alloy Carb mounts and 123Dizzy are here, great workmanship on the dizzy, real solid bit of work!
Aug 16, 2012 11:11:49 GMT
MrSpeedy
East Midlands
Aug 16, 2012 12:51:48 GMT
Glad it's turned up. Now stop messing about on here and go and get it fitted
Aug 16, 2012 12:58:56 GMT
I need to get home first!
Aug 16, 2012 19:11:27 GMT
Got it in, and eventually (after the rain break) and got it up and running. Not running perfectly, timing needs a bit of adjustment I think (tomorrows job) Currently using advance curve 8. Certainly a lot more responsive on the trottle :lol: :lol:
Aug 17, 2012 22:02:56 GMT
Let me know if you want to borrow the timing light to make life easier(I will be back around tomorrow afternoon). I am glad to hear that you have gain some sprightliness.
Hopefully I'll be at the Gathering in a retro but it is looking unlikely at the moment....
Aug 18, 2012 10:18:41 GMT
Thanks chas, I may not be there in the Dolomite after all, the clutch is playing up again. I will let you know
Aug 19, 2012 21:53:23 GMT
Have a ride in this today! It certainly shifts quicker or seems more responsive and swift than your TR7 of old was! Hopefully that jerking on light throttle at low speed will be something simple
Aug 19, 2012 22:34:46 GMT
Hopefully that jerking on light throttle at low speed will be something simple Too much advance by the sounds of it - perhaps a slightly more aggressive curve with a little less static advance?
It was bunny hopping when you just had a little throttle applied, I think it could just be the cable. It does not do it when there is no throttle or lots. Certainly sounds and goes better than the TR7! Hope you got back OK last night Chas.
Aug 20, 2012 12:27:46 GMT
Too much advance.
Aug 20, 2012 12:33:47 GMT
OK So just retard the timing a little?
