m3240z
Nice ECU the emerald
and yes i have split the gearbox and taken the clutch off looked prety standard to me but thanks for the heads up i need to look into that cheers
Terry
Mark
This is giving me filthy ideas!
m3240z
This is giving me filthy ideas! Do Tell just think this car was in you country 10 years ago
m3240z
first pic is of the m3 engine loom nice and easy plug and play, note the twin vanos control ciols then six plugs for the coils and six for the injectors , next picture is of the loom modified for the stand alone ecu which will still control the twin vanos on the cams
m3240z
Right last post for a week or so need to get on with making a wiring loom, not easy trying to make 1970s wiper/headlamp storks control modern relays, datsun in there time liked to switch earths to everything, mix that with a stand alone ecu and you get this, with a bit of luck i should get it running next week, the easy bit is the fuel system, fuels pumped into the filter then into the vacuum controlled regulator on the end of the filter then one return and one feed to the fuel rail easy ! see pics
amazing
@ CRX_IN_SCOTLAND
Excellent work , love those big fat Minilights, those suit it down to a T, will be even better with arches on
Nov 11, 2012 22:50:36 GMT
proper engine that, will be a beast when all running,
do you have any parts from the M3 left? i've got an e46 and could do with some bits
m3240z
Nov 12, 2012 19:45:21 GMT
More wiring done. my head hurts now And shes running ;D ;D ;D ;D ;D ;D ;D
m3240z
Nov 12, 2012 19:52:44 GMT
proper engine that, will be a beast when all running, do you have any parts from the M3 left? i've got an e46 and could do with some bits Paul the car is a rolling shell now, i sold lots of bits but give me an idea or a list and i'll see whats left Tel
Nov 12, 2012 23:27:57 GMT
bloody brilliant progress That wirring looks fun, hope you have it all drawn out on a plan somewhere
Last Edit: Nov 12, 2012 23:35:02 GMT by sierra1off
wow- yep this is cool!!!!
OMG! That is SO awesome!!! And what a noise!! Nothing beats a big straight-six!! No-thing!! ;D Insta-Bookmark!
m3240z
Feb 23, 2013 21:27:29 GMT
Progress is slow due to it being just above freezing for the last 2 months but there is some, thought i had better make sure the car is square before making the roll cage mounts so started doing a dummy run for the pannel fit, the doors wings bonnet tailgate and bumpers are going to be fibreglass (god there light ;D)so here are some pics
<a href="http://s1104.photobucket.com/albums/h336/m3240z/?action=view¤t=041_zps5d35c8f5.jpg" target="_blank"><img src="http://i1104.photobucket.com/albums/h336/m3240z/041_zps5d35c8f5.jpg" border="0" alt="Photobucket"></a>
m3240z
Feb 23, 2013 21:29:01 GMT
m3240z
Feb 23, 2013 21:49:14 GMT
m3240z
Feb 23, 2013 21:54:36 GMT
m3240z
Feb 23, 2013 22:03:51 GMT
Did you notice the square hole cut out in the tunnel this is so i can weld in a plate for the m3 gear lever its just a rubber bush and a large grommet the the two rods attach to the g/box ordered a toyo R888 the 10 x 15 minilites came shod with 245 40 15 avon CR500s but i think they was quite old so the only decent rubber you can get is the toyo R888 in 235 50 15 i was well pleased it came up a bit wider than the avon and just proud of the rim
