Oct 27, 2015 14:58:24 GMT
Got some more done! Started retubbing the drivers rear arch! Got the arch new arch in position lots of measuring so its the same as other side screwed in place until i have fully welded the inner arch and plated over the fuel flap! Repaired the rear panel all rust cut out! and reinstalled so its in the correct position! Once i have finnished tubbing the drivers rear arch thats all the major welding a repair work done!
Retro Concepts LTD Automotive Fabrication, Customization & Conversions.
Oct 27, 2015 22:04:38 GMT
I've got to admit I wasn't sure where you were going with this at the start but it's shaping up really well, those Golf arches were a good choice, keep at it!
Last Edit: Nov 24, 2015 10:26:50 GMT by spartacus
luckygti
I need to try harder!
Oct 27, 2015 22:56:03 GMT
Looks great, really suits the arches too.
Oct 28, 2015 17:50:11 GMT
Thanks Spartacus and luckygti the golf arches are a massive improvement from the originals.
Nov 21, 2015 21:16:00 GMT
Nov 21, 2015 23:48:42 GMT
ps front arch on a wing is same profile as ds rear and the other side is the same , so ole front wings with good arches can be put to good use
Nov 22, 2015 16:29:06 GMT
love cars with raised arches, which golf are they from?
VIP
Is it me or have you welded in the rear arches higher than the front ones?
Nov 24, 2015 20:16:23 GMT
Is this a bad thing?
VIP
Nov 26, 2015 16:22:47 GMT
Visually it'll look weird, no car has rear arches higher than the front, and you'll want the front arches level or at least higher to allow for steering at lower rides heights.
Look at the German Derby for reference.
Last Edit: Nov 26, 2015 16:23:57 GMT by VIP
Nov 26, 2015 17:28:43 GMT
Well do a quick Google search and I can find loads of cars the same shape as mine were the rear arches are higher than the front! And to be honest the rears look higher than they are once welded and painted they are about the same level as the front!
heathrobinson
Broken everything
Club RR Member Number: 111
1978 Volkswagen Derbyheathrobinson
@heathrobinson
Club Retro Rides Member 111
Nov 26, 2015 20:05:43 GMT
VWs that I like are a really, really rare thing. But this is one of them! I really like how it's taking shape.
Sept 25, 2016 22:34:47 GMT
About time for an Update. Got my self a new unit this one has space to store and work on cars inside so i can get on with my build without having to wait for the workshop to be free and having to always keep the car so it can be moved. So Now the derby is in his permanent space i can strip all the suspension and stuff from the front end. First job was the engine bay removing the factory stone chip in the engine bay and preping it for some paint! Stone chip removed! Anti rust primed! And a lick of colour! Painted and fitted a polo mk2f GT/G40 steering rack and steering damper! Installed the suspension and stuff so i could test fit the mock 15 x 8 et0 wheels to check clearance with the new arches! Looking good! next will fit a polo Mk2F GT engine tomorrow and then sort the loom and get it running! so i can start on preping the body work for paint!
Sept 26, 2016 20:37:44 GMT
installed the engine today and played with the wiring and now have spark and can hear the injectors working and engine turns over! now need to remove the engine again install the brake lines sort out fuel lines get hold of a aftermarket fuel tank and make an exhaust system! Tomorrow will start removing the dash and seats ready and prep for paint also remove some not needed wiring!
luckygti
Sept 29, 2016 17:45:19 GMT
Glad to see this back at the top of my bookmarks, still love the look, and the stance with those front wheels is spot on. Just needs to be rear wheel drive now
rickygolf83
Scotland
Mk2 Golf 8v & 16v, VR6, Nova Antibes, Mk4 1.8t & mk4 Gt Tdi 130
Looks perfect!
heathrobinson
Broken everything
@heathrobinson
Apr 16, 2017 10:32:52 GMT
Good to see some progress on this, I can't wait to see how it'll look when it'd done
