Nov 16, 2013 10:03:37 GMT
I am really interested in this conversion. looks great and very impressed with your work. I am thinking of doing one myself. your an inspiration. For R/H drive could you use the Audi rack and modify the column?
keep up the great work and posts!
dubwarrior2
"Open up, its the filth"
Nov 16, 2013 20:18:50 GMT
I know you are a very skilled mechanic/machinist/fabricator/artist etc, but how the hell did you figure out all of the wiring for the motor? Is it as straight forward as just removing all of the curse word that doesn't connect to the engine loom? Also, in order to get it to run, have you kept the audi ignition and immobiliser or have you managed to bypass them?
The main thing that I like about your build threads is your straight forward can-do atitude. Far too many people on forums who are afraid to try new things or spend too much time thinking and planning stuff only to think themselves out of actually doing it. You just tend to get on with things and do them. A proper hot-rodder.
Nov 16, 2013 21:37:12 GMT
I know you are a very skilled mechanic/machinist/fabricator/artist etc, but how the hell did you figure out all of the wiring for the motor? Is it as straight forward as just removing all of the curse word that doesn't connect to the engine loom? Also, in order to get it to run, have you kept the audi ignition and immobiliser or have you managed to bypass them? The main thing that I like about your build threads is your straight forward can-do atitude. Far too many people on forums who are afraid to try new things or spend too much time thinking and planning stuff only to think themselves out of actually doing it. You just tend to get on with things and do them. A proper hot-rodder. Ha ha you’ve sussed me. Lay the loom out on the floor. Cut the curse word out, mount on an old piece of wood, shorten wires, put back in. Keep EVER THING simple. Motor vehicles are very basic once you remove all the bull *hit. What I do is not rocket science. Even though lots of builders like to mystify it. As for the “can do” attitude. That comes with age and I'm *loody old, ha ha . The immobiliser is still there. (Key now taped to the coil thingy) It can be removed from the ECU but costs more than I'm willing to pay. Dave
Nov 16, 2013 22:03:25 GMT
I am really interested in this conversion. looks great and very impressed with your work. I am thinking of doing one myself. your an inspiration. For R/H drive could you use the Audi rack and modify the column? keep up the great work and posts! Was considering converting to left hand drive, but after driving the van for 2 months before starting the conversion. I changed my mind. It doesn’t make much difference. The van is tall enough to see over most vehicles. Plus it has its advantages. You can talk to pedestrians. Scream in the ear of *loody cyclists. Remonstrate face to face with idiot drivers. Step straight out onto the pavement as these things are so wide you stand a good chance of getting run down if you were to exit road side. As for fitting the Audi rack I never got that far, but I think with a little machining the Citroen rack could be flipped.
Hi, we move back to NZ after Shanghai so RHD would be better for me there, it's tricky with NZ compliance etc.. will source a van next year in Europe and ship it. So it's interesting to know that with some machining maybe flipping the rack might work it would save a heaps of hassle. then just the wipers to change over i suppose... cheers..
This is amazing, your a very talented guy.
Nov 17, 2013 15:00:07 GMT
As I said before, this week I installed the engine management. Cutting all the wires going to the engine, to length and wrapping. This took a whole day. View from the cab. View from the front. Also made up the battery leads. But forgot to order any ends. So made them as well. As I have no photos of the finished underside. Showing its rust free condition. I took a few. All I had to do here was wash the chassis/floor area down with a stiff brush and soapy water, panel wipe and paint. Took a few snaps of the business end while I was at it. Looks a bit busy in there….. With the van back on the ground it was time to fire the motor up. Turned ignition on and all the dash board lights lit up and flashed just like they should. Engine turned over but wouldn’t start. Few more tries and nothing. After several more attempts the battery was starting to drain. In desperation I gave it a quick shot of easy start. (I don’t like using the stuff) and ………………………………. Away it went. Coughing and sneezing for a few seconds, then it cleared and ticked over beautifully. It now starts first time. Every time. The rest of the day was spent fitting the large box of water hoses I ordred from e-bay. Apart from bolting the radiatoer to the front of the chassis that’s the mechanical side of this project finished. Next week I continue with the body work…………… Dave
Last Edit: Nov 17, 2013 15:01:42 GMT by hanger18
adi
Nov 17, 2013 15:50:49 GMT
We need a video of this thing on the move with its new innards!
Nov 17, 2013 18:01:21 GMT
I'm seriously jealous of your skills
dubwarrior2
Nov 17, 2013 20:09:43 GMT
Love that straight exhaust pipe.
dubwarrior2
Nov 17, 2013 20:14:56 GMT
The immobiliser is still there. (Key now taped to the coil thingy) It can be removed from the ECU but costs more than I'm willing to pay. Dave So do you use the original citroen ignition key and barrel? Sorry, I'm a bit confused how you have done this bit. I know there is a loop/coil/ring thingy that goes around the original Audi ignition barrel and reads a signal from the Audi key. With these taped together, do you then use the original citroen ignition barrel and key just for turning the starter and live feed to the electrics?
teaboy
Make tea, not war.
Nov 17, 2013 21:32:08 GMT
I think this is fantastic!
Good choice of engine too, Mrs Tea has an A4 which is currently showing 245,000 miles on the clock and still plodding on (touch wood).
The immobiliser is still there. (Key now taped to the coil thingy) It can be removed from the ECU but costs more than I'm willing to pay. Dave So do you use the original citroen ignition key and barrel? Sorry, I'm a bit confused how you have done this bit. I know there is a loop/coil/ring thingy that goes around the original Audi ignition barrel and reads a signal from the Audi key. With these taped together, do you then use the original citroen ignition barrel and key just for turning the starter and live feed to the electrics? All the ign wiring now goes to the original Citroen ignition key. The immobilizer coil was removed from the Audi barrel and the key with the chip in, temporarily taped to the coil. ( so the engine will run) I will eventually make a proper anti theft device using the chip and coil. Or I will get it removed from the ECU when I get it remapped. Dave.
Awesome build so far, i absolutly love these old vans and the engine gearbox combo is spot on! one day ill do this to an old DKW van, Keep up the good work
'90 Audi B3 Coupe 2.3 Auto [gone] '92 Audi S4 Avant 2.2 AAN Turbo Auto [gone] '93 Audi 80 Avant 1.9TDi [gone] '96 Audi A4 Avant 2.6 Quattro [gone] '97 VW T4 1.9td LWB [gone] '03 Skoda Octavia 1.9TDi [gone] '05 VW T5 Shuttle LWB 1.9TDi '15 VW Caddy Maxi Kombi 1.6TDi
eurogranada
Nov 18, 2013 10:24:56 GMT
I can only hope I get my Cos bob to fire that simply after all the loom work!! Just amazing and I think you're playing down your skills!
Frankenhealey
Club RR Member Number: 15
1964 Citroen HY Van (part 2)Frankenhealey
@frankenhealey
Club Retro Rides Member 15
Nov 18, 2013 17:27:10 GMT
I am really loving this thread but the sad thing is that SWMBO was reading over my shoulder and now wants one for her business.
village
Always carries a toolbox. Because Volkswagen.......
Nov 18, 2013 19:41:39 GMT
I am really loving this thread but the sad thing is that SWMBO was reading over my shoulder and now wants one for her business. You need to finish the Goddess first....
"The White Van is strong with this one...."
Chris "Chesney" Allen 1976-2005 RIP
Nov 18, 2013 20:32:49 GMT
I am really loving this thread but the sad thing is that SWMBO was reading over my shoulder and now wants one for her business. I think that would be a great idea, we all love a good thread Good luck! John
Nov 18, 2013 22:16:03 GMT
Of course bookmarked! One of my favourite threads now!
cheers, wrecksforever
