polo6n1600i
All I need is WD40 & Duck tape!
Dec 15, 2013 15:39:57 GMT
Decided i'd better put some pics up of new project car! Bought locally cheap - only done 30 miles in the last 3 years - only mods are the BBS 14" wheels (BMW RBA's) and a set of upraded springs and shocks. As bought with 1 months MOT & Tax Got it through an MOT after:- new calipers x 2 on the back new discs and bearings new brake lines new fuel pumps x 2 new fuel pump relay new fuse box 4x Bosch plugs new leads new coil new dizzy new TCi module uprated headlight loom Passed first time with 1 advisory (drivers side seat doesnt tilt)
2002 Vw Polo 1.9 TDI sport - Daily Diesel 2006 Vw Passat 3.2 v6 estate - family wagon 1990 Rover Montego 1.6 LX - Project 41
polo6n1600i
Dec 15, 2013 15:40:36 GMT
polo6n1600i
Dec 15, 2013 15:41:03 GMT
Underbonnet tidied up.
polo6n1600i
Dec 15, 2013 15:41:30 GMT
New parts.
polo6n1600i
Dec 15, 2013 15:42:33 GMT
polo6n1600i
Dec 15, 2013 15:45:49 GMT
The lamps are actually genuine Bosch ones with correct MK2 golf brackets - you remove the lower of the screws that holds the wing to the front panel and fit a special squared of washered screw to hold the lamp to. Was a mis-listed ebay bargin! (covers are just some I had lying about!)
New plans are to redo the Sebrings in Silver Plasti-dip (just recently powdercoated in black, but look a bit lost in there) Get the bushes replaces in the front suspension Repair drivers side seat
And enjoy it.
adi
Dec 15, 2013 17:15:48 GMT
I like the driving lamps, I've had 15 mk2s and currently own 2, but never tried that look before *goes ebay hunting*
Uprated light loom is a must on these, hope you got/made a kit with 2 relays for the dipped beam, too many ebay special kits about with one relay for both dipped beam, known to cause a stained undies moment when the relay gets damp and fails!
polo6n1600i
Dec 16, 2013 11:07:54 GMT
I actually make and sell my own looms to the owners club and on a few facebook pages. Mine have an aux fuse box (from battery to fuse box, velcro's to side of the battery!), each relay has its own fuse. 1 relay for each headlight dipped beam, 1 relay for full beam for outer lamps and last relay for grill lamps. All done correclty with crimped connectors and heat shrink, relays all clipped together on a mount which just fits in front of the battery behind the p/s side headlight. Its something ive been doing for ages and slowly learned from experience how to do them correctly. Even the driving lights have their own little relayed loom too!
polo6n1600i
Dec 16, 2013 11:08:29 GMT
I should also say this is #50! (maybe I have a VW issue!)
polo6n1600i
Nov 28, 2015 15:33:51 GMT
Ok So I thought i'd better update this! Since then its been in the bodyshop twice - once to replace the scuttle panel and upper section of the bulkhead (fuse box was faulty due to water getting into the car via a badly fitted windscreen seal) - 2nd time was due to an MOT failure (seal split on both rear turrets - so repaired by drilling out spot weld and welding the seams and plating the small holes) Its now on old skool Avo top adjustable coilovers set pretty low. new top mounts, wishbones bushes etc. Also fitted CB & Bluetooth radio for handsfree and music...
polo6n1600i
Nov 28, 2015 15:34:41 GMT
Oh and headlight washers, Heckblende & Magnex exhaust system...
polo6n1600i
Nov 28, 2015 15:39:46 GMT
Ive also got a new project car too - this is currently the new daily (my Mk5 Jetta TDi is now for sale!) This is maybe a little new for on Retro-rides - but it is a rare beast! Its a 3.2 V6 4motion - not bad for £4k...
polo6n1600i
Dec 19, 2015 13:29:10 GMT
Mk2 is back on the Road - its been having issues with batteries recently going flat! Turned out the bulb switch for in the boot has been damaged by the bodyshop, so the 2 points have been touching and running the battery flat. Temporary fix - removed bulb....
polo6n1600i
Jun 19, 2016 13:06:46 GMT
polo6n1600i
Jun 19, 2016 13:08:29 GMT
The Jetta has since been sold.... And the Passat hit with the coilover stick! Time for a few pics on my hard work....
Jun 19, 2016 18:57:06 GMT
LOVE the trailer (MK2???) on the car in front.....
the wife has a B6 Passat with 157,000 on it now and have always loved that ride. peppy, comfy, ect. (2.0T FSI) I have fancied a wagon like yours for some time....
very nice.
JP
polo6n1600i
Jul 23, 2016 13:04:07 GMT
So its time for the MK2 to go onto the next step! MK2 Rally replica! This is what i have in mind. Just starting to buy up graphics and other bits and pieces. Wheels are proving hard to find (Ronal R8's - only 1 set on ebay!) Need to raise the suspension & upgrade a few parts. Should be fun!
polo6n1600i
Jul 23, 2016 13:30:36 GMT
Wasn't a fan of the old look, but rally rep will look ace!
massive pic alert:
Last Edit: Jul 28, 2016 7:42:36 GMT by TerraRoot
