I have wanted to build a retro style fuel pump for my drive outside the garage for some time, as I cannot justify paying the prices charged for "patina'd" pumps.
I started a few threads on various forums as I was hoping to get a plain white globe to fit on top, but it has become obvious that they do not come cheaply, so I am onto plan "B" now, which will not include a glob on top.
www.retrorides.proboards.com/thread/162511/large-white-glass-light-shade
£950.00 for this is fine if you have loads of disposable cash and little distinction of value.
Seen last weekend at the NSRA Swapmeet.
![](http://i294.photobucket.com/albums/mm90/niknakpix/niknakpix008/Billybob280_zps78ed3294.jpg)
This one was already sold at £950.00
![](http://i294.photobucket.com/albums/mm90/niknakpix/niknakpix008/Billybob279_zps7aa4b3e4.jpg)
Bought this at the NSRA Swapmeet for £5.00 a Bargain, and once distressed and stripped of modern plastics, it should look the part.
![](http://i294.photobucket.com/albums/mm90/niknakpix/niknakpix008/Billybob277_zpsb475a1b4.jpg)
Paid about £42.00 including postage for this one on Evilbay, waaaay too much, but what they go for sometimes.
Still need to decide which one to use, or if I want to make a double sided pump with two nozzles.
![](http://i294.photobucket.com/albums/mm90/niknakpix/a27_zpsa7cb270a.jpg)
Nicola's brother works in Suriname most of the time, managing a fleet of dredgers and tugs that work on the rivers.
When he heard I wanted to find some hose for the nozzles, he offered me a whole new, unused fire hose reel.
The next morning Nicola who did not know they were coming, called me in a panic, he had dropped off two, one of which has since found a new home.
I will be using some of the red hose, which will dictate at least in part my colour schemes.
![](http://i294.photobucket.com/albums/mm90/niknakpix/niknakpix001/a34_zps6ef8106f.jpg)
Bought a complete vintage petrol pump face sticker off Evilbay, about £6.00
It will be made to fit inside some perspex, hopefully taken from an old caravan window.
![](http://i294.photobucket.com/albums/mm90/niknakpix/pump2_zps1e528914.jpg)
About 6 months ago Nicola had a clearout at the funeral home she works at, but this broken locker did not make it into the skip.
So about 5 weeks ago I went down to fetch it in the Chevy, loving to make the truck work.
![](http://i294.photobucket.com/albums/mm90/niknakpix/pump1_zps308fc904.jpg)
Last year Mickey had to remove a display unit from a Tony & Guy hairdressing boutique and dump it, but before he did, I removed the white steel sides which had a nice curve on them and were of seriously thick steel as they were structural. At the time I had no specific purpose for the pieces, but knew it was only time......
Today I started to prep the steel and the locker.
![](http://i294.photobucket.com/albums/mm90/niknakpix/niknakpix011/a51_zps8217277c.jpg)
Using a 1mm cutting disc, I removed the 90' lip on all of the sections from the hair salon.
Then I cut them to size as I want my repro pump to be 5 foot tall. The plan is to use these sections to make the front face of the pump rounded with a raised section for the clock face etc.
![](http://i294.photobucket.com/albums/mm90/niknakpix/niknakpix011/a52_zps25c0d213.jpg)
Lastly, I butt welded the plates together, leaving the front face unwelded, a minimal skim of filler will sort the joins in the end.
Next up, I need to make up a complete front frame, fill in the open space and cut the cabinet down by about 6 inches, not much I know, but it will be right then.
I also need to weld in a bit of strengthening to the cut down door.
Once made up, I need to find a small vertical compressor to fit inside so that I have a compressor on the drive.
Done for today..... two 5 foot sides and a 3 foot length that needs to be cut in half to make a top and bottom section.
![](http://i294.photobucket.com/albums/mm90/niknakpix/niknakpix011/a53_zpsd7c23f58.jpg)
I am also going to look for bits of old car or refrigerator/cooker trim to use on the front and sides of the pump to embellish it a bit, giving it a bit of an Art Deco feel.
I will leave you with this, a metal star we bought after Christmas 2012 in the sales.... I knew it would come in useful some time.
Now it will form part of my non existent "Star Brand" fuel logo.
Any ideas and advice welcome.
![](http://i294.photobucket.com/albums/mm90/niknakpix/vice3_zps62d12721.jpg)
