820
May 19, 2017 18:06:04 GMT
okay, this is how it has been for many years. It came from an old ex Jaguar dealership I worked at, they were being thrown out, I grabbed 2 the other needed a service with lots of freeplay in the pump action, so was given away. This one works perfectly. a good clean, several sheets of emery cloth and 2 tins of Hammerite later. Unfortunately no pictures in between just almost finished. Bearings cleaned and wheels ready to refit. Nice bright yellow perfect for a workshop. The original sticker was beyond saving but fortunately under this panel was another identical sticker on the cylinder in much better condition so it was carefully peeled off and glued to the outer panel Almost finished just a few areas to touch up, and just noticed the ends of the front axles should be white. Will update when finished, cheers
Last Edit: Dec 5, 2017 16:38:13 GMT by 820
Nice job, I have the smaller version in the queue for repair. That should last forever, you now need to buy something heavy to lift with it.
820
May 20, 2017 16:37:25 GMT
Thanks, cant help with regards Epco Dunlop production, just says made in England on the label. What year and tonnage is your Dunlop? Hope this will inspire some more cleaned and painted jacks.
8bitash, that thing looks heavy, do you have the cup?
May 20, 2017 16:38:38 GMT
From memory its mid 60s, I think its 1.5 ton. Its way down the job list though
820
May 20, 2017 16:39:38 GMT
and yes it does deserve to be lifting heavyweights, its great for cars though
May 31, 2017 22:26:46 GMT
Found this behind a building at work. 6 tonne. Going to see if I can have it. Do you think it's worth having?
Last Edit: May 31, 2017 22:27:27 GMT by pauly22
Like most good things in life it looks like it needs a good grease and pump!
I thought it was drop & wheels If you have the space and need for a jack this size - why not? Doesn't look like it'll be expensive. Cheers, Jan
I thought it was drop & wheels If you have the space and need for a jack this size - why not? Doesn't look like it'll be expensive. Cheers, Jan I would worry about having a need for it, you can never have too many tools
Aug 24, 2017 17:48:42 GMT
Took a trip to Lake Constance today... And since I'm posting this to this thread, you know what I did there. Jepp, you guessed it. I brought home number twelve... Don't know what I'm going to do with this one, I've got so many that need work & attention But it was too cheap to let it go... This was actually offered to me as response for an for-sale advert I posted online. So instead of getting rid of one, I bought another Cheers, Jan
820
Aug 25, 2017 17:04:37 GMT
Take a complete one that needs the least work, get it finished, good clean with minimal dismantling and a coat of paint, one or two days work at the most. Trouble is I was meant to be cleaning mine up for sale to make space in the garage, it looks so good now I am never going to sell it, so there is the danger a restored jack could fuel your habit even more.
I don't think it's possible for Jan's habit to get any more fuelled!
Haha, I'm already looking for more. Sadly I just missed out on a mechanical pre-war jack. That would be the icing on the cake for my collection. I keep looking... I'm fuelled to the brim! I even had a little clear out to make room for more Steinbocks. Cheers, Jan
820
Sept 13, 2017 10:50:36 GMT
Finally got the Dunlop finished, nipples greased, wheels oiled and last few bits painted. Brightened up my garage no end. Now this thread needs a restored Steinbock
Last Edit: Dec 5, 2017 16:42:16 GMT by 820
Sept 15, 2017 5:10:37 GMT
Found this behind a building at work. 6 tonne. Going to see if I can have it. Do you think it's worth having? I think judging by the font on the sticker its an Epco, bigger version of the K40 Well worth repairing, the first time you use it you will be glad you did. Very handy due to the long reach if lifting a 4x4 or van, might not fit under some cars If its free get it even if you give it away so some one else can use it
Sept 25, 2017 8:25:56 GMT
Never realised how cool these can get. I love all things German, I always love the pictures you put up of the places you go @turbodieselweasel
Oct 18, 2017 17:21:53 GMT
Sooo - I have a little little addition to the herd. It's not a Steinbock, but it's pretty old as well. And it isn't even a trolley jack. It's a little mechanical bottle jack. There were a few situations in which I wished I had a bottle jack. Now I have a bottle jack. I was given this by my employer who found it in a shed he'd just bought. Nice! It is made by BLITZ. Blitz was founded in 1872, as a repair company for machines. They soon started production of jacks, air compressors and other garage equipment, mainly hydraulic & pneumatic tools and jacks. And - they are still in business, doing the same thing. I think most of the axle jacks used on 4-pillar lifts & pits in germany are made by Blitz. The axle jack on the 4-pillar lift at work is also made by Blitz, dating to 1972. And still working like a charm. I'm not sure, but they may be one of the oldest garage equipment manufacturers still in existence (if merged with other brands under a mother-comapny, like it is usual today). Anyway, back to the jack: What I like about this; the lifting spindle is fixed, turning the input shaft, you rotate a collar that pushes out the main spindle, which is held in place with a pin (green arrow shows the cut out in the thread used to prevent rotation): Pretty nice little jack that. No clue about it's age, but slotted screws indicate it's pretty old. The handle is missing, sadly. Looks like it had a reteining ball, there's a notch in the square. Lifting capacity is 1200kg. That's all. Cheers, Jan
Oct 18, 2017 18:29:38 GMT
Truly is a thing of beuty..
Oct 20, 2017 11:28:20 GMT
That, I would be happy to own. Lovely.
93fxdl
Enter your message here...
Oct 20, 2017 18:20:56 GMT
