vulgalour
Club RR Member Number: 146
Aug 23, 2017 12:40:47 GMT
It makes sense not to have a folding seat in a saloon if there's a hatchback and estate in the same range, as there is with the R8 Rovers. I'd have to do more research into it but just from the comments made it seems that folding seats in saloons only really started to appear around 1990 and a split folding seat is unusual.
Generally, in the UK at least, it seems you bought a saloon to show you didn't need to use your car for dirty work like tip runs. Hatchbacks used to be looked down on, something you bought because you had to do things yourself, which is silly but that's us Brits for you. The other advantage with a saloon is that unlike a hatch (with the exception of the XM, of course, with its glass divider), the load area is completely separate from the cabin so it keeps the cabin quieter, particularly when compared to an estate car. You also get the bonus that if you need to go in the boot, passengers can stay in the car without the outside world intruding through the open hole in the back of the car.
I'd like to fit a folding seat from an Ambassador to the Princess, but it's rather more involved. The Ambassador was totally re-engineered to accommodate a folding rear seat and tailgate, even the rear inner arch tubs are different.
vulgalour
Aug 24, 2017 15:20:57 GMT
Had a bit of a setback today on the Austin. I finally got myself to a point where I had free time and headspace to get on with the floor replacement and filling in that massive hole and in the process of cleaning things back, found that a good deal of the intermediate sill panel is completely gone on the driver's side. Here's what I mean. 20170824-01 by Angyl Roper, on Flickr 20170824-02 by Angyl Roper, on Flickr 20170824-03 by Angyl Roper, on Flickr The outer sill panel is only attached at the top, there's nothing holding it to the car at the bottom. There's also rot setting in on the outer sill panel. The only remedy here really is full sill replacement and I haven't the money or time for that at the moment. The job I can do is replacing the floor and inner sill portions that need it but before I do that I've still got to address things like the rear subframe mount which isn't actually attached to the car at all because all the bits that hold it on are actually rust and air. 20170824-04 by Angyl Roper, on Flickr This is not what I wanted to discover. Financially, repairing this makes absolutely no sense. Emotionally it doesn't make sense either, I'm not as well invested sentimentally in this car as I am with my others. I know I don't want to scrap it and I know I'll get nothing if I try and sell it so I've decided to mothball the project for the time being. That way I can save up some money, focus on finishing other projects that are eating my spare time and get myself in a healthy position to deal with these problems. It will probably be a few months before I pick this up again and I may dip in and out to do some smaller jobs that don't require more than time investing in them, of which there are quite a few. For now, the little Austin is sat outside huddled for warmth with the other long-termers and eventually I will get around to getting this sorted, or sold on, or whatever. I'm not going to stress about it. Instead I'll focus on the few bits and bobs the Princess and Rover need that I've been putting off in favour of trying to get the bodywork done on the Austin. 20170824-05 by Angyl Roper, on Flickr 20170824-06 by Angyl Roper, on Flickr Mike has been very busy in the background with the Churchill pump and giving it lots of lovely new parts and paint. Just waiting on one fitting arriving in the post before it can be tested. 20170824-07 by Angyl Roper, on Flickr Finally, the spare dashboard (Morris, I think) that came with the Austin is up for grabs should anyone want it. I'm not going to use this so make an offer and it could be yours, sale of that can go into the new sill fund for the 1100. 20170824-08 by Angyl Roper, on Flickr
thebaron
Aug 24, 2017 16:37:50 GMT
Very sensible. I would normally say you should just let it go but as you have space to store it that's secure (and more importantly not outside your door) then all is good.
Aug 26, 2017 18:23:47 GMT
It makes sense not to have a folding seat in a saloon if there's a hatchback and estate in the same range i think its more basic than that, just the pure definition of a hatchback is to have shared cabin and load space.
vulgalour
Aug 27, 2017 17:49:25 GMT
Sunday, a day off, I can do whatever I want... whatever I want... I know, I'll clean the engine bay on the Rover! I'd found a pretty good guide on Youtube last night that I wanted to try out, it's a much better method than I've used in the past for this job and helped tackle what is a fairly messy engine bay pretty easily. All in it took me just under 2 hours which, considering this car is used every day and I think I've lightly cleaned the engine bay once in 2 years didn't seem too bad at all. Here's a before. 20170827-01 by Angyl Roper, on Flickr Here's the after. 20170827-02 by Angyl Roper, on Flickr That's not bad is it? I was just aiming for clean rather than show car so there's some areas that are difficult to get to that could do with a bit deeper a scrub than they got today. There's also still some weird varnishy residue in places which takes ages to shift, I managed to get it off the brake fluid reservoir which was yellow instead of grey, but there's a few spots like here, on the ICV where it just won't budge without a lot of persistant scrubbing. When I got the car the whole top of the engine was covered in this varnish stuff, I don't know if it's just two decades of dirt and oil or if someone actually painted the engine with a quick-shine product or something that's gone funny with heat cycles, but it's been a right old war to get rid of. 20170827-03 by Angyl Roper, on Flickr
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Aug 31, 2017 19:44:40 GMT
I'd love the dashboard but that would just give me an excuse to buy an 1100. 😆
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
vulgalour
Aug 31, 2017 22:34:21 GMT
I'd love the dashboard, it can be the first part of the 1100 puzzle I'm building. 😆 Fixed that for you.
Sept 1, 2017 22:44:00 GMT
^ I have a soft spot for Mk1 Cortinas I got a full set of clocks and gauges from a scrapper, then bought my first Mk1 to fit them into I see no reason why you can't get the 1100 dashboard then get the rest of the car to suit
vulgalour
You can buy nearly every panel new. It'll be exactly like an Airfix kit
You can buy nearly every panel new. It'll be exactly like an Airfix kit Take ages to paint though with those little tins of paint!
The worst part will be the fumes from all that superglue. Probably be more solid than the original though.
Last Edit: Sept 4, 2017 2:16:50 GMT by varelse
Re engine bay cleaning..... I consider this shabby and dirty as there is dust everywhere from 400+ miles It takes a good while to get to a point that it looks brand new. But that Rover engine is much cleaner than it was! I find that the Meguires products are excellent, especially the black restorer. Downside is they are expensive. Positive side is that they go a long way!
Rebel
Have you acquired a merc now?
Peanut butter ( smooth, not crunchy ) is excellent for keeping black plastic looking good. Just a small amount works wonders
1968 Dodge Charger 1985 Chevrolet Camaro 1993 Toyota Hilux Surf 2001 Ford Mondeo
I'm not sure it's the peanut butter, more likely the licking it off that cleans the plastic
Sept 5, 2017 10:43:23 GMT
Peanut butter ( smooth, not crunchy ) is excellent for keeping black plastic looking good. Just a small amount works wonders What's it smell like in a red hot engine bay? I'm just wondering if you wind up the centre of attention to all sorts of things you'd rather you weren't. 😁
Sept 5, 2017 12:27:46 GMT
Peanut butter ( smooth, not crunchy ) is excellent for keeping black plastic looking good. Just a small amount works wonders I would imagine it's the oil in the peanut butter that makes things shiny. Probably be easier to use warmed peanut oil instead. I can't imagine that it would smell nice after a couple of hundred miles either ..... would also leave oily residue on everything using peanut butter. Dirt would stick to it and you run the risk of stinking like the back end of a chippy I would guess.
vulgalour
Sept 5, 2017 13:49:58 GMT
A chippy or the back end of one of our diesels You got a thread up on the Merc anywhere? Was look pretty smart last time I saw it.
Rebel
Its the peanut oil that does the business. You don't need a much of it, used it for a while now. No smell, don't smother the plastic in it, you're not making a sandwich, lol. Just a small amount and polish it off, no adverse effects and black plastic stays black
You got a thread up on the Merc anywhere? Was look pretty smart last time I saw it. Yeah but I'm jiggered if I can link it. I actually have it half arsed up for sale at the minute but I'm not bothered if I end up keeping it
Sept 10, 2017 19:10:54 GMT
I can understand the split/fold rear seat conversion, it was fitted to our 1988 Omega (=Carlton) and despite being a saloon it was very handy and practical sometimes.
