fred
WTF has happened to all the Vennies?
Dec 29, 2014 21:25:15 GMT
Theoretically speaking - shoveling a V12 into a Landrover is insane so 148mph should theoretically speaking pretty sane for the insane ! (This was just a comment - and No kittens or Nuns were killed in the making of such comment)
'79 Cossie ran Cortina - Sold
2000 Fozzer 2.0 turbo snow beast
'85 Opel Manta GSI - Sold
03 A class Mercedes
Looking for a FD Ventora - Anyone?
Dec 30, 2014 11:30:50 GMT
Is the 148mph theoretical for tarmac or mud ??
1994 Mercedes e220 petrol estate, daily driver. 1998 Peugeot 406 Coupe 3.0 v6, shopping car.
moomin
Dec 30, 2014 11:41:20 GMT
Is the 148mph theoretical for tarmac or mud ?? Both I guess, it's based on gear ratio calculations. It'll never see the mud again. Tarmac only with this suspension height.
@toxicknobs
Dec 30, 2014 12:46:37 GMT
I'm sure a bit of 148mph green-laning would be rather quite eye-popping to say the very least...!!!
***GARAGE CURRENTLY EMPTY***
Dec 30, 2014 19:25:53 GMT
that small drive video is audible heaven !
moomin
Jan 11, 2015 19:16:57 GMT
Barely looked at it since last post due to the arrival of my first born! Luckily today I managed to escape the endless nappy changing, feeding and bouncing to pick up this... It's a defender 110 Salisbury rear axle. It's supposedly a straightforward diff swap but we'll see. Also got some replacement HT leads, 8mm jobs. Hopefully clean the running up a bit.
@toxicknobs
skoze
Jan 11, 2015 20:07:00 GMT
Just realised what the axle is for, ignore my message about modifying it!
Just caught up with the progress, this really is fantastic.
Jan 11, 2015 20:39:47 GMT
Barely looked at it since last post due to the arrival of my first born! Congrats! Mine's due next month, and I think I'd be stabbed in my sleep if I attempted a project of this standing whilst she was expecting, lol
moomin
Jan 12, 2015 11:14:33 GMT
Barely looked at it since last post due to the arrival of my first born! Congrats! Mine's due next month, and I think I'd be stabbed in my sleep if I attempted a project of this standing whilst she was expecting, lol Good luck it's pretty mental! Gotta set a precedent early on. Luckily my little man sleeps pretty much 95% of the time at the moment.
@toxicknobs
Smiler
I no longer own anything FWD! Or with less than 6 cylinders, or 2.5ltrs! :)
Jan 12, 2015 15:05:54 GMT
Congratulations! Early precedent is a good idea if you can really get away with it. 95% sleep regime does not sound familiar in the slightest, you lucky lucky bar-staff!
www.Auto-tat.co.uk'96 Range Rover P38 DSE (daily driver) '71 Reliant Scimitar SE5 GTE 3.0ltr Jag V6 Conversion '79 Reliant Scimitar SE6A 3.0ltr 24valve Omega Conversion '85 Escort Cabrio 2.0 Zetec - Sold '91 BMW 525i - Sold '82 Cortina 2.9i Ghia Cosworth - Sold '72 VW Campervan - Sold '65 LandRover 88" - Sold
Jan 12, 2015 22:37:53 GMT
I would just like to point out that this is amazing. Brilliant work!!!!
moomin
Jan 14, 2015 16:04:42 GMT
Slipped out for an hour this afternoon. First job swap the leads out... Nice 8mm jobs. Definitely needed as I think these ones might well be older than me... Onto the diff swap. Cleaned the defender casing up a bit then removed the cover plate. Closer inspection shows very little wear and no teeth damage. Then just enough time to pull the half shafts out and again no damage. They match the current ones which is a bonus as I wasn't sure they would.
@toxicknobs
Jan 14, 2015 22:36:36 GMT
You need a case spreader to get the diff out of the Sailsbury cases. Nice job so far.
Last Edit: Jan 14, 2015 22:38:05 GMT by neilios
moomin
Jan 15, 2015 11:06:33 GMT
You need a case spreader to get the diff out of the Sailsbury cases. Nice job so far. I know, find one is an issue! Probably going to have to make one.
@toxicknobs
Jan 15, 2015 11:19:18 GMT
could you elaborate on case spreader ? is it to widen the 'ole by stretching the metal (not so much that it permenantly deforms of course) so that diff+bearing will actually fit through ?
if yes to the above is it only the stress of the diff housing which pre-loads the bearings, or is there castellated adjustment ?
Jan 15, 2015 12:39:38 GMT
They match the current ones which is a bonus as I wasn't sure they would. the series/defender ones are the same?
Jan 15, 2015 12:44:37 GMT
don't need a diff spreader. a huge G Clamp at 90degrees to where the spreader would sit and squeeze the casing. it does exactly the same job as the spreader would do by distorting the case enough to get the diff in and out with a small amount of preload when released.
moomin
Jan 15, 2015 13:13:35 GMT
They match the current ones which is a bonus as I wasn't sure they would. the series/defender ones are the same? Wasn't sure if they be 10 spline or 24 spline.
@toxicknobs
Jan 15, 2015 16:22:28 GMT
Ah! got ya.
