edk83
May 20, 2020 21:32:36 GMT
Man this thing's going to be mental! Not that it isn't already Could you go for a sightly longer intercooler and flip it around so the pipes go directly back through the foglight holes? Or was that the plan alreadY? Yes the actual one I use would be slightly bigger and yes the pipes would go through the fog lights and inner wings. Mg6 intercooler I just had knocking about to offer up
edk83
May 20, 2020 21:37:45 GMT
I've just got the trailer brakes bringing the allegro high level one on, works well.
Yeah I'll have to check the exact measurements and find a cooler as close as possible. Probably one with straight pipes rather than 90 degree, that way I can adjust the 90 degrees exactly into the fog light openings
May 21, 2020 18:33:57 GMT
it "feels" like a normally aspirated car though. i'm at odds!
edk83
May 22, 2020 13:39:30 GMT
Me too! The turbo engine is being built either way, if not in the Allegro it's going in this, yes I needed milk during lockdown!
vertex
May 22, 2020 15:38:38 GMT
Apologies if this is a re post
edk83
I've been measuring and it'll fit in the Allegro engine bay...
Jun 12, 2020 13:19:28 GMT
Now isn't that a thing of beauty!
Honestly I've got a real soft spot for Allegros. Not one of the 'my gran used to have one' soft spots, but a genuine 'I think they look really good with a few modifications' soft spot.
Probably helps that I'm too young to have seen them in service on the road...
edk83
My Dad hates them, he said he was always stuck behind one driven by an old man wearing a hat! That's when I knew I had to get one! Smurf it Sunday! Only one place this engine is heading now 350hp Allegro
Last Edit: Jun 15, 2020 8:45:18 GMT by edk83
Jun 15, 2020 10:19:18 GMT
This is funny in the most awesome of ways.
edk83
Jun 19, 2020 13:40:54 GMT
Heater pipe adjusted I'll have a sensor rail in the top pipe, will be monitoring coolant temp and pressure (for head lift, its still a K series lol) Maybe have another sensor after the stat or after the rad to measure effectiveness
edk83
Custom fuel rail done, stainless mg6 one with stainless an6 connectors and a 3bar reg. Siemens 620cc injectors
edk83
Custom inlet manifold done, needed to move the tb to the other end for pipe routing and other things.
edk83
Painted in the proper colour with a larger tb.
edk83
Had to alter the block to accept a pulse sensor rather than a hall sensor that the mg6 used. P38 range rover one fits well and was able to reuse the mounting point rather than redrill and tap a new one
edk83
China turbo wastegate port much too small Fixed
Hell yeah Interesting about the cheapy turbo's wastegate being way too small. Must remind myself to check that if I ever get one!
edk83
Yeah that would suffer from boost creep, also I want to be able to lower the boost in low gears.
edk83
edk83
Aug 24, 2020 12:31:38 GMT
Coolant pipe reroute, factory one ran straight into the turbo Also started making turbo support brackets
