Mar 29, 2016 17:55:40 GMT
Got a fair bit of drawing done yesterday and a couple more bits pretty much finished. Needed a 35mm shaft with the end turned down to 25mm ,but with it offset by 5mm from centre. Not a problem,but I don't have a four jaw chuck for the cnc lathe. So, a bit of workings out,and it's all tickety boo with a three jaw chuck. These cnc power chucks have serrated jaws,the pitch of which is 1.5mm. So, easy like a Sunday morning. Set the jaws to clamp a 40mm dia piece,tighten two jaws. Move the third jaw in 5 serrations ,(7,5mm), and then a clamp a 35mm bar in it. Tell the lathe your bar size is 45mm. Press go and stand back.... Job done. Love it when a plan works out..
mk2cossie
Club RR Member Number: 77
Mar 29, 2016 18:45:01 GMT
Very nice too So does that mean the triple wankel is officially under way now then? The porting job looks amazing from a week ago
Mar 29, 2016 18:56:21 GMT
This is for the magical mystery tool! I figured out how to make the triple rotor eccentric shaft about two years ago and made a dummy/ test one up to see if I could handle the machining. Want to get. Body work finished before I do any more engine work. It's just too much of a distraction,hahaha. Did buy in the proper material for the shaft last month though.... This was development work on the shaft
Darkspeed
Club RR Member Number: 39
Tube bender?
A couple more bits done for the growing pile that is still,referred to as the MMT ,( magical mystery tool) Decided whilst that first eccentric shaft would do the job,version two would be better. With added throw.... Roughing out in the mill Roughing out complete,just needs to be finished .25mm throw as opposed to the 5mm throw on the first one
Seeing I had arranged to meet somebody who lives closer to work than home,I stayed on a bit as it was pointless to drive home,only to drive all the way back a couple of hours later. So, bit of skip diving yielded this,an old positioning plate. I will have a bit of that. Cleft a bit off and into the mill to add some lightness Added lightness and sexy curves to both sides before standing on head. It's head,not mine... Back in to finish off curvy goodliness....
Speaking of curvy goodliness,Mrs Bravo has been making some hints that I need to get in shape. Not quite certain what part she doesnt quite get. Keep on reminding her that round is a shape. Doesn't want to have it either,that I have a body of a God. Well, Buddah is a God, is he not ? Any way ,I heeded her well meaning advice and got me a new toy. Seeing I really don't see the point of paying over the top for something I don't really want and doubt I will use that much, I found this not so little gem on the bay of Flea.... Made by Keith Black's cousin Roger, who now lives in China. Not so sure about me being the only thing needing to lose a few kilo's , this thing is right porky too.....Going to have a little play tonight......
Last Edit: Mar 31, 2016 3:32:13 GMT by Deleted
Got to admit I don't have a bloody clue as to what you are doing, but I'm seriously absorbed in whatever it is!
johnl
Got to admit I don't have a bloody clue as to what you are doing, but I'm seriously absorbed in whatever it is! He's making an engine e shaft while running on the running machine.
Wilk
Got to admit I don't have a bloody clue as to what you are doing, but I'm seriously absorbed in whatever it is! He's making an engine e shaft while running on the running machine. And he's probably running the mill at the same time from a smart phone app he's just written
But what is the treadmill powering??
But what is the treadmill powering?? He's using it as a belt sander at the moment.
mk2cossie
Mar 31, 2016 12:22:05 GMT
lovely work on the MMT there, although I have absolutely no idea what it is Tis very handy having a nearby scrap pile to raid for pieces as well!
Mar 31, 2016 16:00:29 GMT
lol what happened to roger black ? locked in kris akabusi's shed i reckon
Mar 31, 2016 16:08:20 GMT
Finished machining the end of the e shaft Cross hole time Bit of a shaft and a knob That bit done
Mar 31, 2016 16:10:31 GMT
And in other news,this turned up. Love properly wrapped parcels. Makes I smile.... Another piece of the puzzle....
Mar 31, 2016 16:15:17 GMT
Oh, well, it's obvious now that you're making a tamping wopple for a Keyley trunnion - after all, what else could it be?
Mar 31, 2016 16:38:53 GMT
Oh, well, it's obvious now that you're making a tamping wopple for a Keyley trunnion - after all, what else could it be? Metric or imperial though? ........
Mar 31, 2016 16:59:21 GMT
Metric....with four pieces measured in twelfty thirds.....
Mar 31, 2016 18:41:03 GMT
ooh a Broach, nice and a few quids worth!
