The lack of useable parts from so many engines seems to paint a woeful picture of their durability .... is that right ?! It can’t just be bad luck, surely !? Actually not. Apart from the one that had been run lean and detonated, all the rest would have continued to run. A rotary engine can be more shagged than a piston engine and still run well. The problem is putting new seals up against a worn housing, you cannot get the seals to bed in properly. Out of 8 housings there are three that I would consider using again. If it was just a drift or skid car , I would say only two housings out of the 8 are not worth the effort. With the rotors, five are useable, two have hammered the seals out due to detonation and running lean, and one has had water jacket seal failure and is rusted solid. Could probably get the seals out but not worth the effort.
Last Edit: Jul 5, 2020 20:34:58 GMT by Deleted
Thanks Johnny - I was worried there for a bit!
Workshop renovation continues. Painting of floors and fitting of lights nearly complete. Moved the big 5axis cnc lathe yesterday. Pretty uneventful considering it weighs 7,5 tons. House Elf couldn’t believe it when I initially moved it away from the wall with no levers or winches 🤣🤣🤣. Much easier to push with the little forklift though once I could get in with it though 😊 Need to paint the walls where that was standing and second coat the floor. Then over the weekend move the small cnc lathe down that end. All ready for the cnc mill being delivered on Monday 😊
teaboy
Make tea, not war.
Jul 16, 2020 21:34:58 GMT
That little forklift thing was a real godsend.
That little forklift thing was a real godsend. Best £250 I ever spent. 🤣🤣 All it needed was a resistor soldering back onto the board in the charger.
Jul 25, 2020 16:28:47 GMT
Wilk
Jul 25, 2020 16:43:56 GMT
There’s something satisfying about cleaning up either old or dirty items so they look like new again
mk2cossie
Club RR Member Number: 77
Jul 25, 2020 16:52:02 GMT
@johnnybravo if that is a MINI MILL, how big is one that isn't mini
Jul 25, 2020 17:03:33 GMT
@johnnybravo if that is a MINI MILL, how big is one that isn't mini The size of the one I normally use ....🤣
mk2cossie
Jul 25, 2020 17:41:30 GMT
@johnnybravo if that is a MINI MILL, how big is one that isn't mini The size of the one I normally use ....🤣 Is it big enough to make some plates for a differential?
Jul 25, 2020 19:02:49 GMT
It will do 400mm x500mm x 600mm high
mk2cossie
Jul 25, 2020 19:07:31 GMT
It will do 400mm x500mm x 600mm high I may require your expertise in that case. Providing the unit turns up and you're OK with my plans?
Jul 25, 2020 23:50:35 GMT
I know what you mean about working on dirty machines. Used to be regularly wiping mine down but then would go onto other machines and could barely see the controls for all the swarf on them. Usually dirty roughers it has to be said.
I love keeping my lathe clean. Doesn't make it any less noisy or more accurate but it makes it nicer to use. Plus it will last longer.
Very true. But it does also keep it more reliable because you find things like screw coming loose before they actually fall out . I must have tightened four of five screws yesterday. What I also found,which I wasn’t aware of,is this mill had the optional through the spindle coolant system fitted when new. A very useful option that would have stuck £5k on the original bill. It was a very nice surprise from an otherwise very monotonous day 🤣
Jul 26, 2020 15:48:57 GMT
It’s slowly getting cleaner 😊
v8ian
Jul 26, 2020 16:15:37 GMT
Spindle coolant, nice thing to find, and its white on top too
v8ian
Jul 26, 2020 16:16:13 GMT
Last Edit: Jul 26, 2020 16:16:48 GMT by v8ian
jpsmit
Jul 31, 2020 13:25:43 GMT
