Nice easy night... The dogleg panel responded nicely to a short conversation with a piece of hardwood and a mini sledge. The gap is gone and the lines match. Bit of John Deere green paint to protect the bits that won't be seen and I am ready to weld it on for good. But not tonight. Not hearing the welding Muse, so a pint of Stella and a good sweep-up will do.
Jun 15, 2016 11:14:53 GMT
Got the dogleg welded in and ground down. Lets call this done and off the to-do list. Before: After:
eurogranada
Jun 15, 2016 11:46:47 GMT
A tribute to your craftsmanship!
Jun 15, 2016 14:56:30 GMT
well done!...step by step, inch by inch!
JP
Jun 15, 2016 15:05:22 GMT
well done!...step by step, inch by inch! JP
Jun 23, 2016 22:54:11 GMT
It's a roller !
Jun 24, 2016 20:36:27 GMT
Pics!
14 Audi A3 Sportback - Easy driver 05 Audi TT MK1 3.2 DSG - Damn quick 73 Triumph 2000 - Needs work 03 Range Rover 4.4 V8 petrol. Had to get it out of my system.
Ask and thou shalt receive... Have had three straight days to work on the car. I need to have it on its wheels so that I can roll it off the frame jig and put another project up there. The car is sitting on the suspension supported by threaded rod to establish the ride height. The good news is that with the rods adjusted symmetrically side to side, the ride height is 7" along the pinch weld just as I calculated. 1" up or down is easily achieved without compromising the geometry. The front end is jut dropped in place. Needs to be properly fitted at the front so that the front drops another half inch. The rear is more indicative of the tire to arch fit at this point. Plenty of room for the accessory giblets
Thats better! Looks absolutely great. Always admired these cars and the work you have done to this to bring it back and upgrade it is amazing. Keep at it and don't let the other project going on the spit take up too much of your time.
Better view. On the ground for the first time in 3 years.
Last Edit: Jul 3, 2016 23:02:24 GMT by bjornagn
coruas
Better view. On the ground for the first time in 3 years. Amazing. Can't wait to see it finished
vulgalour
Club RR Member Number: 146
You can't tell you've done anything now it's on the ground
You can't tell you've done anything now it's on the ground Thanks! That is the point of this whole project. Going to try two things when it is done. #1 Attend a Classic Volvo meet and see how long I can fly under the radar #2 Attend a Miata meet and see if they let me on the show field.
glenanderson
Club RR Member Number: 64
You can't tell you've done anything now it's on the ground Thanks! That is the point of this whole project. Going to try two things when it is done. #1 Attend a Classic Volvo meet and see how long I can fly under the radar #2 Attend a Miata meet and see if they let me on the show field. Brilliant. Just brilliant. It looks just right. If if you weren't so far away I'd like to be a fly on the wall at those two meets!
vulgalour
It's got to be tempting to get some steels in the same size and offset as the eventual wheel choice that'll accept the Volvo hubcaps for maximum sleeper points. Possibly a set of Miata alloys too just to confuse people.
Last Edit: Jul 9, 2016 14:43:48 GMT by bjornagn
Might need a pretty aggressive cutting compound for that one.
Jul 11, 2016 12:05:28 GMT
Nah, a few gobs of filler and it will be fine.
Aug 12, 2016 20:56:31 GMT
See, I ain't dead yet! And even when I am not working on the Molvo, I am still on the case. The good news is that I found a header that will clear the steering column. The bad news is that it is seriously ugly and I don't know what it is from. Hopefully the tag on the front tube contains some information. If I can identify what car they are for, I might be able to locate cast manifolds which I would prefer anyways. Regardless, good to have another build challenge retired in principle. I thought I was going to be building a header.
Aug 12, 2016 21:02:46 GMT
loving that steering column mod!!
(i know it's a mock-up but couldn't help cracking the joke)
