Mar 21, 2023 11:20:51 GMT
Soldered the rear wiper relay, Seems to work, I looked at aralditing it but then realised the case had a feature moulded into it to support the board but the case didn't clip tightly to the base, a tie strap seemed to be the simplest solution. Managed to move the relays around so they all clipped in easier, then decided to fix something else the rear wiper switch is loose in the column shroud, the edges of the shroud were broken (all the plasics on these are a bit naff). Decided to add a alloy plate crimped and epoxied around the edges of the original hole. When the epoxy has dried I'll clean it up and paint it grey.
Last Edit: Mar 21, 2023 11:22:44 GMT by kevins
Mar 23, 2023 20:11:38 GMT
Painted the repair on the column shroud, Colours a bit light but it will do for now and the switch is secure. It's all back together and everything still works ok. Used the TR for work on wednesday, and had a few issues, the main one was a flat battery, basic problem is it's well past it's sell by date one thing I can't put up with is poor starting, so I splashed out £90 on a new 600CCA Bosch one. Other issue is it's a bit lumpy on light throttle, It was fine but very rich at idle and stunk, I set it up so the idle mixture is around 3% and now it's fine at idle but a bit fluffy at very light throttle. (Pulls like a train at higher load though). There's oil in the dashpots and it recently had new jets so I'll dig out the flow meter and check the balance, if that's OK I suspect it needs some BAF needles others seem to have had similar problems with the std BAK ones when using freer flowing induction and exhaust.
Apr 10, 2023 20:47:51 GMT
Been busy on diy projects so not much time for cars lately, had to adjust the hardtop on the streetka, the front was about 4mm off centre making one door difficult to open an the other window noisy, just a matter of loosening the latch bolts pushing it across and tightening them up again, also fixed the 12v power socket, the fuse had blown! Still need to sort the wiring for the heated window at some point and a storage box for when the hardtop is off.
The TR failed to start, the battery has been flakey for ages so I splashed out £90 on a new one, starting seems fine now.
Took the Lotus out for it's first run this year today, started straight away and drives as well as ever, needs a wash and the paint I did a year ago polishing I will then use it as much as possible.
Range rover is being used a a Builders van, do need to do a few jobs on it this summer though, changing the fuel lines and going over some surface rust on the chassis being the main issues.
Son bought the Minor home to fit the gearbox as he is getting towards the end of his finals, noticed a few other problems too, the dodgy handbrake was obvious, one of the abutments has come away from the floor, both rear wheels ends on the axle are leaking (doesen't get on brakes thankfully) probably needs speedi sleeves on the axle where the seals run and it has a few surface rust spots from knocks and chips.
Mx5 also needs a good service and a few bits of bodywork, nothing serious, dodgy paint on the bonnet and a few bits of rust on the front wings but that can wait, might even buy new ones.
MiataMark
Club RR Member Number: 29
Mx5 also needs a good service and a few bits of bodywork, nothing serious, dodgy paint on the bonnet and a few bits of rust on the front wings but that can wait, might even buy new ones. I bought new wings from Moss, (look out for their discounts), the body shop said they were good quality.
pptom
Apr 11, 2023 11:34:16 GMT
I put a new genuine Mazda one on the wife's mx5, surprised they still make them. She was paying and I didn't want to be mucking about trying to get an aftermarket one to fit, not my best skill. Plonked in like a charm, no tweaking required. Think it was about £150? From mx5parts although I probably should have checked if a local dealer could get them and saved worryingly about postage damage. Mazda seem quite unique in supplying new parts for a 30 year old model.
Apr 11, 2023 11:48:59 GMT
yes mazda are amazing and the parts are not ridiculously expensive either, the wings are a bit crusty at the rear towards the bottom from stone pecking (not holes buy probably could be if I prodded hard enough) one has already been repaired where they joint the bumper and the other is bubbling and both have been dinged and repaired over the years, It might be time to cut my losses and fit new ones.
pptom
Apr 11, 2023 13:12:00 GMT
One tip i picked up from the forums at the time was about the mud + road dirt packing up between the sills and wings which causes them to rot. I also had to patch the sill here The advice was to space the wing out slightly at the bottom, think I just used washers. It's not noticeable, but gives a bigger gap which you can fire a hose / pressure washer in and a bigger route for the rubbish to fall out of.
Last Edit: Apr 11, 2023 13:12:40 GMT by pptom
Apr 11, 2023 13:16:57 GMT
Yes I unbolt the bottom of the wing, remove the plastic liner and clean it out and wax in there every year or 2, problem is the scuttle drains into there so it's always damp.
Apr 11, 2023 18:29:38 GMT
Some pics from the minor, reason there is excess handbrake travel. Oil weeping at axle wheelends. Spent about 45 minutes on it, result, Gearbox out. On the bench ready to remove the clutch actuation. Also drilled a drain plug, fitted a magnet which is epoxied and peened in place. Other things we have found, the rear propshaft UJ is virtually seized (good candidate for the driveline vibration) there is a fair bit of oil in the clutch housing which looks like it is coming out of the gearbox and the clutch cover fingers don't seem centred, so a new clutch and uj's should be about it for now, I'll monitor the axle to see how it goes.
Apr 11, 2023 20:53:30 GMT
Wow, you removed a Minor gearbox in 45 minutes? That's good going! I had to change the head gasket on my 2008 Abarth Grande Punto Esseesse this weekend, and removed the o/s/f wheelarch liner to change the cambelt, etc., and was surprised at the amount of mud and some rust that had developed behind the bottom rear of the front wing, all hidden, of course, by the sill skirt and arch liner.
I'm lucky enough to have a 4 post lift so most of it was done sitting on a bar stool, also have done it a few times now.
process I use is:
-Undo drain plug, while that is draining remove prop -From inside remove 3 gearstick and 4 crossmember bolts -From engine compartment remove battery negative, starter wire, top 5 engine to box bolts and top starter bolt -from underneath support engine under sump on jacking beam, -remove clutch rod clevis and line from reservoir, gearbox mount bolts and 4 remaining crossmember bolts, lower the back of the engine(we don't have heater tap to worry about). -then undo bottom starter bolt and pull it forward, undo the remaining 3 engine to box bolts twist the box 90 degrees clockwise and leave you able assistant to catch the gearbox (my son).
while I am waiting for the parts I'm going to carry out an autopsy on the old box, will also give me a input shaft to use to align the clutch.
Apr 12, 2023 12:55:34 GMT
Pulled the gearbox appart at lunchtime, a few issues but nothing dramatic. Lay shaft badly worn. 1st gear in a terrible state. And no shims fitted to clamp the front and rear bearings which would havecallowed them to move in the case, quite a bit of wear on the front circlip too. Otherwise the main bearings felt fine 1st on the mainshaft was past it's best but servicable and the reverse idler was pretty good with just one chipped tooth.
Apr 14, 2023 21:29:24 GMT
Spent a couple of hours on thd minor, firstly swapped the gearbox mounts over then started changing the front cover and concentric slave mount over, turns out I need a 6 thou shim and I only have 4 or 8 thou ones so that put an end to that, Started on the prop pressed the seized uj out, which was seized solid, eventualy got it out using heat. Pressed the new one in, forgot to take the grease nipple out and snapped that off, fortunately the remains unscrewed so just a matter of getting a replacement, still need to do the other end which also looks pretty tightly in there to.
Clutch etc is here now but i'll have to wait for the shim to arrive to put it back together, hopefully get it all done one evening next week.
Apr 16, 2023 20:11:32 GMT
Shim arrived yesterday but I had already agreed to spend most of the day doing other things so only a hour or so on the minor today, fitted the front prop uj but struck a problem on the rear one, it was seized solid and very rusted, after I had pressed in out and cleaned all the rust out of the flanged yoke I found the new bearing cap could be pushed in and out with finger pressure, I have put it back together with some bearing lock but I'm not really happy with it. I've now found Moss do a new rear flange / yoke for £19 so that and a new U/J are on the way. The offending one is fairly obvious.
Last Edit: Apr 16, 2023 20:13:08 GMT by kevins
Apr 16, 2023 21:19:16 GMT
They can be right swines to remove and replace, those UJs. Been there with the bearing fit stuff myself to try to get the cups to remain in place!
Apr 17, 2023 13:12:04 GMT
yes I've done plenty of land rover an ford ones over the years these were the worst ones, as only one was really rusty my guess is it stood in long grass or something similar for a long time.
Apr 19, 2023 20:45:20 GMT
Slow progress before work and at lunchtime, new prop flange fitted. Front cover and clutch actuation all fitted to the new box. Also gave the mazda a wash and polish, we are going away for a few days in it at the weekend, while it's far from perfect it certainly improved it's appearance.
Apr 20, 2023 12:21:55 GMT
Do you find the concentric slave conversion gives much improvement over the conventional Midget type exterior slave?
Apr 20, 2023 13:18:28 GMT
It's certainly far better than the minor mechanical set up, I've not tried the midget set up though, with the concentric slave and minor clutch it's very light and progressive hydraulic Also means I don't need the restaining cable or torque reaction rod as it can move around on the mounts far more.
Apr 20, 2023 20:37:04 GMT
I currently have the 'regular' Midget external slave cylinder on my Traveller (with 1275 Midget engine & gearbox), and it works pretty well, though the slave cylinders do tend to need replacement every so often, as they start to weep fluid, etc.
