foxy99
Jul 22, 2024 12:49:08 GMT
Thanks jimiSo that's the 'slam-panel' of the bonnet finished. Well it's 90% finished. All the shape has been formed but it needs a bit of 'joining the dots' with the welding. I was getting a bit fed up with the pernicketiness of it so treated myself to a change of activity and cleaned all the rust off with wizzy-wheel and got some etch-primer on it. Next thing to do was obviously start repairing the shell of the bonnet. Well the bonnet I guess you'd call it. This will be visible so I want to get the welds as invisible as possible and was stressing about how to form the curves going two ways. Well it turned out great. Bit miffed about blowing a couple of holes, as I didn't cut back far enough to sound metal in the bits I repaired yesterday, but the shape is good. As you may see from the earlier pics this bonnet was originally a darkish metallic blue and was sprayed in a light non-metallic blue in the 80s I reckon. The bonnet has quite a few small dents in it as well as the corrosion at the front and the dents have all been filled and sanded to quite a high standard but I only noticed yesterday, when sanding back the paint, that the repairs were re-painted in the original colour (looks like a perfect match). This kind of repair would be unusual on a car towards the end of its life back in the 70s or 80s so I reckon the bonnet had already rusted out at the front when the car was still quite new. The primerless blow-over in a non-original colour is much more typical of the time I think 90% done and ready for some paint now to repair the bonnet proper quite a few holes here sanding shows these holes were repaired before and bonnet re-sprayed in proper colour before it got the light blue paint in later years cutting out holed part on corner new bit welded in similar-sized hole on LH edge sorted but may do it again with bigger patch
foxy99
Jul 23, 2024 11:10:45 GMT
So I did a bit more on the bonnet yesterday. Actually have only got one more patch to do and then it's time for cosmetics. Have found there are several dents that were filled pretty well but I'm taking the filler out and will remove the dents. It won't be difficult. Once this last patch is done I'll need to fill in the gaps on a lot of the welding on the slam-panel part and then find best/easiest way to clean the bonnet before painting. Am thinking electrolysis in a big shallow thing - like a paddling pool - or I'll make another box. Or mb just paint over the rust. It'll come back no matter what I do But yeah I impressed myself with last patch I did on the front of the bonnet. It has a bit of a profile in it and I even included the return lip which I didn't plan to do. Problem with that is you end up having to loose quite a bit of metal at the outside corner. I can't shrink it away so it'll need to be cut and welded which defeats the point of trying to do it all from one piece of metal. Ran out of welding gas so the welds aren't complete but will get some more today slam-panel with some etch-primer on still need to joint the dots flash off makes the gaps very clear corroded piece cut out of front edge new patch includes return flange. need to loose metal at outside corner shape of patch turned out pretty good
Last Edit: Jul 24, 2024 0:34:48 GMT by foxy99
foxy99
Jul 25, 2024 11:55:11 GMT
I should really be finishing the bonnet but yesterday I dug-out the rear crossmember thing. Most cars don't have these but, as the Imp is rear-engined, it has a detachable panel between the rear 'chassis-rails'. It's quite a robust, double-skinned affair with various bits spot-welded to it. On part is like a turret which supports the end of the engine via large rubber bush. Anyway. As well as some corrosion mine has a dent in the middle and years and years ago I thought I would simply separate the two skins, by drilling out all the spot-welds, remove the dent, fix the rusty bits and weld it back together. For whatever reason this didn't happen. All I did was drill out a lot of the spots but not all of them. Bringing the part down for the attic in the barn yesterday you can see it has rusted up nicely on the flanges which were, presumably, sanded to help locate the spots. So last night I set about removing all the non-original paint. This is the last part of the car which still has the black cellulose re-spray on it (from some time in the 80s afaik). I scraped it all off the rest of the car decades ago so it seemed like a good idea to finish it off. I may have said before but I am quite seriously considering keeping all the original paint and just try to blow-in the repairs in as close as possible a match to the old. So I got most of it off and today will tackle the primer. The thin coat of black was relatively easy to remove but whoever sprayed it seems to have went on a lot heavier with the primer. Well in some places anyway... It's weird after all these years to be able to'see' what they did. This panel was obviously quite low down on the car and has very little paint on the bottom but loads in the curved part on top. The guy obviously cba lying under the car or jacking it up to get to the hidden bits. Also interesting was to find the HILLMAN script appearing in the primer. I'd forgotten the car would have had a metal badge there and there was no evidence of it in the black paint but it's clearly there in the primer. So that suggests it was primed with the badge still on then the badge came off before the black went on. We may never know. I did meet the guy who painted the Imp black, back in 1992, and he told me a story about driving in to the back of it on his motorbike and landing in the pick-up bed and asked if there was still a dent in the bumper (which there is) but the rear-panel is also dented - as you can see in pics. I was initially thinking the bump must have caused the badge to crack and fall off but then there would have been a 'ghost' HILLMAN on the black. Imp rear-panel exhumed from attic (front) back dent in middle spotwelds separated on lower edge and at jacking-point rusty top edge and undrilled spots black paint scraped off HILLMAN in primer repair needed at this corner did collision take place before or after the re-spray
remmoc
Jul 25, 2024 18:07:22 GMT
Cotton tape or glass fibre tape is fine , thin as possible as coils are quite tight on the shoes . Before retaping we wash the coils in a parts washer then cook them in an oven at 100˚C for a few hours to dry them , coating on the wires quite tough but try not to scratch it up . once taped the coils will need varnishing and cooking , this is done once the coils are back in the pot . there should be an insulation sheet between the coils and pot but not between the pot and pole shoes . Pole shoes can also be washed and cooked to dry
foxy99
Last Edit: Jul 29, 2024 11:00:07 GMT by foxy99
foxy99
So I had a better look at the 2nd dynamo. It was £10, plus £11 postage. I won't go into the stripping-down procedure, as it's exact same as last one, but it's all apart and the case has been cleaned and painted already. This in another 22715K version of the C40 but from week 18 1972 - so a little later than the last one. You'd expect the parts to be identical to the previous one but, as I said, that has a mismatch of parts so I expected this one to be quite different. This one seems to be more 'correct' but there are a couple of issues.... The 'stack teeth' on the armature are pretty rusty so I couldn't make-out any stamping and even after quite a bit of cleaning I couldn't find anything. It looks almost identical to the other one apart from a very slight difference in the length of some bits below the commutator which won't affect it's function but it looks like there is no date on it. The drive-end bracket is the type with an integral bearing (not employing a bracket to hold it in) but unfortunately the casting number is basically illegible. It seems to start with a 5 so at least follows the right format of the numbers given in the Lucas catalogue but I don't think I'll be able to decipher it. The commutator-end bracket has the exact same number cast on to it as before and it seems unlikely that on both units they would be the same but wrong. I had another look online and found a NOS bracket with part-number 54211125 on its box but the number cast on it is 54210104. This is the number on both of my brackets so I'm saying I have two 54211125 brackets despite what the casting shows. Actually this was quite common with Rootes themselves. The number cast on the part was not the part-number. It seems that with Lucas most of the time it is but sometimes it isn't. Clear as mud. So back to the condition of the unit.... There is no oil in this at all but it seems a lot more rusty inside. I'm not too bothered about this as all that business about ashing and drying the windings seemed like a right hassle. The bandages on these ones looked good at first glance but they are a bit frail. I think I'll need to take the plunge and buy some of the special tape and rewind at least one pair of coils. When I first glanced inside this one the brushes looked long and I wondered if it was even worth disturbing the commutator end but I noticed that one brush wasn't out as much as the other and, sure enough, there's a broken spring in there. It was at this point I took it fully apart. I've cleaned the corrosion off the poles and the inside of the body/yoke/pot and, as I said before have cleaned and painted it. I haven't removed the drive-end bracket from the armature as the bearing feels really good. The sensible thing to do would be to use the good armature from the first one with the proper drive-end bracket and dry coils from this one and the pulley and fan from the first one. These were absent on the latest one. In other news I found the band for the starter. been looking for it high & low for a week or so then was looking at my engine-crane for some reason (which I pass every day) and it was hanging from the end of that I could have did electrolysis or some sort of acid-cleaning but, to put it mildly, am at the end of my tether with rust and and getting to the stage where I'm thinking 'fk it. if it looks good for a the first time you use the cursed thing that'll do' so just wire-wheeled it and it's now had the same paint as the dynamo body. another Lucas C40 dynamo (£10 plus £11 P&P) 22715K from 1972 drive-end bracket removed c/w armature this one doesn't have the plate retaining the bearing can't read the numbers on the casting stack is rusty and can't find any stamping on it commutator looks fine brushes looked odd brush-spring doesn't look right tape on coils looks a lot better than previous unit unit is dry inside (no oil) but quite rusty same commutator-end bracket casting-number anomaly as last one bandages didn't look as good once coils removed from body comparing first armature (orange) with latest one (purple) commutators are same length but there is slight difference where wires join on body etch-primed followed by normal primer then a light mist of topcoat found - one rather rusty starter-motor 'cover band' cleaned? etch-primed
foxy99
Jul 30, 2024 12:01:23 GMT
The other day I spent basically the whole day removing all the primer from the rear panel then polishing-up the old paint. Can't seem to capture it properly in pics but it looks amazing. Even where it goes thru to the red-oxide primer and bare metal it looks amazing. I would luv to keep the original paint like this but in this fkn country it would rust-up in a day I'm not as keen on the parts where the original paint was either worn, nicked or rubbed too thin that the whitish Rootes primer/undercoat shows thru but, hey, it's still original. To remove the primer I used a combination of scraping with a chisel; sanding with 1500 wet 'n' dry; Farecla G3; T-cut. They all had their good and bad points but bottom-line was the paint under looked like new. IE fk all like the stuff I got from Claytons Auto Stores NI. That brings me to my next point. I ended up having an argument with those arseholes and still don't have an answer.... Going back a year when I bought the 'Direct Shire' paint and the woman on Ebay (Jolene Clayton) was fobbing me off with any old curse word whenever I asked her for details on what they were selling I thought I would contact the company direct and on their website there is a Chat service. Excellent. I sent them a clear message with pics, then another and got no reply. I then emailed them at the address on their website. No reply. I then phoned them and just got a lot of 'umbrage'. The woman on the phone kept giving me warnings and put the phone down. She wasn't happy that I wasn't impressed by her total confusion about the Chat function on their website and then proudly explained when the penny dropped that they don't use that to which I replied well what's the point of having it you should remove it which resulted in another warning. When I called back a guy answered and we couldn't get past 'what colour is it?' (which I'd already explained to the woman only to be met with more bewilderment). He couldn't understand what I was saying and kept saying 'give me a minute' then asking her for advice. i was getting rather curse word off by this time and was told to 'cool my jets' and had phone slammed down again. Called back, got the woman again. More warnings and I asked her if they'd ever heard of customer service and she kept saying she would help me if whatever and I said 'well can you hurry up then' so phone slammed down again. Complete curse word arseholes. All I was asking was 'is your direct shine range basecoat or gloss?' I then tried the Ebay seller again and explained for the umpteenth time what I wanted to know and she replied that they only do my colour in gloss. Anyway. I've given up on them now as it was boiling my curse word and have found another Ebay seller selling the colour who assures me it's 1K gloss. We shall see. So, back to the panel. I set about drilling out the rest of the spotwelds with an expensive 8mm flat cobalt spot-weld bit and stopped after the first one. Totally pointless as the idea is to remove the weld from one panel whilst leaving the one under it completely untouched but this bit has like a 4mm centre section which goes right thru both panels. I just swapped to a normal 6mm bit and found that was big enough the remove the spots and do less damage to the panel below. Things didn't go very well the first day. I've had this problem before (on my Daimler) where you find the dent and drill into it but the weld is actually over to the side so you need to do it gain and end up with 2 holes in the same place. I was seriously considering just slicing the the sections apart with a cutting sics then grinding off the flanges and remaking it all but took a chill pill and returned to it yesterday where I made better progress and the whole bottom flange is now separate and the side and some of the top. Hope to get them apart today. The corrosion is actually worse than I thought but it will be easy enough to fix once the 2 skins are separated While writing this I went back into my Ebay messages to get a quote of what I said to Jolene after she said it could only come in gloss and my message has mysteriously vanished. I'm 99.9999% sure I sent it but it appears not so have sent another simpler response "That doesn't make sense. If it can only be supplied as direct gloss why did you sent it to me as matte/basecoat? (as shown in pics).Thanks. Graham"I don't imagine I'll get any useful reply but you never know. rust on rear panel small holes always mean bigger rusted area removing the primer back to original paint old paint really shines taking measurements where original holes in bottom-flange are before making new holes
Last Edit: Jul 30, 2024 12:23:51 GMT by foxy99
foxy99
Jul 30, 2024 23:19:56 GMT
Nice short post this time... Got the shells apart today without too much trauma to the flanges. Was very frustrating having to drill certain ones 3 times! but now that it's done am ok with it. I was surprised to see that the inside seems to have some sort of black coating on it. The rear skin is made from heavier metal and will clean of fine I reckon. Should really get the electrolysis up and running again but I have a feeling I'll just clean it mechanically. After the complexity of the repairs to the bonnet I think this will be much easier. You may notice there is a sort of cone-shaped panel in the middle between the skins. This was also spot-welded to the outer skin. I wouldn't have known that (or spotted it) but strangely saw a Facebook post about someone fitting a rear-panel to his Imp and it was in two halves like mine and I saw the holes there. I think they were new panels as he had an 'Ex-Pressed Steel' advert in the picture and they are the ppl who make the bonnet repair pieces but I didn't realise they did ones for the rear. I did ask the guy to clarify but got the high-hat instead insideoutside
foxy99
foxy99
So the rear-panel repairs are continuing. I'm dying to get on the the actual body but the car is under scaffolding with motorbikes on the scaffold and I want to finish the engine, get it running and load it on to the trailer I'm refurbishing, take that to show the guy(s) who owned the car near me (Paisley, Renfrewshire) if I can find them and/or they haven't died yet then take the motorbikes off the scaffold and get the Imp out. There isn't quite enough room in the barn to manoeuvre it out from under the scaffold without taking on 'leg' way which would involve propping it up on Acros or something so I think I'll just do it the safe way. I've transferred the dimensions to bit of paper (it does work) and tried doing it at the dining table and there's not enough room. Anyway. Back to the rear panel.... So, as shown in last post, The front skin is basically done and the rear is also now basically done. As you can see from the pics a sort of square part which is heavily-recessed in the rear skin and meets the front skin with a hole in each panel fro the bumper-brackets. The rear skin is made from thicker steel (1.5mm) so the metal takes a bit more hammering to shape but the great part is you can make much better welds without blowing more holes so am really happy with how it turned out. The repair the the bottom edge isn't so good as I was having trouble with the welder and not getting much penetration. That seems to be sorted now so I'm tempted to slice a new line down that repair and weld it again. After that it'll be into the electrolysis tub to clean it all then paint, spot-weld or plug-weld the skins back together then paint. bumper-mount area on rear skin of rear-panel corroded same area viewed from 'outside' rot removed patch formed patch welded in view from 'outside' wide view
foxy99
Last Edit: Aug 7, 2024 18:43:17 GMT by foxy99
foxy99
Aug 24, 2024 23:04:35 GMT
foxy99
Sept 8, 2024 11:00:43 GMT
Darkspeed
Club RR Member Number: 39
Sept 8, 2024 15:15:07 GMT
Better increase my share holding in gas and welding wire... Bit of work ahead there.
foxy99
Sept 8, 2024 15:49:35 GMT
Better increase my share holding in gas and welding wire... Bit of work ahead there. Lol. Funny you should mention that as the plan was always to do the Imp with oxy-acetylene as I read somewhere that it's kinder to the metal. Also you can apparently shape the welds as it's softer. Anyway. There's no time for that now as I have months rather than decades to get this done. The price of MIG gas & wire isn't too bad imo but the costs for oxy-acetylene are getting outrageous. It costs me about £300 a year just to rent the cylinders and last time I wen for a refill it was about £18 for the product but the bill went up to £60 something after all the add-ons like £24 for entering the shop and £7 for not paying online. Every year I get an email from BOC for one free re-fill for low-volume used but have never actually had the voucher which is supposed to be attached to the email. Last year I spent about 2 hours on the phone fighting with them to get the voucher and they eventually emailed me it and I plan to go for my free refill this week. I have a horrible feeling it won't be honoured and/or they'll be adding all sorts of hidden charges. I need the oxy-acetylene to try to straighten some shallow bends on an old motorcycle frame and I think after that will just close my account. It's a very hard type of welding to master compared to MIG
foxy99
Sept 15, 2024 19:59:19 GMT
So I didn't flesh-out the previous update and it's a bit late to do it now so will just try to bring things up-to-date... So I was going on about the 'box-section' inner-sill. Well that's out and I've repaired two areas on it and two parts on the shell that the inner=sill fits to. There were two more small bits that needed repaired before I could weld it back in (not including the floor and seat-crossmember which can both be done later)and that has lead to the rear storage-bin being cut out which will now lead to partial repairs of another few panels before I can do the two bits I want to get done to get the sill back on. Pics later repairing top front part of inner-sill lower rear corner of inner-sill being repaired need to remake this before the inner-sill goes back on rear 'bin' removed for access
