Adey
Club RR Member Number: 171
The 1957 "The Dope" Dauphine Adey
@adey1984
Club Retro Rides Member 171
Jun 27, 2020 10:07:37 GMT
aaaaaaaaaaaaaaaand this morning i received some pictures..... That is a 6v armature in the correct rotation and spline count for my starter housing, being posted out to me next week. Good news until the next F up.
Adey
@adey1984
WOOOO, i took delivery of the armature this afternoon, i threw it in the starter housing and built that back up. Bolted it on the car and it spins nicely i think, span enough on the starter to get the oil around and turn the light off a few times over so hopefully that's all good now. Really really happy about that. I didn't get any pictures of building it back up as i kind of got it done sharpish to prove it worked.
Next issue I've got no spark, i have got a new points set here for my dizzy so ill fit that this eve, i need to look into how to test old ignition components, I'm not sure if the condenser is duff so ive ordered a new one of them too. The coil worked fine on the last engine so I'm assuming that its still fine, fingers crossed.
Castellated hub nuts and conical washers also here from so they have been fitted on, just need to torque them and put some split pins in and it can go back on its wheels.
Good day all in all, just waiting on a few more bits and all we will be back on the way. Missed my 1st of July deadline but all being well it should be back up and running in a couple of weeks.
Adey
@adey1984
I spent the day trying to get a good amount of work done and completed to hopefully start the car. I checked a few condensers I had in and picked one that wasnt faulty and fitted it to the dizzy I replaced the points on. I have spark but its weak as curse word. So I've ordered a new coil, condenser and some fresh battery cable to replace some that doesn't look to clever. Fingers crossed with it all replaced it should fire up nicely. I need to find a carb rebuild kit too as the accelerator pump decided to start spraying fuel out sideways.
Engine mounts turned up so they have been fitted and its feels solid as a rock, the old setup had 3 out of the 4 mounts ripped in half 🤦🏻♂️
On the list of things left to sort is an exhaust system and the gear linkage along with picking up the hoses for the cooling system. I'll probably move to that once I can prove the engine is sound.
vulgalour
Club RR Member Number: 146
The 1957 "The Dope" Dauphine vulgalour
@vulgalour
Club Retro Rides Member 146
Really shows how tiny that engine is, the Dauphine isn't exactly a large car and that engine still looks lost in that engine bay.
Adey
@adey1984
Really shows how tiny that engine is, the Dauphine isn't exactly a large car and that engine still looks lost in that engine bay. indeed, its properly dinky and its bigger than the one i removed
Last Edit: Jul 2, 2020 17:18:34 GMT by Adey
teaboy
Make tea, not war.
Gordon's alive!
That's brilliant.
result...!! top job.
Adey
@adey1984
Cheers all, it took a few adjustments of the dizzy to get it to catch and run but pretty chuffed with that. Have done a fair bit of rewiring today and fitted a new coil but all seems to have worked. Need to work on the next list of things, Exhaust, cooling system, carb rebuild and a gear linkage are all on the list.
That's so awesome to see and hear, well done! Warren
Adey
@adey1984
Jul 10, 2020 20:20:13 GMT
Well done on all the work Adey she will look good when finished. Cheers its getting there. I also need to go borrow some banded 15s off a mates Renault 8 to see how it looks on them soon. Every time i look at it, it looks the same as when i brought it back home, but have spent ages working on it. Next to noting visually to account for the time and effort lol Ive got a couple of big box's here donated from a friend that look similar to the above pic, they just look huge when near the car. Unfortunately my phone keeps corrupting the pictures so i can upload any to show what i mean. The old dope exhaust is on for now but ill probably focus on the exhaust once the rest has proven itself. Had a text from DHL to say my rad will be here Monday. Ive just been out and tightened the rear hub nuts and fitted the wheels, popped the speedo cable in the box (though i don't think its the right one) and everything else is tightened up as far as i can tell. To have a test drive i need to fit the carb gasket set when it gets here, fit and the water system and fill the gearbox with oil. There's a list of other niggles but they are the majors to see if it all works properly
borcombe
Newport, Northern Beaches
Jul 10, 2020 21:23:18 GMT
Love the Dauph, imho it would suit 5.5x13's Avanti's A110's used to wear. Alloy centres, steel rims. Or if your'e feeling rather wealthy, find some Cosmics as fitted to this R8
