Adey
Club RR Member Number: 171
The 1957 "The Dope" Dauphine Adey
@adey1984
Club Retro Rides Member 171
May 20, 2020 20:32:07 GMT
Caught this in IG the other day... VR6 swapped, taken somewhat to the extreme with styling though. Its pretty wild isnt it, i think the rear track has been set with as the engine is built in the same as it would be in a golf, so its quite wide. He posts plenty of vids, the vr engine sounds so amazing.
Yeah a VR6 is a bucket list engine to own at some point... Along with many many others haha
Adey
@adey1984
May 21, 2020 14:11:44 GMT
I was so sick of being locked up at home I chanced it and took the dope out for a quick cardboard disposal trip. Something clutch related is sticking and causing the clutch to drag but if I pop the pedal it grips hard again. Still cool as to drive in even if it smashes your teeth out and sounds like its about to fall apart 😂
Last Edit: May 21, 2020 14:18:13 GMT by Adey
May 21, 2020 14:14:38 GMT
Cool indeed
brc76
May 21, 2020 17:39:32 GMT
I love how the body lines cast a kustom shadow. Such a cool thing.
Adey
@adey1984
So as I'm so hardcore with my lowering , and especially after yesterday's teeth rattling I decided to swap out my modified front bump stops for some proper conical items to make it a little more progressive on the stops. Yes I run on the bump stops, don't hate too much. I need to take it for a spin but it seems a lot more forgiving when bouncing on the car, win in my book 👍🏻 I did have some pics but my phone decided to corrupt the images
Adey
@adey1984
May 23, 2020 15:48:12 GMT
Last Edit: May 23, 2020 21:09:12 GMT by Adey
Such a cool looking car, I really like what you are doing. Warren
Adey
@adey1984
Such a cool looking car, I really like what you are doing. Warren Thanks man, appreciate it
Adey
@adey1984
May 25, 2020 13:19:33 GMT
If I had some spare material that was acceptable I would of made some of them too but I think I will end up ordering new. they are cheap it's just postage I hate... theres a few little other bits I could do with too so it will make it a little more acceptable.
Loving driving it though, its worlds apart from how it was when I collected it though it all looks the same 🤦🏻♂️
Started looking at another thing i want to do soon. I really want some wider rear wheels, but rather than band them I'm looking at re barreling them. Remove the centre from one of my wheels and then place it into a wider barrel. Pulled the tire off the spare already so will now look at removing the hub part. Fingers crossed.
Adey
@adey1984
May 28, 2020 13:53:51 GMT
Note to self, when quickly repairing the seats frame make sure you shield it very well and have a hose to hand. The 60 year old seat and the hay/hair mesh that's inside lights very easily and burns quickly.........🤦🏻♂️
May 28, 2020 14:43:40 GMT
Doing "burnouts" are you? lol
Adey
@adey1984
May 28, 2020 15:49:17 GMT
Doing "burnouts" are you? lol you could call it that lol. more so than the car can do under its own power
May 28, 2020 16:36:43 GMT
What width are those wheels Adey? Estafette are 5” standard if that’s wide enough.
Adey
@adey1984
May 28, 2020 18:06:53 GMT
What width are those wheels Adey? Estafette are 5” standard if that’s wide enough. i measured the spare wheel i stripped at 4 inch. are they 5x15?
May 28, 2020 18:28:41 GMT
Yes 5x15”. I think they would probably fit straight on or you could just use the hoop if your going to reverse rim them with your disc. There’s a guy on the Estafette FB page called Elliot Harrison who would have some. He trades as My Estafette or the Estafette Emporium. Essex based I think.
Adey
@adey1984
May 29, 2020 12:03:49 GMT
Cheers for the heads up, i have just found his website and note he sells a 5 stud hub conversion kit...... do you know much about it jonsey? emails keep bouncing back from the webpage.
Last Edit: May 29, 2020 12:10:39 GMT by Adey
