Adey
Club RR Member Number: 171
The 1957 "The Dope" Dauphine Adey
@adey1984
Club Retro Rides Member 171
Mar 30, 2016 11:29:26 GMT
20 min spare to start playing a little. Back obviously needs a touch with the stick but not dropping it too much. Front is on the bumpstops,quite common for lowered Renault 8s to run on them so this should be fine. Got a few bits to renew and replace but being covered in French mud has protected everything really well, in fact It came apart better than my 5 year old Renault.
dikkehemaworst
Club RR Member Number: 16
The 1957 "The Dope" Dauphine dikkehemaworst
@dikkehemaworst
Club Retro Rides Member 16
Mar 30, 2016 11:37:24 GMT
Are you able to band the stock rims? Love to know because nobody in holland is able to balance my wheels. The wheels just do not fit the balancing machines....
Adey
@adey1984
Mar 30, 2016 11:40:24 GMT
I have spoken to a company who said they can yeah. Will update when it gets to that point. Chances are I will only band the rear on this though.
Adey
@adey1984
Mar 30, 2016 13:50:26 GMT
Rear looks easy too. That should be a case of lobbing a coil off to get a little drop.
vulgalour
Club RR Member Number: 146
The 1957 "The Dope" Dauphine vulgalour
@vulgalour
Club Retro Rides Member 146
Mar 30, 2016 15:34:40 GMT
Banded rears and a bit of rake will look most excellent on this. Doesn't even need paint, it's perfect right now.
The 1957 "The Dope" Dauphine fr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
Mar 30, 2016 15:38:23 GMT
Looking forward to seeing this completed. Call me silly but I'd like to see the rear axle extended and big fat tyres on wide wheels that sit outside of the body with the body on the floor.
Adey
@adey1984
Mar 30, 2016 15:55:15 GMT
Banded rears and a bit of rake will look most excellent on this. Doesn't even need paint, it's perfect right now. Thank you, exactly what I'm thinking
Adey
@adey1984
Mar 30, 2016 15:55:45 GMT
Looking forward to seeing this completed. Call me silly but I'd like to see the rear axle extended and big fat tyres on wide wheels that sit outside of the body with the body on the floor. You're silly
Last Edit: Mar 30, 2016 16:21:17 GMT by Adey
vulgalour
@vulgalour
Mar 30, 2016 22:21:54 GMT
Do the earlier 'star' wheels fit? I've never been sure if they're like the Panhard wheels where the centre detail is the brake drum or if they're some sort of split steel rim. I would like to see them done as staggered split rims, they're a lovely bit of design.
dikkehemaworst
@dikkehemaworst
It's a '57 model , so it should have the early star wheels as standard. would be nice though , a '50 split rim , and only widen the rim and not the star.... was yours an exportmodel with the later wheels? I've got the same wheels on my ' 61 and thats an ondine export with a 1050.
Adey
@adey1984
Mar 31, 2016 10:37:05 GMT
It's a late 57 so no star wheels here also has a heater fitted.
Rear may need to come down one coil more. Not sure if there looks like a little to much rake plus I wanted a touch of rear camber.
79cord
Mar 31, 2016 11:28:40 GMT
Reminds me of Parents early Renault R4.. Even the wheels look similar. Basic, disposable steel tube bumpers to protect it without distracting from its simplicity?
Last Edit: Mar 31, 2016 11:31:26 GMT by 79cord
stevietuck
Mar 31, 2016 15:20:21 GMT
That looks the business mate!
Adey
@adey1984
Mar 31, 2016 17:12:00 GMT
Will need to modify the axle drop stops so I can limit the drop of the axle and stop the springs dislocating
vulgalour
@vulgalour
Mar 31, 2016 18:07:08 GMT
I think it was better with rake. That last picture demonstrates why you need wider wheels on the back nicely though.
Adey
@adey1984
Mar 31, 2016 19:15:35 GMT
I think it was better with rake. That last picture demonstrates why you need wider wheels on the back nicely though. There's still some there, will get a side on shot. The extra drop just gave me a little negative rather than positive camber
Paul Y
Mar 31, 2016 19:20:40 GMT
I likey. Looks a little Crossley esq in that 3/4 front shot. Agreet hat the final drop with a little negative camber looks best - well too my eyes.... Mid mounted Scooby lump and you are Golden.... P.
vulgalour
@vulgalour
Mar 31, 2016 20:43:45 GMT
The drive is probably cancelling out some of the rake visually too. Carry on anyway, it's all good
