1985 Honda Acty Show Truckfr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
Apr 10, 2019 22:01:13 GMT
As an aside to the above I’ve realised that with four cars in the family we now have the following PCDs... 4x98 4x100 4x114.3 4x120 I reckon I need a four stud ford next to cover all bases. Or maybe another dolomite for 4x95. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
@freshandminty
Apr 13, 2019 18:12:28 GMT
Another Saturday morning of taking bits off the proton... I love how the side light units are retained by springs... ![](https://uploads.tapatalk-cdn.com/20190413/570024e47324b1c2b27d7d509241f23f.jpg) ![](https://uploads.tapatalk-cdn.com/20190413/29c3e2d0c480f3945c8da50bec8357f8.jpg) Inner rear arches are so clean... ![](https://uploads.tapatalk-cdn.com/20190413/be92a3405ab6f5608d0bd2e942f37a17.jpg) ![](https://uploads.tapatalk-cdn.com/20190413/efd543ff414b56e847e5eaa706bb7d51.jpg) Under light trim piece thingies removed... ![](https://uploads.tapatalk-cdn.com/20190413/ab75b5b8bcdd4fb4c667c59916b2841a.jpg) I spent ages trying to remove the rear lights and bumpers after removing all visible nuts but they wouldn’t budge so decided to leave them in place for painting, there’s only one line along the light that I won’t be able to access. I then removed the bumper bumpers, I already knew they were held on by clips in holes but I’ll get a chrome strip to hide the holes which imho will be more subtle and a lower profile than the standard trim pieces... ![](https://uploads.tapatalk-cdn.com/20190413/8f2ebb4e24fa09ab460c73f061bf5c99.jpg) ![](https://uploads.tapatalk-cdn.com/20190413/801b91ce96c7395bf2c5139e5cc1323e.jpg) I was pleasantly surprised to find the bumpers were metal. Rear mud flaps off next... ![](https://uploads.tapatalk-cdn.com/20190413/975682885ffabe8ce389ff2157274873.jpg) Then front plate and front indicators and lower front grill removed... ![](https://uploads.tapatalk-cdn.com/20190413/6827cb70041689452c5d2517f8d8928e.jpg) ![](https://uploads.tapatalk-cdn.com/20190413/84ec2f9421a97303a57f1cf5aa4438c4.jpg) Rear number plate and mounting panel / reverse lights removed next... ![](https://uploads.tapatalk-cdn.com/20190413/69e683b65873b2de99b8f71c61d4a6f5.jpg) Front mudflaps removed and remains of the adhesive from the side running strips removed with a heat gun and scraper, damage was done to the paint but as I’m repainting any way I wasn’t concerned, I would have chosen a slower and more forgiving removal method if I wasn’t repainting. ![](https://uploads.tapatalk-cdn.com/20190413/baf9d7a30f4a11ea6eae2b1afed32b62.jpg) Jonny is ready to be attacked by a mouse sander and 800 grit pads next.
vulgalour
Club RR Member Number: 146
1985 Honda Acty Show Truckvulgalour
@vulgalour
Club Retro Rides Member 146
Apr 13, 2019 23:54:35 GMT
Are you still planning to two-face Mario kart this or did you end up going all Initial D on it instead? I lost track.
@freshandminty
Are you still planning to two-face Mario kart this or did you end up going all Initial D on it instead? I lost track. I decided to go for a more classic look when I discovered roller painting cars. Current plan is initial d since I introduced Ethan to initial d but possibly with mario M decals that the next owner can remove if desired. The red / green mario / Luigi split was all down to green gear knob and steering wheel but I think I’m going to revert back to standard gear knob and paint green on steering wheel black.
vulgalour
@vulgalour
Apr 14, 2019 12:14:04 GMT
Well you're not going to be making it worth any less, whatever you do, these little cars are woefully undervalued which is a shame. Even one as clean as this isn't worth what it ought to be, and you've the ability to make whatever you do actually look good.
@freshandminty
Well you're not going to be making it worth any less, whatever you do, these little cars are woefully undervalued which is a shame. Even one as clean as this isn't worth what it ought to be, and you've the ability to make whatever you do actually look good. That’s along my thinking really. Have some fun with it but not killing it by doing silly unnecessary drilling / cutting etc. If I can get the paint looking real nice it might attract new people to this model that might have dismissed them in the past and if anyone does want a mint one in the future they could strip paint off and have a proper respray and it would be like a new car. In other news a 12 metre roll of 50mm vinyl wrap tape has arrived for the middle belt line... ![](https://uploads.tapatalk-cdn.com/20190415/f5ed999fc58e6b7b7ecac40247fc97b1.jpg) ![](https://uploads.tapatalk-cdn.com/20190415/ee30dfe01da2648c288ab93d72a9b480.jpg)
recarouk
Yorkshire and The Humber
Apr 16, 2019 12:03:42 GMT
olduns
Apr 16, 2019 16:01:27 GMT
Seller based in Pershore so probably one of his that was parked as an advertising board on bridge above M5. I also met some deluded 20 yr old with plans to drop a Ducati V twin into one. I'd lay odds he never did it!
Last Edit: Apr 16, 2019 16:01:58 GMT by olduns
recarouk
Apr 17, 2019 12:29:26 GMT
Seller based in Pershore so probably one of his that was parked as an advertising board on bridge above M5. I also met some deluded 20 yr old with plans to drop a Ducati V twin into one. I'd lay odds he never did it! ha ha this one looks fairly fruity, no idea what engine mind: ![](https://www.google.com/url?sa=i&source=images&cd=&cad=rja&uact=8&ved=2ahUKEwi3kLOGkNfhAhVOb1AKHSayAysQjRx6BAgBEAU&url=https%3A%2F%2Fwww.pinterest.ch%2Fpin%2F477803841712574311%2F&psig=AOvVaw062JndK7E-KO_QnhpeIYLK&ust=1555590403493153) ![](https://www.google.com/url?sa=i&source=images&cd=&cad=rja&uact=8&ved=2ahUKEwi3kLOGkNfhAhVOb1AKHSayAysQjRx6BAgBEAU&url=https%3A%2F%2Fwww.pinterest.ch%2Fpin%2F477803841712574311%2F&psig=AOvVaw062JndK7E-KO_QnhpeIYLK&ust=1555590403493153) ![](http://www.curbsideclassic.com/wp-content/comment-image/62931.jpg)
@freshandminty
Not sure if I mentioned it on this thread but I did find myself browsing them on Japanese auctions at the start of the year but resisted. The trouble with the modified ones i think is they look like they’ve been raced in Japan- maybe not all of them - but think I’d rather go for a standard one. I did find van versions rather than pickup too.
Not sure if I mentioned it on this thread but I did find myself browsing them on Japanese auctions at the start of the year but resisted. The trouble with the modified ones i think is they look like they’ve been raced in Japan- maybe not all of them - but think I’d rather go for a standard one. I did find van versions rather than pickup too. All of these are so unusual, impractical, probably a PITA and of course one wants one. Same seller has a Cube, certainly on my want list. Just not sure it would out perform Prozac in the practicality stakes. Maybe, just maybe I will have one, one day. In the mean time, this thread keeps me coming back.
@freshandminty
Apr 18, 2019 20:50:01 GMT
Latest update from the body shop where the Acty currently resides... ![](https://uploads.tapatalk-cdn.com/20190418/3819ea0aeb580d473fb84dbd4a76e9fd.jpg) Steel lower repair panels intended for a vw split screen being adapted to form new side panels and rear arches.
GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
1985 Honda Acty Show TruckGavinJ
@gavinj
Club Retro Rides Member 209
Apr 19, 2019 16:18:51 GMT
Ooooh looks like they are doing a very nice job of that, it’s the colour I’m most curious about though....🤷♂️
@freshandminty
Apr 19, 2019 19:38:55 GMT
Ooooh looks like they are doing a very nice job of that, it’s the colour I’m most curious about though....🤷♂️ Not as clear cut as you might think but probably mint will be tricky not to choose eventually.
Apr 22, 2019 17:56:36 GMT
Give it a Mint Aero look..... ![](https://cdn11.bigcommerce.com/s-kbm52d/images/stencil/1280x1280/products/2467/3096/pn131__37789.1522096498.jpg?c=2&imbypass=on)
Apr 24, 2019 14:23:35 GMT
Can't believe it's taken me 7, incredibly busy, working hours to go through this thread.
I'm green with envy that you have the ways and means to take on such projects and have a supporting family around you. Fantastic job, Keep at it man. Life would be even duller if we all drove the same thing.
1994 S1 106 Rallyé 1996 Mini Cooper 1.3 MPI (Rust bucket, currently in for surgery/resto) 2003 Renaultsport Clio 172 (Daily beater)
tom13
Apr 24, 2019 15:52:32 GMT
Can't wait to see those wheels on the Ignis. How long before the big reveal?
@freshandminty
Apr 24, 2019 18:48:35 GMT
Can't believe it's taken me 7, incredibly busy, working hours to go through this thread. I'm green with envy that you have the ways and means to take on such projects and have a supporting family around you. Fantastic job, Keep at it man. Life would be even duller if we all drove the same thing. Cheers for the comment. Glad it was worth reading. Yes very understanding people around helps!
@freshandminty
Apr 24, 2019 18:50:13 GMT
Can't wait to see those wheels on the Ignis. How long before the big reveal? Big reveal of what? ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) The proton painted? The wheels on the Ignis? The Acty complete? Currently they’re in the above timeline ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Apr 24, 2019 19:06:44 GMT
any or all...not fussed personally!
