1985 Honda Acty Show Truckfr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
May 13, 2021 21:03:46 GMT
Good work, rotten jobs but you caught that hidden rust in good time. Yes it’s something I could have done casually at any point in 2020 but why not wait until 3 weeks before the weekender?! I’d like to get a professional to take the whole of the underside back to bare metal and do the process again when there’s more time. I’m sure there’ll be other areas that will need addressing at some point. I have spare coolant pipes too so would like to strip and paint those and swap them over in future.
@freshandminty
The hydrate 80 has done it’s thing, took this photo this morning, about twelve hours after the second coat… There was only minor rust on the axle any way (from where some of it had been soda blasted before paintwork in Spring 2019 and not treated up to now) so I’m looking forward to seeing how the rust patches look but I’m not in my scruffs so can’t crawl under to look until Saturday. I’m impressed with how this has transformed. This was before, although I haven’t got the full axle and box sections from the suspension framework in this shot…
@freshandminty
You’d think that after buying a total of three trucks and one collection of spares I’d have all the parts by now but a breaking Acty popped up on eBay this week and I’ve now got a front badge heading my way, I have one without the A but this is complete so I’ll get it stripped back and painted as per original or possibly colour coded to the body to make it more stealth or maybe use it on the aluminium canopy. Not sure yet but while one is available and in the UK I thought I should get it. How they looked brand new, from a brochure photo…
@freshandminty
Early start this morning to get some outside jobs done before the rains come. Aluminium tool box dug out of shed… … and cleaned up… … and dried… … and painted… Whilst that dried it was on to the final varnish coat on the board. It got rained on its last coat leaving patches… No one is ever going to see it but I decided to give it a quick wet sand any way, hosing it showed how protective the varnish is with water just beading right on top and running off…. Then I made a little shelter to prevent the same happening again… And gave the top side it’s 4th coat of varnish… Now it has a shelter I’ll try and get at least two more coats on the underside during the week to make it super waterproof. Then I need to redrill the holes in the bottom of the tool box so that it sits in the right place on the board, behind the vertical board before I can fit it all on the back of the truck. And last job before the weekender is to do an oil and oil filter change.
@freshandminty
May 16, 2021 17:25:07 GMT
The rain said get them in the truck ASAP! So I did. Tool box not fixed down yet, I need to redrill the holes in the base of the tool box as it sits further back and to the right compared to its previous location.
mk2cossie
Club RR Member Number: 77
1985 Honda Acty Show Truckmk2cossie
@mk2cossie
Club Retro Rides Member 77
May 16, 2021 17:31:07 GMT
Looking good Love the rump shaking with the hydraulics
@freshandminty
May 16, 2021 18:08:59 GMT
Looking good Love the rump shaking with the hydraulics I didn’t know my twerking was visible in the reflection?!?!!
@freshandminty
May 17, 2021 19:29:45 GMT
Olfi camera mount fixed on the rear window today, I’ve taken a test photo in the garage and it’s got a good panoramic view and hopefully my videos will include all the sites I get to see on the roads from now on.
@freshandminty
May 19, 2021 16:10:44 GMT
Front badge and magnetic sump plug arrived in today’s post… I gave it a bath for an hour… … then at lunch time I blasted it with the patio cleaning high pressure lance on the jet washer… Some area’s surprisingly stubborn. I’ve already started to scrape some of that off with a blade but no photo yet.
@freshandminty
May 19, 2021 20:12:26 GMT
Just some fiddly bits within the H and a few other spots to scrape at before it’s back to plain plastic… … and also forgot to post about last night’s progress. I drilled the holes in the bottom of the toolbox and positioned everything in it’s right place but then I realised “I’m gonna need a bigger bolt” so three on their way but at least everything is ready to get bolted together when they arrive.
@freshandminty
May 20, 2021 19:51:38 GMT
A bit more scraping and steel wool got the badge clean enough to be painted, although I still need to clean the old adhesive off the back… Tried in a few places… Also in today’s post the bolts for the tool box / board / divider screen arrived as well as much more subtle QR code stickers to replace the huge one in the back of the truck. I only need a few but they’re sold in A4 sheets of repeated design… I also picked up my oil, oil filter, and an oil filter removal tool so I can do an oil change next week.
May 20, 2021 19:59:08 GMT
Always busy.
Relentless and restless.
Progress.
@freshandminty
May 20, 2021 20:22:43 GMT
Always busy. Relentless and restless. Progress. To be fair i didn’t touch it from September until March as the possibility of car shows seemed so far away which has kind of forced a bit of a rush on for forthcoming shows but I tend to make better progress when I have a target in site.
@freshandminty
May 24, 2021 12:56:07 GMT
Less than a week until the weekender and I didn’t have much time this weekend. I got chance to bolt down the tool box and modesty board though and fill the area (and the box) with most of the stuff I need (and some stuff I hopefully won’t need) for the weekend and a round trip of nearly 400 miles… … At some point I plan to make a cover for the spring box and battery so I can safely store stuff over the top of them too. I did plan to do an oil change before the journey but Mrs Minty set doubt in my mind saying that if anything goes wrong there won’t be any chance to sort it and get to the show so I decided just to check the level … Even the dip stick is cute on an Acty. Level all fine despite it having a rocker cover leak for MOT, maybe they topped it up or the volume of leak was insignificant on my 18 mile round trip to the garage. Either way it’s fine for now and I’ve got oil on board if the level does drop. I’ll be going for a test drive on Tuesday evening to check everything is okay ahead of the weekend any way. Dry for long enough to primer the Honda badge and bake in the airing cupboard… Strong adhesive tape heated with a hair drier and applied… The weather is due to turn good from tomorrow onwards so should get chance to paint it chrome (bright silver) and attach to the truck before the weekender. Hopefully see you soon!
@freshandminty
May 24, 2021 15:20:09 GMT
Five minutes of dry and got a bit of chrome on, brighter than I remembered. I went a bit too close in places though so I’ve wiped the thicker area back while it was still wet and do another couple of coats tomorrow.
@freshandminty
May 25, 2021 10:11:28 GMT
Gave it another coat but as suspected the area I wiped between the N and D is still visible so I’ll sand just that area back once it’s dry and give another light dusting. It’s looking nice but I remember from the last time I used it that as soon as you apply lacquer it dulls it so I’ll fit it without lacquer. Location should be free from stone chips / any impact so should survive ok. If it dulls over time I’ll just go over the letters rather than the whole badge with a molotow chrome marker. I’m having difficulty sleeping / doing anything else as all thoughts are on the weekender. I will be going for a test drive tonight so that will set my mind at rest either way. If it drives fine then I’ll trust in it for Friday. If it doesn’t then I’ll have to abandon ship and go in the cactus or keep driving it hard tonight until it does drive fine. Then it’s just a case of remembering to pack everything on my various lists.
tom13
May 25, 2021 12:30:15 GMT
I won't be mad seeing either of the cars as they are both ace. I get you desire to get out in the Acty though.
@freshandminty
May 25, 2021 19:52:04 GMT
I won't be mad seeing either of the cars as they are both ace. I get you desire to get out in the Acty though. It’s a waste to have the Acty sitting around after this much effort especially for retro / classic shows but the cactus is a handy backup.
