Apr 19, 2016 16:58:02 GMT
Auto Engine Runs ok very very tatty / rusty /not been on the road for 3 years. matt black grey leather interior BMW 2.5 turbo diesel engine does drive. good for spares / engine donor or maybe drift or whatever people do with old knackered RWD cars these days!
Last Edit: May 16, 2016 16:47:09 GMT by datman
paul99
Apr 28, 2016 10:14:30 GMT
Will the 'box be ok on a motorway cruise? Fluid ok?
Apr 28, 2016 13:12:29 GMT
i believe so but i would expect this to need a lot of other work before being driveable, i would think very bad idea to drive it home, been sat around a while etc. tyres not very good etc
Price dropped to 150
Last Edit: May 12, 2016 13:36:10 GMT by datman
If the engine is sweet with no starting issues, you'd get at least £150 for all 6 injectors (number 4 with the wire is the expensive one) and £200+ for the injection pump.
Advertise it on the Rangerover groups as it's the same engine as the P38 and injectors/pumps are always snapped up
thankyou
May 11, 2016 15:35:08 GMT
someone is having the tow bar so car is now £125 .it shows 50k on the clock but there's no way it could really be that low looking at the state of it. i drove the car today , the brakes are a bit sloppy but the engine sounds pretty good. takes a while to start from cold, glow plugs? comes with handbooks, jack , tools etc.
Last Edit: May 11, 2016 16:43:11 GMT by datman
May 11, 2016 17:36:25 GMT
mot history in 2006 says 9k miles, last motd on 44k in 2012.
May 11, 2016 17:55:15 GMT
Yup. I can only assume it had a new speedo or something before 2006. It could have done 100,000 miles before then !
May 11, 2016 22:36:49 GMT
If the engine is sweet with no starting issues, you'd get at least £150 for all 6 injectors (number 4 with the wire is the expensive one) and £200+ for the injection pump. Advertise it on the Rangerover groups as it's the same engine as the P38 and injectors/pumps are always snapped up Are the pumps electric ? As in are they coded
May 12, 2016 13:42:46 GMT
£100
May 12, 2016 15:56:30 GMT
If the engine is sweet with no starting issues, you'd get at least £150 for all 6 injectors (number 4 with the wire is the expensive one) and £200+ for the injection pump. Advertise it on the Rangerover groups as it's the same engine as the P38 and injectors/pumps are always snapped up Are the pumps electric ? As in are they coded Nope, direct swap If I was closer I'd snap this up to break for engine bits
May 12, 2016 22:37:34 GMT
Are the pumps electric ? As in are they coded Nope, direct swap If I was closer I'd snap this up to break for engine bits I was thinking of a conversion so it's a pretty simple wire up engine ?
Should be, I can't think of anything that would stop you.
What are you thinking of putting it in?
May 14, 2016 14:58:17 GMT
Weighed in. Still have alloys if anyone wants em
Last Edit: May 16, 2016 16:47:54 GMT by datman
nitro
Wish i see this sooner
