Duggy
i wonder why mk2 cavaliers werent bonded screens, but mk2 astras are. must be the extra couple of years grasp towards the 70s and expandy trim in the groove type setup. cavalier is looking depressingly good (back handed compliment due to being at the metaphorical page 1 or 2 of my restoration ) Possibly either didn't have the time or money to setup the robot, or it was too late to get their suppliers to change the spec. Or maybe they didn't think the extra cost was worth the increase in structural rigidity. Who knows.
bstardchild
Club RR Member Number: 71
1988 Mk2 Cavalier 1.8GLibstardchild
@bstardchild
Club Retro Rides Member 71
i wonder why mk2 cavaliers werent bonded screens, but mk2 astras are. must be the extra couple of years grasp towards the 70s and expandy trim in the groove type setup. Carltons/Senators (1986 to 1994) were also bonded screens - I guess manufacturers were moving over to it around that time
sleag40
I've no longer space for any more!
Fuel filler apparatus now reinstated. Threading the pipes through the plastic conduit arrangement was a bit of a faff. It's all gotten a bit busier under there. Fuel lines all buttoned up now. To the rear, (still need to clip the tank to pump line to the chassis leg) Up front. Once I've checked everything over under here, I can get the motor back in.
1994 Volkswagen Polo G40 1992 Volkswagen Polo G40 1988 Vauxhall Cavalier GLi 1977 Vauxhall Cavalier GL 1973 Renault 15TS 1967 Lambretta SX200 1966 Lambretta TV200 1964 Lambretta LI150
sleag40
Nov 12, 2021 21:03:04 GMT
Whilst getting the front bumper cleaned up ready to go back on, I thought I'd try the grill on. It fits OK, but the little rubber grommets that support it on the body have disintegrated. May have to get creative here as I've not been able to find any on Ebay. The bumper to wing brackets cleaned up pretty well, just need to fit the new chrome trim to the bumper and it can go back on. Borrowed an engine crane from next door in preparation for the lump going back in, then went over the motor making sure everything was tightened or torqued before it goes back where it came from. Put it's own wheels on out back, then proceeded to drop the back end down from this height, to something a little less precarious. Should hopefully get the front end raised up, and the engine and gearbox back in over the weekend.
Nov 12, 2021 21:24:39 GMT
so smart looking hats off to ye
sleag40
Nov 13, 2021 23:13:07 GMT
Got the whole afternoon on this today, kicking off proceedings by getting the engine off the stand. The clutch was fitted next, I cleaned up the face of the flywheel with wire wool first as it had a bit of flash rust on it. Fitted a new release bearing, then the gearbox went back on. The front of the car was raised up a little to enable the engine and box to slide underneath. I put a sheet of perspex down first, then some polythene bags, then sat the lump on top. I was surprised just how easy it was to manoeuvre the heavy lump on this plastic combination (in the past I've used carpet and struggled) and it was also spot on for protecting the paint on the sump from damage. Once it was central under the engine bay, the crane was used to lift the assembly up into position so that the engine and gearbox mounts could be fitted. This took a fair amount of time to lift and manoeuvre a little at a time, constantly checking so that nothing was allowed to damage any paint anywhere. After an hour or so of faffing and fussing, it's all in position on its mountings. Should get all the mountings tightened up, and everything plumbed in and wired up tomorrow.
820
Nov 14, 2021 10:38:36 GMT
Excellent progress, this is such a nice build, I would never drive it, just admire it.
neil79
Nov 14, 2021 16:26:16 GMT
Excellent progress, this is such a nice build, I would never drive it, just admire it. Looks better than new from the factory
Nov 15, 2021 13:11:23 GMT
Just awe inspiring...
I have said it before (and I will repeatedly say it until people force me not to!!) and I WILL say it again but these mundane, everyday conveyances really are so rare and so comforting to see that I wish there were many more of them out and about!
This is wonderful!!
***GARAGE CURRENTLY EMPTY***
sleag40
Nov 15, 2021 20:38:01 GMT
Arthritis got the better of me on Sunday, but I managed a couple of hours on it this evening after work. The engine mounts were all tightened up first, then a few smal under bonnet items went on before the radiator, fan and coolant hoses all went back where they belong. I was a bit too crippled to get underneath and continue connecting up pipes and wires, so I chose the far easier job of fitting the secondary horn to the nearside front gearbox mount. Hopefully I'll get a bit more done in the week - I'm away at the weekend so will try to get the rest of the engine related stuff done before then.
sleag40
Nov 25, 2021 20:43:06 GMT
Not had any time on this for a while, but got a couple of hours on it this evening. The coil has been spruced up and put back on. The plumbing in and wiring is coming along, once I've fitted the engine loom and connected up the fuel lines, I can get on with fitting the sub frame and suspension. Should get a bit more done over the weekend.
sleag40
Nov 26, 2021 18:53:50 GMT
I've left the re-fitting of the engine loom for now, and got on with getting the front suspension back together. It's been sat on the four bolts which hold the centre of the sub frame arms to the chassis, so first I had to move the axle stands from there to the jacking points at the front of the sills. Once that was done, the anti roll bar was bolted on. With that in position, the sub frame arms could go back on, closely followed by the wishbone. Once I'd fitted the anti roll bar links, time had run out. Should get back on it over the weekend.
Nov 26, 2021 19:18:39 GMT
Hat's off to You Sir! That's the level I want to reach with my own BMW e36 coupe when I will start my restoration project. Better than factory without any doubts Sir!
sleag40
Nov 27, 2021 18:20:53 GMT
Bit more done today, the offside driveshaft didn't want to go back in to the gearbox, so suspecting that the circlip thing in the splined end was at fault.... another one was sourced from a random pile of driveshafts next door. The offending item didn't look too distorted.... But the "new" one allowed the driveshaft to flop back in with a couple of gentle taps. Once the driveshafts were in position, the strut assemblies were put back where they belong. Should hopefully get the engine loom buttoned up tomorrow.
Nov 27, 2021 19:41:59 GMT
Triple A... Awesome As Always!
1968 Mini MkII, 1968 VW T1, 1967 VW T1, 1974 VW T1, 1974 VW T1 1303, 1975 Mini 1000 auto, 1979 Chevette, 1981 Cortina, 1978 Mini 1000 1981 Mini City, 1981 Mini van, 1974 Mini Clubman, 1982 Metro City, 1987 Escort, 1989 Lancia Y10, 1989 Cavalier, 1990 Sierra, 1990 Renault 19, 1993 Nova, 1990 Citroen BX, 1994 Ford Scorpio, 1990 Renault Clio, 2004 Citroen C3, 2006 Citroen C2, 2004 Citroen C4, 2013 Citroen DS5. 2017 DS3 130 Plenty of other scrappers!
sleag40
Time has been scarce this week, but I still managed to get a few odd jobs done. The clutch and speedo cables have gone back on, as has the engine loom. I finally got round to chucking on the oil filter - it's been sat in a box for two years patiently waiting. I torqued up the front suspension fasteners, then checked all the wiring was in the right place before running out of time. Once the exhaust, brakes and wheels are fitted, it should be ready for firing up.
This is a very high quality project, I cannot state how impressed I am with your work on this.
I suspect the windscreen not being bonded may be to do with this being the J car series, effectively a world car with very few if any changes to structure wherever it was being made and sold, in a miriad of countries by various GM brands.
A joy to see...!!
sleag40
Didn't get a lot of time for this today, just enough to get the engine lid on and positioned nicely. More fettlings will hopefully happen tomorrow if I'm lucky!
sleag40
Luck was on my side today, difficult chores ended up being easy ones, so I got a couple of hours in the shed. I checked that the caliper sliders still slid, and that the pistons were still mobile (it's been a while since my DIY refurb). All in order, so they went on with the new discs... new pads and fitting kit... and new caliper bolt covers. After repeating on the other side, I got to have a drive in a couple of my other heaps before teatime.
