jonomisfit
Club RR Member Number: 49
Apr 16, 2021 19:58:40 GMT
My crimp tool arrived, so made off the main power cables P1050261 by jono_misfit, on Flickr continued plugging bits together P1050262 by jono_misfit, on Flickr buttoned up the centre console P1050263 by jono_misfit, on Flickr ive got some neatening up to do still P1050264 by jono_misfit, on Flickr Someone on the escort cosworth forum pointed me to a place selling reproduction side lights P1050265 by jono_misfit, on Flickr P1050266 by jono_misfit, on Flickr P1050267 by jono_misfit, on Flickr They are good enough for me, however I suspect on the high end cars the owners would have issue with them. They are not as good as the originals, but what reproduction bits are? In situ P1050268 by jono_misfit, on Flickr P1050269 by jono_misfit, on Flickr I spent some time tidying up various bits of loom, then made a start on the rear brake lines. feed in points to rear P1050270 by jono_misfit, on Flickr P1050271 by jono_misfit, on Flickr then measure up for the line P1050272 by jono_misfit, on Flickr That was the end of play today.
Last Edit: Apr 16, 2021 19:59:43 GMT by jonomisfit
jonomisfit
Apr 18, 2021 19:52:12 GMT
Finished running in the brake line P1050273 by jono_misfit, on Flickr i've ordered a smaller diameter of spiral wrap, so these will be replaced with a smaller diameter P1050274 by jono_misfit, on Flickr P1050275 by jono_misfit, on Flickr But fitted as braided stainless hose will happily cut through everything like a saw! and made up the passenger side rear brake line feed P1050276 by jono_misfit, on Flickr i think i need to add in an extra fixing P1050277 by jono_misfit, on Flickr spiral wrap is needed here to protect everything, plus have cable tied it all together to prevent any relative movement. P1050278 by jono_misfit, on Flickr then started prep for the cable management / brake line routes in the engine bay P1050279 by jono_misfit, on Flickr and wiring in place P1050280 by jono_misfit, on Flickr There will be a thermal shield fitted to protect it from the heat of the exhaust and the upper route P1050281 by jono_misfit, on Flickr and passenger side P1050282 by jono_misfit, on Flickr mounted the EDIS 6 module P1050283 by jono_misfit, on Flickr P1050284 by jono_misfit, on Flickr drilled for the brake fitting transit P1050285 by jono_misfit, on Flickr and feed line in P1050286 by jono_misfit, on Flickr It was a short day as had to turf a bit of ground for smallchild_misfits play area
It was a short day as had to turf a bit of ground for smallchild_misfits play area That sort of behaviour leads to reduced car storing space!
jonomisfit
It has! But it was also space I was unable to realise for car storage due to previous threats of divorce.....
jonomisfit
Apr 23, 2021 20:21:54 GMT
In order to be certain on whats needed for the brake lines I need to fit the brake calipers. If you look about 25 pages back I bought some cheap second hand brakes. This is one of the brackets. This is the bolt that wouldnt remain in one piece for the previosu owner. It is stttttuuuuuuuccck. P1050287 by jono_misfit, on Flickr i gave it a warm with the blow torch for a bit and double locked some nuts to try and turn it. P1050288 by jono_misfit, on Flickr This did not work.... not hot enough heat into the ali to expand it. I applied some thinking, then got the tig set out and spent a couple of minutes on a lowish power putting heat in the end of the bolt..... It did the trick nicely. I had to work it back and forth a bit with occassional sprays of WD40 to get it fully loose and the aluminium oxide out of the threads P1050289 by jono_misfit, on Flickr I then spent some time cleaning up the rust on the brackets, cleaning the threads etc. I then quickly put the calipers on the car..... No wait. I spent a hour tryign to figure out which way round the combination of bits go... I got it on eventually. P1050290 by jono_misfit, on Flickr Loads of room in the wheels P1050291 by jono_misfit, on Flickr Like Loooooaaadss P1050292 by jono_misfit, on Flickr This is the difference between motorsport wheel and road wheels. Designed for a load of space. Bare in mind these are 355mm disc. They are massive, but don't look that big in the wheels really. You can just see the calipers have had a light relieving previosuly..... I'm guessing there was not as much clearance. Anyway. Putting it on it took me 30 seconds to confirm its all good. So I put in the other front brake line P1050293 by jono_misfit, on Flickr P1050294 by jono_misfit, on Flickr I did a few other odd jobs I didnt take pics off, then finished the return hose to the tank. P1050295 by jono_misfit, on Flickr I've given it a good spiral wrap as I don't want it cutting into the tank at any point... P1050296 by jono_misfit, on Flickr P1050297 by jono_misfit, on Flickr Once the tank is final fitted and the fuel pump etc. is in then I have some bond on cable clips I'll put onto the tank to stop it moving. Then started the sealing rubber strip on the tank cover. Cleaned back the flanges with degreaser P1050298 by jono_misfit, on Flickr marked out and punch some 1mm rubber strip P1050299 by jono_misfit, on Flickr cleaned and dried the rubber, then using supper sticky 3m tape I started fixing on P1050300 by jono_misfit, on Flickr P1050301 by jono_misfit, on Flickr The tank cover still needs a paint, but it may wait until the car is mobile. Unlikely to be another update this week as I'm going to the pub :-) and I don't think i will be operable on my day
jonomisfit
a box arrived. P1050302 by jono_misfit, on Flickr with a nice random note written on the inside. It was appreciated P1050303 by jono_misfit, on Flickr side windows P1050304 by jono_misfit, on Flickr fitted P1050305 by jono_misfit, on Flickr The drivers side fought me a bit, but the passengers went in fine. P1050306 by jono_misfit, on Flickr I then fitted the passenger seat and harness so I could check clearance for the fuel filler P1050307 by jono_misfit, on Flickr and mocked up a fuel filler route P1050308 by jono_misfit, on Flickr Fuel filler will go in about here P1050309 by jono_misfit, on Flickr I stripped off the spoilers, cleaned everythign down, and bonded in the rear screen P1050310 by jono_misfit, on Flickr I then did loads of small jobs, most not pictured. Put a first coat of paint of the roof fill strips P1050311 by jono_misfit, on Flickr and bonded on a few bits of plastic that had been snapped off. P1050312 by jono_misfit, on Flickr P1050314 by jono_misfit, on Flickr All of this in the aim of getting the car weather tight.
jonomisfit
I gave the roof strips and wing mirrors a coat of black P1050315 by jono_misfit, on Flickr P1050316 by jono_misfit, on Flickr P1050317 by jono_misfit, on Flickr Not a great job, and will liekly need a do over at some point fitted P1050325 by jono_misfit, on Flickr P1050326 by jono_misfit, on Flickr P1050327 by jono_misfit, on Flickr made up a couple more brake link pipes P1050319 by jono_misfit, on Flickr wrapped in spira wrap P1050320 by jono_misfit, on Flickr go here P1050321 by jono_misfit, on Flickr link from the rear bulkhead transits to the rear axle brake hoses and the other P1050322 by jono_misfit, on Flickr I was going to go spray the car with cavity wax, but then noticed it said if <15 degC then keep inside for 24hrs to ensure a consistent consistency. P1050323 by jono_misfit, on Flickr I put a couple of bits of tape on so I know how close I am to the end of the tube, so I don't spray myself.... P1050324 by jono_misfit, on Flickr
jonomisfit
I need to blank this, the hole for the old fuel filler P1050330 by jono_misfit, on Flickr I was hoping to re-use it, but its just too low to get a sensible run to the tank. P1050331 by jono_misfit, on Flickr I don't want to buy a filler just to use as a blank, so better make something.... 10mmn Aluminium P1050328 by jono_misfit, on Flickr trimmed P1050329 by jono_misfit, on Flickr marked out using my accurate guage.... P1050332 by jono_misfit, on Flickr measured and drilled P1050333 by jono_misfit, on Flickr trimmed to closer to round P1050334 by jono_misfit, on Flickr doggily mount in the lathe P1050335 by jono_misfit, on Flickr end up with this P1050336 by jono_misfit, on Flickr drilled out on the PCD P1050337 by jono_misfit, on Flickr sits like so P1050338 by jono_misfit, on Flickr P1050339 by jono_misfit, on Flickr needs shorter bolts P1050340 by jono_misfit, on Flickr Its quite large, due to the size of filler used, and 10mm is over kill. I've ordered a piece of 6mm plate, and I think i'll re-make it thinner, and take more weight out of it as well. At try and make it look "lighter" as its fairly hefty at the moment.
jonomisfit
Maybe i'll put in on the mill and mill half the material off, to save re-making it.......
jonomisfit
this weekend had no car stuff, as I decided i "have" to reconfigure the workshop to see if it makes the space more useable.... Cut out the old shelving above the vice bench.... it was full of woodwormthen P1050341 by jono_misfit, on Flickr then bench out and tidy up.... it was thick in dirt and detritus under there P1050342 by jono_misfit, on Flickr emptied the shelves P1050343 by jono_misfit, on Flickr whcih it turned out had a lot of stuff on it P1050344 by jono_misfit, on Flickr a LOT of stuff.... P1050345 by jono_misfit, on Flickr moved it round and lowered the top shelf by 6 holes, and fixed to the wall P1050346 by jono_misfit, on Flickr started re-packing and found this, which i've been hunting for for ages! it was hidden in a plastic bag, in a box, in another box, and covered with junk. P1050347 by jono_misfit, on Flickr then remembered I needed to get the floor clear again so I can get the car back in.... so packed the shelves again. P1050348 by jono_misfit, on Flickr it looks a mess, but once I have a tidy through some of the bits it should get better. I have a LOT of brake calipers.... 3 full car sets (2 escort and 1 MX5). None of which I will be using so i think they may go for sale. slowly getting there P1050349 by jono_misfit, on Flickr P1050350 by jono_misfit, on Flickr there is a fair bit of stuff for the metal recycling point of the tip escort back in, and space is no worse, mig will go back in its space once I get rid of the junk P1050351 by jono_misfit, on Flickr and started emptying back these shelves as well. P1050352 by jono_misfit, on Flickr
820
May 10, 2021 14:43:28 GMT
Great work on the Escort. Really like the brake hoses, I want to do mine now.
jonomisfit
May 15, 2021 17:22:54 GMT
operation tidy up / re-configure continues I removed the old home made draws and bought a cheap storage cabinet to go in the space. P1050353 by jono_misfit, on Flickr Theres actually enought space to put two in there side by side. I'm tempted to buy a second and do this. Rather than rip out the old shelves in this corner (at least at this point, i may do it later) I set about making them a useable size and fitting a shonky cupboard door to it all. P1050354 by jono_misfit, on Flickr shelves are now double the height they were, so can take actual stuff in them P1050355 by jono_misfit, on Flickr I filled the cupboard but forgot to take another pic then spent ages boxing things up and putting them on the mezanine, and then re-packed the shelves above the bench in a more useable way P1050356 by jono_misfit, on Flickr I also wrote on the wood what things were if it wasnt imediately obvious. fitted an additional light into this corner so its now possible to see things... And started building up another pile of things to go to the recycling centre (having been there friday afternoon with a full van of things) P1050357 by jono_misfit, on Flickr slowly getting there, you can at least see the floor again now. P1050358 by jono_misfit, on Flickr and almost there on the bench. P1050369 by jono_misfit, on Flickr I'll need to see what I do next. Back to the escort, or buy in some steel and make the new metalwork bench. There's still some more changes to make on layout Garage Layout - 2 - 6 by jono_misfit, on Flickr Garage Layout - 2 - 7 by jono_misfit, on Flickr New workbench i'm intending to make Workbench_Assy by jono_misfit, on Flickr I'm also giving consideration to buying a two post ramp, so may well model that up and see how it all works space wise. Objective has been achieved so far, as it does feel like theres more useable space... at least there will be when I've exited the new recycling pile....
jonomisfit
May 23, 2021 20:05:09 GMT
This weekend was spent not working on the escort. Mrs_Misfit and Nolongeratoddler_misfit were away for the weekend, so I spent 3 days painting where new windows etc. have been fitted and patched plaster etc. This took up most of the time. I had this afternoon free, so after failing to get the mobility scooter running ( forum.retro-rides.org/thread/210182/toddler-misfits-tot-rod?page=2) I knocked up a "quick" job for my dad. My dad dropped in for a quick stay for the first time in 9 months (covid + scotland) and produced out of his van a piece of inner wing from a ford consul. And nonchalontly asks, any chance you can make me the inverse of this, the other side is missing. the part to copy P1050376 by jono_misfit, on Flickr made a cardboard template P1050377 by jono_misfit, on Flickr transfered it to steel P1050378 by jono_misfit, on Flickr rough trimmed it P1050379 by jono_misfit, on Flickr started to bend the flange P1050380 by jono_misfit, on Flickr bend bend bend, hitty stick hitty stick P1050381 by jono_misfit, on Flickr drilled the mounting holes and put in a bead (smaller than original as I don't have the right size dies, and its only a stiffener) P1050382 by jono_misfit, on Flickr and gave it a clean P1050383 by jono_misfit, on Flickr It came out OK. Not perfect, but will work well enough. As I now have batteries I can use as a tester, I think i might connect one to the escort and try out the electrics and see if they work.....
Last Edit: May 23, 2021 20:06:44 GMT by jonomisfit
jonomisfit
May 30, 2021 19:29:49 GMT
As part of the clear out I sold a few things I didnt need that were just taking up space. And converted them into something else that will take up space P1050384 by jono_misfit, on Flickr Which came as a box of bits and I spent ages putting it together, then even longer trying to get it all running well. One of the big isues is dust affecting visibility and as such an extractor system was needed. If you just connect a vacuume to the exhaust port you fill the the bag very quickly. So I got a cheap cyclone seperator, and plumbed it in. Size wise I couldnt find any tube that was the right size, so the closest was some 50mm drain pipe which then got modified a bit to make an exhaust. I then taped all the joints to try and keep the vacuum sealed as I could. P1050385 by jono_misfit, on Flickr unlike the really cheap ones from ebay (this is still cheap just not as cheap) it didnt need mods to the pickup pipes, and the seals were fairly decent. Does it work? A beam clamp before P1050386 by jono_misfit, on Flickr P1050387 by jono_misfit, on Flickr scabby as anything. After P1050388 by jono_misfit, on Flickr P1050389 by jono_misfit, on Flickr P1050390 by jono_misfit, on Flickr I was still getting a technique to do it, as i've never don't any real blasting before. This was with aluminium oxide media, I'll try getting some glass at another point as see what thats like. Works quite well, and I was a bit worried my compressor tank is too small, but once up to pressure it keep running well enought to hold about 80psi with continuous blasting.
We got around the dust issue by plumbing in a shopvac, but with a 20l oil drum full of water in the middle. Using glass, it filters pretty much all of it out and turns it in to mud. Added benefit that it only really pulls the dust out which is too fine to be useful. Usually they benefit from a bigger nozzle, too.
jonomisfit
Jul 24, 2021 19:32:01 GMT
My Dad turned up last weekend for a few days and brought with him a rear diff from one of the sheds. No idea what ratio, so I put some paint marks on it and turned the fropnt flange 10 times and counted the rotations. Its a 3.625, which is the right one for what I need. P1050583 by jono_misfit, on Flickr It was filthy, having sat in a shed for something like 15 years... so I gave it a de-grease and a wash down. It still needs a buff with wire wheels to lift the oxide off. I noted the fill / drain plug was mullered. After some attemps with hand tools and using the impact gun I gave up and welded on a large nut. Which with the heat from the welding and somethign to grip to it just wound out nicely. P1050584 by jono_misfit, on Flickr Daughter_misfits tot-rod is taking longer than I hoped, so I'm itching to get back on with this.
Jul 24, 2021 20:00:11 GMT
Once you've blasted it to that sort of finish stick the part in some TFR overnight and it'll clean the rust pits out too.
nice to see some progress
All i seem to do with mine is walk under it while its raised up on the hoist
jonomisfit
Mine currently on hiatus whilst I get the postman pat van finished. I'd like to be back on with it ASAP as I'd like to drive the thing!
