jonomisfit
Club RR Member Number: 49
I decided I fancied a change this afternoon. If anyone has driven a sierra / escort thats got some age behind it will know the gear shift gets sloppy. Ford put a lot of rubber where they could in the gearstick, i'm asusming to reduce noise/vibration. I'm surte it was fine when new, but its all gone soft so i need to do something. It turns out i have 4 gear sticks, some better than others, but all seem a bit sloppy to me. Think i'll make a new gear stick. Original P1070721 by jono_misfit, on Flickr I've already ordered a nylon gear nob (at £20 its not worth the effort of making one!) but need to make the stick itself. Make a drawing of waht I want. P1070722 by jono_misfit, on Flickr I've got a length of 20mm EN24T lying about, so am makling from this. Considerably stronger than normal bright mild so if it bends, i've likely bent a selector fork as well. Cut to length and put in the lathe P1070723 by jono_misfit, on Flickr cut a step and doing a light pass with the thread tool to check pitch correct P1070724 by jono_misfit, on Flickr P1070725 by jono_misfit, on Flickr threads cut P1070726 by jono_misfit, on Flickr reducing centre section P1070727 by jono_misfit, on Flickr part made, couple of flats added to bottom P1070728 by jono_misfit, on Flickr P1070729 by jono_misfit, on Flickr pretty much finished, but may need a few light tweaks when the gear knob turns up drilled for a sping pin P1070730 by jono_misfit, on Flickr and fitted P1070731 by jono_misfit, on Flickr P1070732 by jono_misfit, on Flickr Its come out quite nicely and feels rock solid. I've got a metal blacking kit coming, so will be taking it off, cleaning, and doing a chemical black to protect it a bit. Hopefully the gear knob will fit.....
mk2cossie
Club RR Member Number: 77
The BOA definitely had cats in the downpipe section as standard. Can't remember if they had a third shared one further back tho 🤔 Either way, I'd make new downpipes from 2inch pipe, and make it where you want to go and clear things If the Escort is registered after 1994, it only needs 1 cat anyway
jonomisfit
Its interesting, when I was doing a search for Granada Cosworth catalytic converter it doesnt return anything. The only ones listed are the scorpio cosworth ones for the BOB.
I've been looking at exhaust tube / bends kits and will make something :-)
Originally it would have had 4 catalysts.
jonomisfit
Those are the bits I have (1 and 2) but none of them have cats in them. They are empty boxes.....
Unless the cats have failed and been blown out, or someone has pulled the internals out.
mk2cossie
Those are the bits I have (1 and 2) but none of them have cats in them. They are empty boxes..... Unless the cats have failed and been blown out, or someone has pulled the internals out. I think we all know what happened to the innards Also means the exhaust would drone too, as the hollow chambers cause all kinds of reverberation noises when cruising
jonomisfit
Those are the bits I have (1 and 2) but none of them have cats in them. They are empty boxes..... Unless the cats have failed and been blown out, or someone has pulled the internals out. I think we all know what happened to the innards Also means the exhaust would drone too, as the hollow chambers cause all kinds of reverberation noises when cruising 😆😆😆
yep there is supposed to be a small light off cat in the front ones and larger bricks in the ones further back.
jonomisfit
My M10x1.5 die turned up so used it to finalise the thread profile. It took a very small amount out and left a good fit on a nut P1070736 by jono_misfit, on Flickr P1070737 by jono_misfit, on Flickr I took out the last couple of threads to prevent a stress raiser P1070738 by jono_misfit, on Flickr then test fitted the internal from the gear knob P1070739 by jono_misfit, on Flickr goes on like so P1070740 by jono_misfit, on Flickr But a raw steel shaft is going to go rrange very quickly. Time for some alchemy P1070741 by jono_misfit, on Flickr some detailed instructions.. P1070742 by jono_misfit, on Flickr Basically clean for 10 mins, in the blue solution (copper selenide) for 10, and oil for 10. clean P1070743 by jono_misfit, on Flickr dried P1070745 by jono_misfit, on Flickr Just into the blue P1070746 by jono_misfit, on Flickr 10 mins in the blue P1070747 by jono_misfit, on Flickr rinsed P1070749 by jono_misfit, on Flickr de-watering oil P1070750 by jono_misfit, on Flickr cleaned part P1070751 by jono_misfit, on Flickr its come out OK. Goes well with the gear knob P1070752 by jono_misfit, on Flickr I'm going to give it a coat of matt laquer to protect it, as I think it'll corrode with time still otherwise. I need to deal with this hole as will let in fumes. P1070744 by jono_misfit, on Flickr I have this bit, which has a plastic insert, but doesnt fit my car, but is close enough to use P1070748 by jono_misfit, on Flickr I need to make a bracket P1070753 by jono_misfit, on Flickr mark out some 3mm ali P1070754 by jono_misfit, on Flickr roughly trimmed P1070755 by jono_misfit, on Flickr bent some alignment tabs P1070756 by jono_misfit, on Flickr and in situ P1070757 by jono_misfit, on Flickr and gearstick in P1070758 by jono_misfit, on Flickr I think its come out quite well P1070759 by jono_misfit, on Flickr P1070760 by jono_misfit, on Flickr Doing some brum brum noises the gearstick is a massive improvement over the original. No flex, very positive shifting, and just the right length for me.
jonomisfit
Then it was on to the sump guard whilst it accessible. I need to do this so I can make sure I position a few other things and I need to make sure they don't hit the sump guard. Club sump guards are usually made from 6mm duralluminium for wear resistance, or laminated from kevlar, but i'm making mine from a couple of pieces of regular 3mm Ali welded together. Its just there to offer a bit of protection for the lows. Going to be something like this P1070762 by jono_misfit, on Flickr mark out some Ali sheet P1070761 by jono_misfit, on Flickr trimmed to shape with the jigsaw P1070763 by jono_misfit, on Flickr got out the old sheet metal folder I made as it was big /sturdy enough P1070764 by jono_misfit, on Flickr first slilght bend in and in position P1070765 by jono_misfit, on Flickr P1070766 by jono_misfit, on Flickr the front curved bit was more of a challenge to make, but I did 5 off circa 8 degree bends to make the curve P1070767 by jono_misfit, on Flickr and then dressed it P1070768 by jono_misfit, on Flickr A bit more shaping needed, then i'll do the fixings P1070768 by jono_misfit, on Flickr
jonomisfit
Apr 10, 2023 19:49:42 GMT
I kocked some transfer punches up and marked out and drilled mounting bolt holes. P1070771 by jono_misfit, on Flickr Plate back up with temp bolts P1070769 by jono_misfit, on Flickr gives 25mm clearance to the bottom of the subframe and about 35mm to the bottom of the sump P1070770 by jono_misfit, on Flickr used some more transfer punches on the rear and marked the sump guard P1070772 by jono_misfit, on Flickr P1070773 by jono_misfit, on Flickr drilled P1070774 by jono_misfit, on Flickr with a second skin the countersink bolt will sit flush P1070775 by jono_misfit, on Flickr folded up the rear corners P1070776 by jono_misfit, on Flickr P1070777 by jono_misfit, on Flickr then onto the side stiffener plates rear sections, marked P1070778 by jono_misfit, on Flickr trimmed P1070779 by jono_misfit, on Flickr transfer to the other side P1070780 by jono_misfit, on Flickr both trimmed P1070781 by jono_misfit, on Flickr stitch welded on P1070782 by jono_misfit, on Flickr I was struggling to get nice clean welds, and after much tweaking got it running OK but not amazingly. P1070783 by jono_misfit, on Flickr in situ P1070784 by jono_misfit, on Flickr P1070785 by jono_misfit, on Flickr I may need to add slightly more clearance around the compression strut rode end from underneath P1070786 by jono_misfit, on Flickr starting to shape the next section P1070787 by jono_misfit, on Flickr P1070788 by jono_misfit, on Flickr getting the front curve set P1070789 by jono_misfit, on Flickr P1070790 by jono_misfit, on Flickr more fettling P1070791 by jono_misfit, on Flickr P1070792 by jono_misfit, on Flickr welded up and tweaking fit P1070793 by jono_misfit, on Flickr P1070794 by jono_misfit, on Flickr front needs trimmed to shape P1070795 by jono_misfit, on Flickr We'll see how I get on next sesuion.
Apr 12, 2023 11:31:34 GMT
did you buy or make the sump guard brackets the thick aluminium ones?
jonomisfit
Apr 12, 2023 11:45:46 GMT
I bought them.
I got them from a rally page on Facebook, but I think ATM / Prestige motorsport do them.
jonomisfit
Apr 12, 2023 21:42:10 GMT
Dropped the sump guard back down again and set up on the bench for welding P1070796 by jono_misfit, on Flickr started welding the side onto the sump guard P1070797 by jono_misfit, on Flickr start cutting out the other side reinforcing P1070798 by jono_misfit, on Flickr many cuts P1070799 by jono_misfit, on Flickr tacked together and clamped into position P1070800 by jono_misfit, on Flickr P1070801 by jono_misfit, on Flickr clamped ready for welding on P1070802 by jono_misfit, on Flickr adding additional welds P1070803 by jono_misfit, on Flickr back in to check what tweeks are needed P1070804 by jono_misfit, on Flickr back on the bench and stitch weld the reinforcing edge P1070805 by jono_misfit, on Flickr P1070806 by jono_misfit, on Flickr P1070807 by jono_misfit, on Flickr aaaaaaand ran out of gas just as I got the last welds done. Will need to get more as I have additional strips to fit on the sump still Sump guard back on P1070808 by jono_misfit, on Flickr P1070809 by jono_misfit, on Flickr P1070810 by jono_misfit, on Flickr P1070811 by jono_misfit, on Flickr Its coming on OK. Still pretty light in weight.
Apr 13, 2023 13:15:03 GMT
great thread this some great fabrication , not sure 3mm sump guard would be any use on the rallies i have done!
jonomisfit
Apr 13, 2023 21:27:26 GMT
Agreed, 3mm wont stand up to much. Its going to have a second 3mm skin added in key places, plus some 6mm skids / ribs applied as well. I am however now stuck waiting for material to turn up and also more gas.
jonomisfit
Apr 13, 2023 21:56:46 GMT
Today was a fill in day as I'm waiting for more gas to turn up. my box of exhaust bits arrived P1070812 by jono_misfit, on Flickr I fitted the bar I used to position the rear sump guard mounts, as this is sets the plane for the sump guard that the exhasut has to clear. P1070813 by jono_misfit, on Flickr it doesnt fit as is so needs a trim P1070814 by jono_misfit, on Flickr Oh, and this is why there is no cat present in it P1070815 by jono_misfit, on Flickr cut and cleaned P1070816 by jono_misfit, on Flickr cut a 45deg bend in two P1070817 by jono_misfit, on Flickr And added a wedge to change the angle of the pipe in two direction, and used tape to temporarily hold in place. This side has loads of space. P1070819 by jono_misfit, on Flickr This side does not.... P1070820 by jono_misfit, on Flickr not quite as bad as it looks here, but still pretty tight round the prop and tunnel P1070821 by jono_misfit, on Flickr I bought a couple of weld in silencers, however they are too big for my original intention P1070822 by jono_misfit, on Flickr nicely sized to allow the pipe to slot into it for welding P1070823 by jono_misfit, on Flickr Because its so tight round the gearbox / tunnel this side I need to make it turn in two directions P1070823 by jono_misfit, on Flickr P1070825 by jono_misfit, on Flickr I was trying to work out what I need to aim the pipe at, so put the silencer in positon where I wanted it to be P1070826 by jono_misfit, on Flickr its all very tight P1070827 by jono_misfit, on Flickr P1070828 by jono_misfit, on Flickr P1070829 by jono_misfit, on Flickr I'm not sure I want it hanging down as low as it is. I need to find some oval silencers, however they don't seem to be that easy to get hold of. I'll do some searching to see what I can find. I need to get past the edge of the gearbox so need to make a bubble. Using tape to work out centre points P1070830 by jono_misfit, on Flickr cut on lines intersecting with this and taped together P1070831 by jono_misfit, on Flickr and tacked P1070832 by jono_misfit, on Flickr goes in like so P1070833 by jono_misfit, on Flickr tight, but clears with some room to move P1070834 by jono_misfit, on Flickr I got fed up with the tapering wedge under the car, so put in the rear stands P1070835 by jono_misfit, on Flickr P1070836 by jono_misfit, on Flickr Will see how I get on next time I'm in the workshop.
jonomisfit
Apr 21, 2023 19:46:08 GMT
It been a busy week or so, but managed to get an hour in the workshop. I need a cross over pipe, but cant find anything that works for me. I have these though P1070837 by jono_misfit, on Flickr and a saw P1070838 by jono_misfit, on Flickr I need two of these P1070839 by jono_misfit, on Flickr the bends arent especially accurate so one needed a slight tweak to get them parallell P1070840 by jono_misfit, on Flickr Marking out for cutting P1070841 by jono_misfit, on Flickr cut and cleaned up P1070842 by jono_misfit, on Flickr P1070843 by jono_misfit, on Flickr second side cut P1070844 by jono_misfit, on Flickr cleaned up, tweaked, then welded the joint P1070845 by jono_misfit, on Flickr I need to tweak it a bit further , but that was all I had time for today.
Darkspeed
Club RR Member Number: 39
Apr 21, 2023 21:09:14 GMT
Nice bit of design assembly work going on there - as usual I may add - Anther reason I like mid engine and rear engine cars - no room for that sort of faffing about creative fabrication needed
jonomisfit
Haha, it's the journey not the destination for me.
Inventing side projects is what keeps it fun.
