jonomisfit
Club RR Member Number: 49
Sept 8, 2020 20:26:00 GMT
jonomisfit
Sept 9, 2020 20:28:30 GMT
brake switch wiring P1040156 by jono_misfit, on Flickr P1040157 by jono_misfit, on Flickr start tidying up the ECU loom, the diagnostic connectrs etc, are no use to me, plus AC switch and few other bits, so the ends are terminated, sealed, and then added to this dead leg should they ever be needed in the future P1040158 by jono_misfit, on Flickr then there is a second leg of things I don't need (gearbox kick down, breather canister purge etc.) so terminated, sealed, and added to a second dead leg. P1040159 by jono_misfit, on Flickr next job will be sorting out the ECU / Engine loom feeds / relays / fuses.
mk2cossie
Club RR Member Number: 77
Sept 9, 2020 20:45:57 GMT
I havent forgotten about the wiring diagram, just lacking inspiration and motivation at the moment The wiring looms are coming along nicely tho, very impressed with how good they look Do you have the AC pump and bracket going spare by any chance?
jonomisfit
Sept 9, 2020 21:33:24 GMT
No worries.
I'm pretty certain the answer to this is going to be no, but i'll check the workshop next time i'm out there as my dad dropped a load of bits off and there could be the pump and bracket somewhere.
melle
South West
It'll come out in the wash.
Sept 10, 2020 7:56:12 GMT
Any recommendations for braided sleeve? I've always used loom tape or re-used brittle original sheathing on my cars, but what you're using looks so much nicer. Had a look on eBay, but it all looks the same and varies wildly in price. I wonder how well the different types hold up in practice (read: engine heat)? I'd rather use the best I can afford, then redoing it in a few years time.
I like your sub-looms. I was always of the opinion that it was better too have less connections = less potential issues, but with decent connectors it shouldn't be a problem really.
jonomisfit
Sept 10, 2020 8:47:46 GMT
I bought mine from a company called PMG rather than eBay, I can't recommend them enough. The eBay stuff seemed very expensive for the same products.
There are a number of different types. If you look through the pics there are two types I use. The one with the white crosses through it is a slightly higher temperature one than the all black.
You can also get higher temperature again than I've used, abrasive restant, raychem style seal shroud etc. They get pretty expensive though.
I generally like as few connections in a wire chain as possible, however in this instance I'm driven by practicality of being able to reconfigure it all in the future as engines etc change.
I'll keep an eye on how it develops and if any issues arise from it.
melle
South West
Sept 10, 2020 8:57:49 GMT
Thanks, that's useful information, I'll look up PMG. Did you get your connectors there as well?
It makes sense to have at lease a separate engine loom, and I think it doesn't harm to make things like rad fans easily detachable too.
jonomisfit
Sept 10, 2020 10:22:21 GMT
It's pmgonlinecompany.
I got the connectors switches etc. from a number of places.
Automotive wiring products Car builders solutions 3 way components on eBay Bad obsession motorsport
Plus a few others
melle
South West
Sept 10, 2020 12:00:16 GMT
I've used 3 Way a few times, always been happy with their products. Will check out the others, thanks again.
jonomisfit
Sept 10, 2020 20:27:31 GMT
ECU loom termination, the main live feed for 02 sensors and Injectors, the ECU power feed, an ignition signal, and the starter solenoid trigger. The single connector is the tacho signal return from EDIS 6 module. P1040161 by jono_misfit, on Flickr
Last Edit: Sept 10, 2020 21:37:01 GMT by jonomisfit
jonomisfit
Sept 11, 2020 19:42:15 GMT
I made a central cable guide P1040162 by jono_misfit, on Flickr will rivet in here P1040163 by jono_misfit, on Flickr temp screwed in , and cable ties fitted to show how its used P1040164 by jono_misfit, on Flickr first cable fitted for linking Engine loom to centre panel P1040165 by jono_misfit, on Flickr running earths to the relays. I think i'll replace a couple of the rivets with bolts, so I can use them as earth studs, plus it will them properly earth the panel. P1040166 by jono_misfit, on Flickr starting the colum loom links. P1040167 by jono_misfit, on Flickr loom them up first so they're easier to manage P1040168 by jono_misfit, on Flickr P1040169 by jono_misfit, on Flickr sheath applied P1040170 by jono_misfit, on Flickr Terminated and sanity check against the link cable P1040171 by jono_misfit, on Flickr When i'm happy with it all there will be coloured banding applied so its easy to see what goes to what. Its about to start getting really complicated on the wiring front it think..... I've also decided I need to re-do the feeds to the switches, as most of them don't need to be switched by the ignition, they can just be fed stright from fuses. I've also realised a number of relays arent needed that way and I can use the switches directly for the low load items.
jonomisfit
Sept 13, 2020 20:41:53 GMT
I continued wiring up the panel. P1040172 by jono_misfit, on Flickr I swapped out some of the ign feeds to switches and fed some directly from fuses, and then linked some through. P1040173 by jono_misfit, on Flickr continued on with wiring up the relays P1040174 by jono_misfit, on Flickr and some more P1040175 by jono_misfit, on Flickr then worked out I can cut down on the conenction to the board if I split out the front / rear lights from a single panel connection. P1040176 by jono_misfit, on Flickr started terminating that through P1040177 by jono_misfit, on Flickr P1040178 by jono_misfit, on Flickr the panel is starting to get very busy... and its only half done. started on the link loom fom the panel to the bulkhead connector P1040179 by jono_misfit, on Flickr black and red split out is the brake switch connection. P1040180 by jono_misfit, on Flickr link out loom, the connector on the left of the pic is the feed for the rear lights. P1040181 by jono_misfit, on Flickr P1040182 by jono_misfit, on Flickr Link loom, there will be more wires (a lot more) joining this for things like fans and windscreen wipers. P1040183 by jono_misfit, on Flickr
jonomisfit
Sept 14, 2020 20:13:55 GMT
a couple of bit tonight, which doesnt look like anything, but tok a while of working out. the additional cables to add to the loom I've started yesterday.... P1040185 by jono_misfit, on Flickr suitable sizes / colours found P1040186 by jono_misfit, on Flickr prepping for braiding / terminating. P1040187 by jono_misfit, on Flickr
eurogranada
Sept 15, 2020 7:53:41 GMT
Instead of liking every single post: nice job you're doing on the wiring!
jonomisfit
Sept 15, 2020 20:19:37 GMT
thanks. Terminating last nights bit of loom. P1040188 by jono_misfit, on Flickr wipers, washers, blower P1040189 by jono_misfit, on Flickr There were a lot of extra wires for things like washer level sensors etc. which I'm not going to use, so have allocated as some strategic spares. P1040190 by jono_misfit, on Flickr task for next time is integrating these two pieces of loom. P1040191 by jono_misfit, on Flickr Its going to be a good size....
Sept 15, 2020 20:45:06 GMT
Looking good! I like the central guide plate. It makes it look tidy and avoid the risk of pulling of connectors. It is a busy place but should be avoiding electrical gremlins
Peter
Darkspeed
Club RR Member Number: 39
Sept 15, 2020 21:08:17 GMT
Nice work - It does however make me glad I am dealing with very basic circuits with my projects.
jonomisfit
Sept 15, 2020 22:14:46 GMT
I'm hoping so. And also hoping I haven't mucked up anything up...
Hopefully the morris will be more straight forward when I do that
jonomisfit
Sept 16, 2020 20:18:56 GMT
Right, to start conjoining my mess of wires into a single piece of loom P1040192 by jono_misfit, on Flickr start layering up the cables P1040193 by jono_misfit, on Flickr Start adding in the rest of the cables P1040195 by jono_misfit, on Flickr all in a bunch P1040194 by jono_misfit, on Flickr It could be a bit neater, and I think the last set I put on should have wrapped the opposite direction. Added a piece of braid to it P1040196 by jono_misfit, on Flickr and started checking the conenctor to make sure the various guages of cables i'm using fit it....
jonomisfit
Sept 20, 2020 17:26:23 GMT
wiring in the rest of the front end connections. P1040197 by jono_misfit, on Flickr checking it all lines up with the link loom P1040198 by jono_misfit, on Flickr ignition and start wired in P1040199 by jono_misfit, on Flickr i then realised i hadnt put in split out connection for the hazzard switch, so had to splice them in P1040200 by jono_misfit, on Flickr its all getting very tight... hazard switch wired in P1040201 by jono_misfit, on Flickr flasher relay in P1040202 by jono_misfit, on Flickr I then decided to re-route all the ignition feeds to the switches, as its very close to the dash panel and i've already had one cable damaged from it, this way its got much more clearance. P1040203 by jono_misfit, on Flickr relay earth in P1040204 by jono_misfit, on Flickr I think i'll just add washers / nuts to the bolts holding on the relay panels to get earth points. I'll just nee to make sure they have good contact once its all stripped and painted. fuel pumps, fuel gauge, and intercom loom. P1040205 by jono_misfit, on Flickr P1040206 by jono_misfit, on Flickr fans feeds added. I'm still undecided on using the existing temp controlling relay or using a new one, so the coiled cables are for the thermostat signal if I do mount them here. P1040207 by jono_misfit, on Flickr panel back in situ to check clearance P1040208 by jono_misfit, on Flickr its fairly busy in there but it all fits and is accessible P1040209 by jono_misfit, on Flickr panel closed P1040210 by jono_misfit, on Flickr still a fair space in there P1040211 by jono_misfit, on Flickr P1040212 by jono_misfit, on Flickr I've still got to do the rear loom connections, the bulkhead connector inside and out, and add in a switch panel feed for the co-driver panel. But other than that its getting pretty close to wiring complete...... Untill i need to fault find on it....
