flashelmer
I'm a Fiat man!
Nov 22, 2017 15:55:42 GMT
As far as I could tell, the boltholes were drilled right in relation to the centerhole, but not centered right to the middle of the rim. So when mounted on the car, it acted like a out of round wheel. Glad yours checked out fine. Mine must have been a bad batch... Ah, now I see what you mean! These have been used before so I hope they are OK... I will spin them when mounted on the car to see that they sit in the middle.
The rims have no markings whatsoever so maybe the were cast by some drunk amateur somewhere?
Cheers
The rims have no markings whatsoever so maybe the were cast by some drunk amateur somewhere? Cheers [/font][/quote] If a drunken amateur can do that I need to drink more!
1987 Alfa Milano/75 1979 Alfetta Mille Miglia 1976 Alfetta GT race car 1970 Lancia Fulvia 1.3 Rallye S 1968 Fiat 850 spider
Nov 24, 2017 16:15:44 GMT
The Abarth Grill and script look fantastic!
Nov 25, 2017 15:04:21 GMT
Brilliant idea on the center caps. Also good idea going magnesium on the spare, one can never go too light in an 850. I also use a 15 pound battery (Braille). It will be interesting to see if the the tires hold air. Magnesium wheels tend to be porous and leak down over time. Ive had good luck painting the rim inside the tire area with Glyptal or in worse case scenarios using a tube.
It's looking very good! Much respect for the hand-tooled personal touches, & for "My Way".
Keep posting!
heathrobinson
Broken everything
Club RR Member Number: 111
Fiat 850 Special - My Wayheathrobinson
@heathrobinson
Club Retro Rides Member 111
Nov 30, 2017 17:10:20 GMT
What chord will all those holes play at 45mph? Or does it play the Godfather theme as you accelerate from 20 - 60mph?
Love your car, for the rear wheel camber you could try to find some 850 spider springs. they are 1,5cm shorter then the berlina ones.
flashelmer
I'm a Fiat man!
It's looking very good! Much respect for the hand-tooled personal touches, & for "My Way". Keep posting! Thanks!
flashelmer
I'm a Fiat man!
What chord will all those holes play at 45mph? Or does it play the Godfather theme as you accelerate from 20 - 60mph? Since the sound is made by holes I’m aiming for something a bit ”cheesier” - the opening theme from the original ”The Italian Job”.
flashelmer
I'm a Fiat man!
Love your car, for the rear wheel camber you could try to find some 850 spider springs. they are 1,5cm shorter then the berlina ones. Thanks! Do you know if the coupe springs are shorter too?
heathrobinson
Broken everything
@heathrobinson
I originally put the Italian Job, but I changed it to the Godfather, thinking that someone would come along and mutter about minis. Great minds and all that!
Love your car, for the rear wheel camber you could try to find some 850 spider springs. they are 1,5cm shorter then the berlina ones. Thanks! Do you know if the coupe springs are shorter too? as far as I know the coupe springs are the same. only from the spider they are shorter
Looks great. Must be lightning fast now😁
qwerty
Club RR Member Number: 52
Fiat 850 Special - My Wayqwerty
@qwerty
Club Retro Rides Member 52
Excellent progress and a lovely looking little car.
Looking forward to seeing it with a bit of altitude adjustment.
Tom
flashelmer
I'm a Fiat man!
Looks great. Must be lightning fast now😁 I did not dare to test the high speed capabilities since I have only put stripes on one side of the car. I was worried it'd warp...
