Every time I've been to Sapporo, it's been winter, and we inevitably end up staying at a place that has a tiny window balcony for pigeons to poop on. However in winter, they load up with a foot or so of snow, and make excellent cooler boxes for the excess 'cocktail-in-a-can' beverages we come back with when we do a convenience store challenge.  Don't think it gets quite -35° cold, but when you're used to +35° it feels much the same! Enjoying all the odd jobs around the house, I'd love to do some on ours but as it's a rental, I have to be careful what we do.. I've screwed a few shelves to the wall, and dismantled a few fence panels in a way that they can be replaced easily, so we have a removable fence section that lets the dog over in to the neighbours yard for play dates.  Probably going to arrange for the same neighbour to wire in some extra lights and power in the garage over the holidays, too.
One of our motorised valves has just done the same, wondered why the pump seemed to be running all night turned out the hot water valve was stuck on, its one of 3 Horstmann ones we had, the 4th being a cheap unbranded one, unbranded one is still going strong the 3 more expensive ones all had growths and stains were they leak and have failed over time.
Fortunately for us it's the hot water, so all we had to do is turn it off at the programmer, hot water is now on whenever the heating is on but it doesen't really matter this time of year, I'll fix it when it gets warmer and I can afford to do without heating when something else breaks in the process!
Who wants to learn about satellite dishes then? No? Sorry, ‘cos that’s the topic of the day. You could just skip to the summary at the end. Mostly we watch the TV off satellite rather than the aerial. Just because that’s the way we roll here at Sweetpea towers. And, because I am dead posh, I don’t watch ITV much. I can’t stand the endless ploppy dramas and reality TV. I much prefer to watch the ploppy dramas and reality TV on the BBC ‘cos, like I mentioned, I is dead posh. Innit. Now I come to say that I think TV can be disappointing. Endless ploppy dramas and reality TV… I’ve even heard of something called a ’soap’ where all the characters hate each other and say “you’re a slaaaaaag” all the time. Why would anybody watch that? Anyway, Mrs Sweetpea’s mum is living with us and she’s not as posh as me so she’s watches ploppy dramas and reality TV on ITV. Actually at the moment she’s watching a ploppy Christmas film on Channel 5, which, speaking as a posh person, must be some sort of council TV or something? The point of all this is that ITV was breaking up from time to time and the technical department at Sweetpea towers (me) was getting complaints. A quick check of the receiver showed that the signal level had tanked and the quality was right down. Later in the evening it fell to the point that level and quality weren’t even showing on the bar graph. How on earth it was producing a picture like that is a mystery. So I popped out yesterday to realign the dish in the hope I could get some signal back. The dish isn’t a standard Sky jobbie that you can point vaguely upwards and it’ll probably get something. It’s an old splop one I pinched from work years ago to do some testing at home. It’s a bit bigger than standard. The up side is that it gets more signal than a standard dish so it doesn’t drop out when the atmospherics get a bit messy. The down side is that it has a narrower acceptance angle so it doesn’t take a massive knock to misalign it. Anyhoooo, the dish hadn’t moved. That’s very bad news because it means I know what the actual fault is. To hide the dish on the back of the garage I let the ivy grow round it. Every now and again I cut the ivy back with the hedge trimmer. Well, at some point in the distant past I’d clipped the cable with the hedge trimmer.  Oops. I guess it’s finally failed. Bumhats. Here’s mr dishy mid way through rewiring the cable.   I said it was old. Works ok though. I know what you are saying… If the cable had failed I’d have lost all the channels to the receiver not just some of them. We’ll, that’s the other thing that’s different about this dish. Normally you get a choice if four signals down each cable. High Band - Vertical, High Band - Horizontal, Low Band - Vertical, and Low Band - Horizontal. The receiver sends instructions back up the cable to tell the LNB (the grey bit on the front of the dish) which of the four it wants. This is a commercial LNB and the 4 cables carry the 4 signals - no switching. That means that something else needs to interpret the instructions from the receiver and send it the correct signal. That’s done by this switch thing in the garage.  The advantage of doing it this way is that you can stack loads of these switches and run dozens or even hundreds of receivers off one dish. I don’t need that but it’s just how this particular LNB works. In a standard domestic LNB the switch is built into the LNB itself. That does mean that when I damaged the cable I only lost signal on some channels rather than all of them. It also explains the coloured cable ties because the order of the cables between the LNB and the switch is critical. I think it was high band, vertical that suffered the worst damage although I wasn’t paying a lot of attention. (In much the same way as I wasn’t paying a lot of attention when I was using the hedge trimmer all those months ago.) Anyway… Replaced the two cables that I’d had an accident with. Had the F connector fall apart on a third cable so that got replaced too.  I’ve grown to really hate F connectors. Horrible things. And now Mrs Sweetpea’s mum can watch trashy rubbish on ITV again. Why did I fix that!? She’ll never bloody leave. So how badly damaged was that cable?  Yeah. It’s toast. To be honest I’ve never understood radio frequency systems. The signal gets 22,000 miles from the satellite to the dish and then can’t jump the 1mm gap where I cut the cable with the hedge trimmer? How can that be? Summary at the end… Replaced cable. TV working again. Mother in law happy. Never going to leave. James
Last Edit: Dec 5, 2020 18:35:55 GMT by Sweetpea
jpsmit
Don't understand any of this but love it just the same. Years ago a friend's kids hamster died. They had a little funeral in the backyard and then a little TV to relax - except he cut the TV cable digging the grave.
Last Edit: Dec 6, 2020 1:34:21 GMT by jpsmit
jimi
Scotland
Very similar setup with a quad LNB to ones I worked with offshore, last rig I was one had 20+ sky boxes and 20+ Freeview boxes. Due to the distance involved between dish (which tracked the satellite as the rig moved) and the the accommodation block, the LNB signals were multiplexed, converted and sent down a fibre optic cable, this was reversed at the other end and fed into the receivers, the output from the receivers was then multiplexed and distributed out on a single coax to the TV's.
Don't understand any of this but love it just the same. Years ago a friend's kids hamster died. They had a little funeral in the backyard and then a little TV to relax - except he cut the TV cable digging the grave.   Poor sods! But I can't help laughing at other's misfortune though! I'm just cruel. A friend of mine cut himself off the internet recently while gardening. The idiot installers put the cable through a flower bed a couple of inches down. They went through it with a spade. Very similar setup with a quad LNB to ones I worked with offshore, last rig I was one had 20+ sky boxes and 20+ Freeview boxes. Due to the distance involved between dish (which tracked the satellite as the rig moved) and the the accommodation block, the LNB signals were multiplexed, converted and sent down a fibre optic cable, this was reversed at the other end and fed into the receivers, the output from the receivers was then multiplexed and distributed out on a single coax to the TV's. Yeah, this is quite old tech which is why it's screwed to my garage. We use fibre optic LNB's these days although it's no longer my problem so I can ignore it all. One coax just for power and a fibre for all the signals. Tracking dish? Hmm. nice. I've never had to play with them. Years ago we were trying to pick up a Russian TV channel from an old Russian C band (if I remember rightly) satellite. We had a huge dish (by my standards) about 2 or 2.5 meters. The acceptance angle was really tight so it had to be accurately aligned. The problem was that the satellite was running out of fuel and the Russians weren't holding it tightly in orbit to try and extend its life. Over a 12 month period it performed a vertical figure of eight motion in the sky and twice a year we had to move the dish up and down to follow it as it wondered out from in front of our dish. Ah, the good old days!
Dec 16, 2020 10:54:50 GMT |
This is rather interesting - well to me anyway.
In a Bear Grylls type survival tip, if you find yourself in an urban jungle in the UK with no compass, if you ever want to know which way is south so you can find which way is north, just look at all the sky dishes. They all point south, presumably to the equator or a somewhere in the northern hemisphere anywya.
jimi
Scotland
The Astra 2 satellites are more South East than South (28.2deg East of South) and are geostationary roughly over Europe
Similar here but no one uses satellites, so look to see which side of the house people's solar panels are on.  Majority should be facing northish so they get the most sun.
Dec 17, 2020 10:22:46 GMT |
Similar here but no one uses satellites, so look to see which side of the house people's solar panels are on.  Majority should be facing northish so they get the most sun. You confused me until I worked out you were on one of the counterweight continents. James
Dec 20, 2020 21:33:19 GMT |
If you are wondering why I’ve not been talking to you, it’s largely because I’ve not done much. However… Today… Remember that fence thing round the decking?  Yep, that’s the one. Remember I hadn’t cut the newel posts to length? Remember that Mrs Sweetpea was talking about putting lights on the top but I didn’t want them? And, besides, we couldn’t find any that we liked. Then Mrs Sweetpea found a photo of a post top shape that she liked. I liked it too. And it meant a total of zero lights to try and fit. First job was to knock up a prototype so I could see what it looked like and to get the shape right.   There you go. It took a couple of goes to get the angle of the top but eventually it looked right. Lovely. Happy with that. What’s not to like? Well there is one thing not to like. When I was simply thinking of cutting the post tops off I was concerned about getting the cut square and tidy. I reckoned I could do it by hand with panel saw if I was careful. But that ^^^ - no feckin’ hope! Easy enough on the table saw in the garage but totally impossible with the posts in place. So that means the railings have to come off, the decking around the posts comes up and the posts are removed. Having just nicely got the bloody thing together the last thing I wanted to do is take it all apart again. Oh well.  Apart, it jolly well came. I’d marked the top of the railings on the posts before I’d taken them off. Then I measured 10cm up and cut the posts to length. All the measurements are then worked from the top down. I needed an accurate diagram with measurements first. So using the prototype as a guide I produced a bit of cardboard with pencil marks on it.  That done I just set the fence on the table saw according to my diagram, set the blade height, did a triple check that I’d got everything square and pushed it over the blade. Once round all 6 posts then you move the fence to the next measurement and do it again.   Now a challenge. Cutting the point on the top.  Setting the blade angle was the easy bit. When I made the prototype I used a stop on the saw and butted the bottom of the prototype post against it. Then, each time I rotated the post round for the next cut, so long as the bottom was against the stop all the cuts would be in the same place. But that doesn’t help me now. Firstly the real posts are much longer and the bottoms are nowhere near where the stop can get to, and secondly the posts are all different lengths anyway. What I need is for the angle cuts to be referenced to the slots I’d just cut. Hmmm. Hadn’t thought of that and I don’t know how to do it. What a conundrum. Only one thing for it. Go sit on the loo and think about it for a while. Eventually I had an idea and built a ‘thing’. (I built the ‘thing’ in the garage, not while sitting on the loo. Mrs Sweetpea objects to having bits of steel piled up in the toilet. I keep telling her how productive I could be but the argument falls on deaf ears.)  The edge of the angle drops into the slot I’d cut and it nicely clamps to the existing stop on the saw. With this, not only will all 4 cuts on the top of this post be in the same place but all 6 posts will be identical. God, sometimes I’m so clever I surprise myself!   Seems to be working. So here are 6 posts ready to go back into the decking.  The green tint is the stuff that, apparently, stops the cut end grain from rotting. The colour also gives a bit of definition to the slots so, by happy accident, I quite like it. Chances are it’ll soak in and lose a lot of its colour. That’s what seems to have happened elsewhere. I’ve actually fitted the posts again (not the railings yet) but it was dark by the time I’d finished so no photos. When I come to fit the railings again I’ll have to deal with the fact that half the screws broke off. Really. Hmmph. James
Dec 20, 2020 22:10:09 GMT |
Nice work! However, isn't the point of a separate capping (usually with straight grain facing upwards) to protect the end grain of the post?
Dec 21, 2020 19:55:31 GMT |
Nice work! However, isn't the point of a separate capping (usually with straight grain facing upwards) to protect the end grain of the post? Yeah you're quite right. And if the post tops go soggy they'll get chopped off and a cap put on. That said I doubt if there'll be a problem. The posts are really tight grained and the table saw doesn't fuzz them up. (Even though the blade is blunt to the point of being totally borked.) We've also got some old wooden posts in the garden. Some have caps on, some don't. All the caps are rotten yet the posts without caps are fine. The bottom of all of them have rotted off though! I think the short answer is that wood is a bit hit and miss but I'm optimistic that, even without caps, it'll be quite a few years before I need to worry about it again. I suppose the other thing I've learned is that if you want wood to last in the garden, make it out of brick! James
Dec 27, 2020 16:35:15 GMT |
Happy Christmas y’all! And a happy new year when it turns up. I managed to get the railings back on the decking just before Christmas.  Yay! So that’s a project finished! And I did it before Christmas. Hurrah! I know it’s only a little area and it’s taken a quite mind bending amount of time but I’m quite pleased with it. Thank God it’s done though. I mentioned that when I took the railings off the posts some of the screws broke. Well not really ‘some’. More ‘a solid half’ of them broke.  Some of these broke as I took them out. I could actually hear the ‘tink’ as they broke. These came with the brackets that were to fix the railings to the posts. I think they have been treated some how to stop them rusting and it’s left them very brittle. I’ve put stainless back in which have a reputation for breaking off but they are better than these green things. I don’t know if you can see it but the broken off ends actually look like they have a crystalline structure.  I’d love to know how these had been treated. Poxy useless things. So the other thing I’d been up to was a secret ‘cos I was going to wrap them up as a present for Mrs Sweetpea. Now I can’t imagine that she reads the drivel that I write so I was probably safe, but still. In fact I’m not sure that she always listens to the drivel I speak either. I suspect an element of accidental deafness is probably the key to a successful marriage. Anyway. When I made the oak architrave for the doors upstairs I wound up with a few off cuts. They were about 3/4” square and about 7’ long. So that’s, I don’t know, 1.5cm square by the thick end of 2 meters long if you’d rather have it in new money. Basically this, but longer.  Totally useless then. So they sat at the back of the garage waiting for me to chop them up for fire wood, a job I never got round to doing. And besides, I don’t like chucking things away. They must be useful for something? Surely? Don’t call me Shirley! (It’s an old joke but so am I.) Well. The first thing I could use them for was to run them through the plainer, cut them to length and glue them together to make a little chopping board.  Sweetpea Towers isn’t short of chopping boards. Cook makes sure there are plenty of them. But there’s always room for another. Chopping boards are like pencils, you can never have too many. Then I needed to let my artistic juices flow. When Mrs Sweetpea buys grapes from the posh online grocery store she tends to wash them off under the tap and then they go back in the little plastic tub. The problem is that they don’t dry again and have a tendency to go soft and mouldy. This is a shame because I like grapes, but not the mouldy ones. So I conceived this idea of a “grape tree”. It was going to have a base and then a trunk with branches coming off it. There would be hook on the end of each branch to put the grapes on. They would then dangle in the air in the way that grapes do when you see them on the vine. So, in my head, it was to be a semi natural looking thing. Made from more of those off cuts of wood but skilfully blended to make a trunk and branches. But then, when I had bits of wood in my paws, the reality of trying to turn them into what was in my head dawned on me. Lets say the design ‘evolved’ a little and what was initially conceived as a natural looking thing morphed into a piece of modern sculpture.  I can’t decide if I like it or not. It’s a very engaging thing to look at, quite tactile when you fondle it, and I find it quite fascinating. But I can’t decide if I actually like it. I don’t even know if it’ll hold grapes if I’m honest. We haven’t got any so I can’t try it. Anyway Mrs Sweetpea seems to like it. But she’d bought a wire fruit basket so we may not even need a grape tree. Whatever one of them is… But fear not because Mrs Sweetpea might hang necklaces on it instead of grapes. So, if I might be allowed to sum this project up… I had an idea and built something totally different that might not even get used for the intended purpose. I’m not sure if that qualifies as a success or not. Funny old world isn’t it? James
A few years ago this thread started, just in the new year, with me fixing the Christmas lights. It’s new year again and…  It’s almost as if it happens every year. An annual event. Happy new year by the way. I can’t fix all the lights because half of them are still dangling from the house and I need to get the ladders out. Any of you living in the bottom right hand corner of the country will know it hasn’t stopped raining in, well, it feels like decades. I think the weather will improve later in the week so I can look forward to fixing more lights. Remember the clock I pinched from work to try and get it running? Well, apart from a bit of testing to see how well it locked to the mains it was done.  Nearly. Once it goes high on the wall in the workshop there’ll be no way to adjust it. I needed buttons to set the time. Remember that the computer that runs it (an Arduino) doesn’t know where the hands are pointing so the best I can do is fast forward it and stop it.  There you go. Buttons. And lights. The one with the yellow light tells the clock if you want to go backwards or forwards. For backwards it just stops for a while, for forwards it runs at double speed. The other five buttons move it a set amount of time. The left one is one hour (for summertime changes), the right one is one second. The others are varying amounts of time. The coolest thing is that it actually seems to work! I’m going to run it on the table for a while to see how it keeps time. When it goes back to work I need to tidy it up and get it in a box. I say “when” but who knows how long that’ll be. I’m getting very used to working from home. Won’t want to go back to commuting. James
Back a post to the nails you mentioned, I’m pretty sure it’s a ‘sheradised’ coating.
jpsmit
Back a post to the nails you mentioned, I’m pretty sure it’s a ‘sheradised’ coating. Not exactly sure what that means - looked it up and i still don’t understand- however they are designed to be single use brittle screws. The brittleness is so that installers can break off protruding screws with a sideways swipe of the hammer rather then be slowed down. They are particularly useful for drywall applications - if you have ever demolished a drywall wall it is so easy to just go along and break them. Likewise i expect that the manufacturer doesn’t expect anyone to draw out the screws from drywalls or decks.
Back a post to the nails you mentioned, I’m pretty sure it’s a ‘sheradised’ coating. Not exactly sure what that means - looked it up and i still don’t understand- however they are designed to be single use brittle screws. The brittleness is so that installers can break off protruding screws with a sideways swipe of the hammer rather then be slowed down. They are particularly useful for drywall applications - if you have ever demolished a drywall wall it is so easy to just go along and break them. Likewise i expect that the manufacturer doesn’t expect anyone to draw out the screws from drywalls or decks. It’s basically a process like galvanising using a zinc as the coating, obviously just to prevent rusting of the actual metal. From my experience that green kind of colour the op mentioned usually points to a sheradised coating process
Jan 21, 2021 19:09:58 GMT |
I like them posts with the slits in them. Almost look like the slits should have lights coming from them!
Happy New Year by the way!
So I looked up coating things with Shreddies. I think they'd go soggy... Happy Easter toast00 ! I haven’t written much recently. Well… Remember the ‘grape tree’? Waddya mean no? I’ll remind you. Grapes were going mouldy in the plastic tub they come in after Mrs Sweetpea washed them. They needed to hang out and dry. So I made Mrs Sweetpea a ‘grape tree’ for Christmas.  I had an idea of a very natural tree like thing and, as you’ll have noticed, that’s not what happened. So, the question you are all itching to ask is… Does it work.  Not only does it work but… BUT… It also works for those small posh tomatoes that Mrs Sweetpea likes. I did see, while taking that photo, that the grapes needed eating. So I ate them. Mrs Sweetpea really liked the grape tree but, sadly, it had already been superseded even before I built it. We’d bought a wire fruit basket thing which has one major advantage over the grape tree. It can cope with the grapes that have fallen off the twigs. Anyway, Mrs Sweetpea said it’d make a really good necklace stand if only I could put some stick things in the slots to hang the necklaces on. Cleverly I realised that if I did that the necklaces hanging off the top level would stop you using the bottom level. So I actually did this…  What I really like about this thing is the way it’s morphed into something really odd. It you went to make a necklace stand it’d be a cross at the top of a post. But because of the design process and change of use it’s turned into something much more interesting. I like it. And Mrs Sweetpea likes it too. Happy days! What else? In the MR2 thread I said that Santa had brought me a spray gun.   If I want to use this I need to replumb my compressor system. I’ll explain the details in the MR2 thread some other day. But there is no chance of doing that because it’s physically impossible. The garage is chock full of 20 years of plop. Essentially I’ve never thrown anything out. I need the mother of all spring cleans. Bin loads of stuff and replace a load of shelving with something more useful. I’ve hardly started but the garage looks like a bomb has gone off.  And it’s going to get worse before it gets better. Oh, and the garage trolls have pinched the nuts off the bolts that hold one of the casters on my tool box. Either the trolls did it or it was the butler. But I asked him directly and he denied it. “Stubbings”, I said, ‘cos that’s his name, “Stubbings, have you been fiddling with my nuts?” He looked a bit shocked that I should make such an accusation. “Oh no sir”, he said, “You’ve totally misjudged me sir!”, and then mumbled something about him flirting with Mrs Preston the house keeper. Honestly not sure how that’s relevant. So I guess it was the trolls. James
Last Edit: Feb 3, 2021 22:08:02 GMT by Sweetpea
