Sept 16, 2024 8:29:52 GMT
I've already checked that by blanking the iacv pipe off and it was still there.
Ive just had a Honda loving friend message me and told my to check my tb, especially the idle bleed screw. Apparently this whistling is a very common problem with Hondas that use the sand tb I have ie civic, integras, crxs etc etc. Quite a lot of threads about it.
Sept 16, 2024 9:42:17 GMT
ah excellent !
Sept 16, 2024 20:22:31 GMT
The whistle is probably in the throttle body. Did you drill any extra holes in it for vacuum take-offs?
Vitesse EFI had such a whistle on very light throttle with a small range of variable tone over a short section of travel. Wasn’t enough to be irritating (sounded almost like a turbo spooling), so I ignored it for 20 years. It went when I fitted ITBs but, bizarrely, when I returned to the original plenum setup recently the noise has gone, even though I’ve simply bolted the whole lot back onto the head exactly as it was….
Sept 16, 2024 22:16:48 GMT
There's no extra holes anywhere. The vac signal is from the standard pickup on the honda TB. Should I just fit my itbs.....
Sept 17, 2024 10:09:57 GMT
There's no extra holes anywhere. The vac signal is from the standard pickup on the honda TB. Should I just fit my itbs..... Oh yes, yes, definitely ...
Sept 17, 2024 18:42:46 GMT
There's no extra holes anywhere. The vac signal is from the standard pickup on the honda TB. Should I just fit my itbs..... I think this might be the solution you're looking for
teaboy
Make tea, not war.
Sept 17, 2024 20:53:29 GMT
Should I just fit my itbs..... I think this might be the solution you're looking for Or is it the solution that WE are looking for?
mk2cossie
Club RR Member Number: 77
Sept 17, 2024 20:59:14 GMT
I think this might be the solution you're looking for Or is it the solution that WE are looking for? Either is the correct answer if the question is "should I fit ITBs"
Sept 17, 2024 21:01:57 GMT
Sorry to hear your throttle body is irreparable. If you were to have 6 separate, some might say individual throttle bodies no doubt the chance of failure would reduce. I note the Valkyrie appears to have 6 28mm carbs that could possibly be repurposed.
Sept 18, 2024 8:49:41 GMT
Sorry to hear your throttle body is irreparable. If you were to have 6 separate, some might say individual throttle bodies no doubt the chance of failure would reduce. I note the Valkyrie appears to have 6 28mm carbs that could possibly be repurposed. If you need one set of parts from Valkyrie heads, you should order the whole set to save on postage. Nothing at all to do with the racier cam and solid lifters that brings as well. Honest. Purely for financial efficiency. Yours sincerely Team Scope Creep Subsidiary of Enablement Corp Ltd., Pusher Lane, Hoarderton, Spend, DO1T NOW
jimi
Sept 18, 2024 15:45:17 GMT
Sorry to hear your throttle body is irreparable. Confused, did I miss something ?
Sept 19, 2024 15:55:41 GMT
Sorry to hear your throttle body is irreparable. Confused, did I miss something ? Shhhh, we're trying to convince him to buy go-fast bits he doesn't strictly need
jimi
Sept 19, 2024 20:47:38 GMT
I think he already has them
Sept 20, 2024 1:01:48 GMT
I think he already has them yep- I do indeed. But ssssssshhhh. Keep it a secret
mylittletony
Club RR Member Number: 84
Sept 20, 2024 6:38:22 GMT
yep- I do indeed. But ssssssshhhh. Keep it a secret Oooh, you're building a flat eight out of 2 sixes - can't wait for that!!
