Cool build.
I enjoy reading this buildthread.
Re-reading your posts, I came across this one about your scuttle panel.
"Also fibreglass panel is for LHD car so wiper housing area needs moving."
Sometimes it is beneficial to use the wrong side wipers on a race car.
They cover less glass on the pass side, but sometimes the pass side works better because the blade is more in line with the airflow.
scmick
Mar 26, 2021 14:19:41 GMT
Good point but among my stock of spares I've found a decent RHD wiper motor and mechanism that I've fitted. My orange SIMCA racer which is LHD has only a single wiper fitted on the driver's side.
scmick
Mar 29, 2021 19:29:56 GMT
The master cylinders in the SIMCA 1000 originally fitted under the dash either side of the pedals. Obviously done to leave the front compartment free as a 'boot'. Access under the dash is minimal and the original SIMCA cylinders aren't easy to get nowadays. This car's front end simply houses the fuel tank and radiator so no problem to have master cylinders poking through the bulkhead in a more 'normal' layout. Have adapted pedal box and operating rods to house wilwood cylinders. This will also get rid of the SIMCA clutch cylinder which uses a plastic pipe with 'dodgy' connections and using unions with a really obscure sized thread.
Last Edit: Dec 29, 2021 11:36:07 GMT by scmick
scmick
Have fitted master cylinders and was going to get all brake pipes fitted but a bit of welding under my SIMCA pickup turned into a much bigger job. See thread on here. The pickup is so handy for parts chasing so this project is on hold for a while... French car rust...!!! still it's no worse than the terminal rot i had to deal with on the Triumphs and Ford Anglias & Capris I used to be into...
scmick
Dec 29, 2021 11:34:08 GMT
Now the pickup is welded up and back on the road along with my SIMCA 1000GLS, I can start thinking about getting back to the lightweight project. I had quite a find recently. The car I'm working on was once a spare shell I prepared when I was racing. Sold on when I got the SIMCA 'Youngtimer' racecar, It came 'home' to me years later in a right state without the cage. I'd adapted a rear cage I had to fit but was never really satisfied with it. Recently on Ebay a NOS 'Sabelt' 6 point bolt in roll cage to fit SIMCA Rallye 1 & 2 came up. Lightly surface rusted from storage but with main hoop in later FiA spec 50mm dia tubing and fitting kit and at the right price plus free delivery from Border Minis in Cumbria, It was too good to miss. JUst when I thought reserves of SIMCA 1000 parts were drying up in the UK..!!! Just need some fine weather now as the garage is full with my SIMCA Rallye 2 in bits.
Last Edit: Dec 29, 2021 11:37:01 GMT by scmick
scmick
Jan 17, 2022 21:14:52 GMT
Correction to above post.. The tank conversion is on my '72 SIMCA 1000GLS. I should have added to the thread on that... the old brain malfunctioning...!!! I'll put this where it should have gone..!!!
Last Edit: Jan 18, 2022 9:56:21 GMT by scmick
Feb 14, 2022 11:07:10 GMT
Looking good!
Not sure what the original capacity was, but 6 gallons (27 litres) should be a fair chunk of weight saving for a sprint car. Petrol's not quite as heavy as water, but you tend to lug around a lot of it!
scmick
Feb 14, 2022 21:08:25 GMT
Putting the fuel tank in the front of a rear engined SIMCA helps even the weight distribution out too. My Rallye 2 racer has a large capacity fuel cell right at the front. The capacity isn't needed for the trackdays I now do but was essentail for its original German owner when he was doing long races at Nurburgring, Spa, Hockenheinm etc in the 'Youngtimer Trophy' races ...
Feb 14, 2022 22:49:32 GMT
Putting the fuel tank in the front of a rear engined SIMCA helps even the weight distribution out too. My Rallye 2 racer has a large capacity fuel cell right at the front. The capacity isn't needed for the trackdays I now do but was essentail for its original German owner when he was doing long races at Nurburgring, Spa, Hockenheinm etc in the 'Youngtimer Trophy' races ... I remember this syndrome well with my late father's Imp a full tank and a 2" thick 2' by 2' paving slab ballast in the front boot helped handling enormously especially in windy conditions. I suspect that a negative camber kit would have made an even greater difference as fitted to a friend's rally Imp but his remained as standard.
scmick
Feb 15, 2022 11:34:58 GMT
The orange SIMCA racecar was built and raced for many years around Europe in the 1300 class of the 'Youngtimer trophy' by Frank Breidenstein, top engineer at Porsche. He obviously used his vast rear engined car experience on it. Loads of weight is moved forwards with a huge radiator in the front under the fuel tank. Also, he adapted the SIMCA's transverse leaf spring front suspension, replacing the multi leaf spring with a flat single leaf and then replacing the original shockers with adjustable coilovers.
Also, he adapted the SIMCA's transverse leaf spring front suspension, replacing the multi leaf spring with a flat single leaf and then replacing the original shockers with adjustable coilovers. I've been weighing that up as an option for my Spitfire. Reduce the rear transverse leaf to a single length for location (or replace it with one of the fancy fibreglass leaves from America), and run coilovers in the original shock positions. Can't decide whether the added ease and lower cost of adjustability is worth the additional weight...
scmick
scmick
scmick
Jan 11, 2024 21:49:32 GMT
Roll cage now in, made easier as I'd welded thick plate into edge of footwells to mount original cage years ago before this shell went on its 'travels'. Just a matter of drilling and tapping to mount this one but might add a bit of weld to feet and edge of windscreen pillar to stiffen things up further. Spotted a bit of welding needed where rear jacking point once fitted, a regular SIMCA 1000 rust spot. Did other side years ago. Years of standing has seen off a bit more of SIMCA's original metal..!! Hoping to get on to fitting steering column, pipes for brakes and cooling, gear change rods, handbrake etc etc very soon. If we have a snowy spell have always got Ransomes tractor in garage to work on.
scmick
Jan 13, 2024 17:49:10 GMT
scmick
Jan 25, 2024 17:58:09 GMT
Jan 26, 2024 15:19:46 GMT
Replace the jacking points with sill stand tubes much safer and easier for track work
