I can't believe the woeful mpg of the invicar, I would have expected 50+ given its capacity and weight! Did the person keep your old lada or try to sell it straight on? I always thought other than the heavy drive they were a perfectly adequate car and quicker off the mark than people expected. Mid to high 30s seems to be the order of the day. I think economy takes quite a kicking due to the CVT more than anything else, plus it is pretty low geared. We'll see what figures we actually see on some decent runs as time goes on. My personal day to day MPG is always likely to be poor as Milton Keynes is absolute murder on economy in any car. The average is so low on my example so far as I was having issues with the carb for a while and after it was replaced it was immediately obvious that the ancient CVT belt I'd been running had been dragging a lot as both economy and performance improved massively. I think the Lada was moved on again after a couple of months, though the guy I passed it on to tends to switch and swap cars quite frequently. She wasn't a bad drive to be honest, especially with the fuel injection conversion done which provided a massive improvement in the mid-range torque delivery. Vastly improved the drivability of the car, especially in traffic. The Riva has always been a bit prone to driveline shunt, and previously a lack of low end torque combined with that made driving in traffic tiring. Once the injection system was in place you could deal with crawling traffic without even needing to go near the throttle thanks to proper idle speed control. I think the biggest issue I had with it was largely just where I live. Heavy brakes, steering and somewhat ponderous handling get wearing in a hurry when driving around Milton Keynes.
Finally got around to building up the enclosure for the distributor condenser for TPA today. The 0.22uF caps still haven't arrived, so I've just made up a dual 0.1uF cap. As it will be living in a large enough enclosure there's really no issue with this. Given the application vibration was something I was wanting to put a stop to, so the innards of the box have been well and truly secured in place with plenty of hot glue. The capacitors are actually a nice snug fit between the outer of the case and the posts that the terminal strip sits on anyway, so it's just belt and braces really. Under no circumstances should the capacitor leads have any load placed on them. I've also tried to ensure that anywhere that the wiring in the box is touching anything that it's held in place so we can't have any issues with things rubbing through over time. It looks messy, but that's kind of the curse of hot glue. The lead that you can already see connected is the ground connection, which is just going to a ring terminal which will be secured under one of the mounting bolts. You can also see that there's more than just the condenser in here - that's because I'm also using the enclosure as a convenient location to fit a remote engine start button for use when I'm doing testing in the engine bay. If I find I have issues with the plastic enclosure cracking I'll replace it with a metal one. It just seemed like plastic was less likely to dissolve the first time it got wet. Drilled and tapped a couple of holes for it to attach to in the engine bay (okay...Three holes because I totally fouled up the location of the first one and the enclosure would have had to be halfway into the space occupied by the voltage regulator) and hooked it up. Still need to install the wiring for the starter button but the distributor side is all hooked up now. I had planned to get the starter hooked up as well but by this point I'd completely lost all feeling in my fingers so retreated back inside! It's a small detail but it's really nice to have got something on the car side of things ticked off again as it's been a while. Plus this gets rid of my cable-tied bodge from a few weeks ago and is far tidier. It looks a bit new and shiny in the engine bay at the moment but once it's got a bit of road dust on it it'll blend in just fine. Plus I'm more interested in long term reliability and things which make it easier to live with than absolute originality. I really do need to rebuild the rear of that wheel tub sometime too...
Tamber
Shattered. Held together by spite and tape.
Now that is an absolutely fabulous photo.
-< Welder. Allegedly a mechanic. Bodger of Things >- * 1958? Bedford RL - Progress: Glacial. * 1994 Skoda Favorit - It's baaaaaaaack! * 2018 Herald Classic - Off the road, indefinitely.
Re: The Box- why not put a kill switch on it for the ignition too? Then at least you can put the key on, start and stop it from the engine bay. Would add a small increase in security too. Very small.
Phil
Last Edit: Jan 5, 2021 23:50:55 GMT by PhilA
Re: The Box- why not put a kill switch on it for the ignition too? Then at least you can put the key on, start and stop it from the engine bay. Would add a small increase in security too. Very small. Phil I might do. Though usually if I want to stop it I usually just pull one of the coil wires...I'm just a bit reticent to add additional components which have the opportunity to cause problems if they fail. -- -- -- Despite successfully finishing wiring up the condenser enclosure and getting the remote start button working yesterday the day ended rather depressingly when I managed to lock the keys in the van. I also discovered that the battery charger I thought I had repaired following it going bang quite spectacularly a couple of weeks ago is still broken...and was actually sucking juice out of the battery rather than charging it. I know there are three conventional chargers in this house, but could I find one? Not a chance! I don't have a full set of spare keys for the van. I've been meaning to remedy this for a while but it's never made it to the front of the to do list. Biggest stumbling block was that Timpson's (etc) couldn't apparently source a blank for the key for the actual van bit. Apparently you'd need to get it direct from Mercedes for stupid money. As other jobs took precedence I never really chased that up. With the keys I did have, the only useful thing I could get into was the gas locker. My plan was to unbolt the draining board which sits above the locker, climb into it, then reach up through there to get hold of the keys - assuming they were sitting next to the sink where I thought I'd left them. Of course just to add to the fun, all the blinds were closed so I couldn't see! This plan then encountered another frustration when I went to pick up the 8mm spanner. It should be on the hook nearest the camera. Last time I used it was when I was rebuilding the Jag's wiper motor...in the van. Ah. After far too long wrestling with an adjustable spanner that was far too big for the job at hand I had the draining board out - at which point the 8mm spanner I'd mentioned earlier bounced off my forehead and everything I'd left stacked on the draining board cascaded onto the floor inside. Now I'm not flexible enough to actually climb through that hole, but I thought I knew where the keys were, so should be able to reach them. Thank goodness for that! I was just able to reach them at full stretch. Sorted! Then I just had to tidy up the mess I'd made and reassemble what I'd taken to bits. With the van back together and now accessible I was able to dig out the backup backup battery charger out of the service locker. So basically back to where I was hoping to be when I wrapped up yesterday! It's a cheap and nasty thing but will do just fine for a bit of a boost. Think everything is struggling a bit just between winter and lack of regular use. At least this minor bit of work on the Invacar is now done...assuming it still runs fine anyway!
And yet another timely reminder for me to put the battery on charge when I finish play today! I locked my keys in the boot once, luckily I was doing an interior clean so the doors were open, but I still had to dismantle the rear seat via rounded bolts and squeeze between the seat frame!
And then a week later I found a spare key wired to the oil cooler!
glenanderson
Club RR Member Number: 64
Reminds me of when I used to have to break in to the RVs at work after people had locked themselves out. Through the side lockers and out from under the bench seats. I was the only person skinny and flexible enough to do it. That was twenty years ago though; I am still skinny enough, but I doubt I have the flexibility anymore. 🤣🤣
Reminds me of when I used to have to break in to the RVs at work after people had locked themselves out. Through the side lockers and out from under the bench seats. I was the only person skinny and flexible enough to do it. That was twenty years ago though; I am still skinny enough, but I doubt I have the flexibility anymore. 🤣🤣 Wouldn't work for me sadly, the side locker is shallower than my shoulders and ribcage... there's also a brace right in the middle of the area I'd need to squeeze through.
Jan 17, 2021 18:35:30 GMT
New webpage now online for the Casio PF-3000 Calculator and Data BankAn interesting little device from back when the designers hadn't quite figured out what form what we came to know as the PDA would take. Noticed one typo already I'll need to go back and sort later...but think it's mostly done.
Jan 23, 2021 21:20:41 GMT
I've been doing a bit of a poor job of updating things on the cars lately, though mainly because not a huge amount has been going on. It's a good time I've found to start ticking off a few of the jobs which had been waiting for the right time to happen and/or further information. One of these jobs was replacing the rear brake hoses on the Invacar. While the rubber on the ones on there seems fine, the ferrules are quite crusty and I've just never fully trusted them given their age. Despite them passing the "literally having me hanging off the brakes with my entire body weight" test without any signs of distress. However the tricky part there was figuring out what I needed to buy. My original plan had been to take one off the car (or one from a spares stash a friend has) to a local hydraulic specialist and have them make me up a set using the original as a template. This turned out not to be necessary however as someone else had found a Girling cross reference catalogue which showed the part number fitted. The rear brake hoses on an AC or Invacar Model 70 is 64047355. A bit of digging around has confirmed that this is the same as the front brake hoses used on the single master cylinder equipped versions of the Mk I Triumph GT6 (among others...but this seems to be by far the easiest one to find parts for). After initially getting one wrong part delivered (which turned out be a foul up on my part) I got the correct parts ordered. That was at 16:34 on Friday afternoon, through the eBay shop of MEV Spares...The package dropped through my letter box a couple of minutes past noon the following day. That's some speedy service! Their part number for those playing along at home. Perfect weather to be working on cars. Despite being in the garage, with the door deliberately left out a bit to provide an overhang, and inside a car, the snow STILL managed to find ways to get down the back of my collar and into my right ear while I was working. What then followed was the best part of two hours swearing at this thing. The nuts securing the hose to the chassis and suspension arm fought me the entire way off. Not helped by the fact I was working in a space precisely 2/3rds as wide as I needed it to be to realistically get both hands in - and access from underneath is even worse because all of the brake lines are on top of the chassis or suspension. Realistically I should have just removed the driver's seat first...but that sounds like extra work! With the hose *finally* liberated I was able to confirm that it does look like we have a perfect match this time. Thankfully the retaining nuts survived the brute force required to remove them as I didn't have anything else in stock the correct size or thread. Fitting the new hose was a far quicker process! Doesn't this look better? The new hose looks a lot more twisted than the original in the photo mainly because the curve in the pipe is off to one side rather than upwards - that's the orientation it was naturally sitting in before any securing fixings were tightened up, so it's not under any undue strain. Hopefully get the other side done tomorrow, get the system bled and adjust up the handbrake which is blatantly obviously doing next to nothing on the nearside at the moment - which ties in with me having noticed a bit of extra free play in the brakes recently - the handbrake adjustment plays a big part in that as it basically sets the rest position of the shoes. Car is just coming up on 1000 miles travelled now, so makes sense to my mind to have expected to need to do this as the shoes will have bedded in properly and cleaned any crud off the surface in the drums by now. Will just be nice for long term peace of mind to know that these hoses have been changed. For all they looked crusty, I don't think the original ones were in imminent danger of failure (or I wouldn't have driven the car!), but it's nice to know I'm not relying on potentially 48 year old rubber hoses when I hit the brakes! *Especially* as this car has single circuit brakes - something I'd really like to look at upgrading in the future for obvious reasons. the flexible hose on the front brake was physically damaged when I got this car so was replaced with a NOS replacement. This part while also an off-the-shelf Girling item doesn't look to be shared with anything common enough to be readily available these days. For peace of mind I may well look to get one of these made up by Pirtek or similar outfits. Though the front hose at least is easy to inspect - unlike the rear ones which are essentially inaccessible unless you're going in through the service hatch in the rear of the cabin. Also on the long-term peace of mind list regarding the brakes: A few folks have raised concerns about the suitability of copper for rigid brake lines - in spite of it being sold for this purpose with all the prerequisite safety standard markings stamped on it in most motor factors. That message has been received and understood, and I do fully intend to replace all the copper rigid lines with cupronickel ones in due course. I want to fully investigate the possibility of the dual circuit setup first though as I'd rather not do the job twice. I've been as careful as possible to avoid bending the pipe at all beyond what's necessary to form it into the necessary shapes so as to avoid work hardening it, and have made sure it's secured in place as thoroughly as possible (and have actually just bought some more clips to improve on that a bit along the chassis rail for the front to rear main line). Thanks for the advice on that folks, it's not something I would have ever known about without the feedback. Of course once this work is finished it'll probably be a while before I can take a test drive to see if it's made any noticeable difference to the behaviour of the brakes (not expecting it) given the current situation.
Last Edit: Jan 23, 2021 21:23:15 GMT by Zelandeth
Jan 23, 2021 21:36:05 GMT
Copper brake pipe is ok as long as its secured properly at regular intervals. Any vibrational movement in it can induce stress hardening which can cause it to crack so keeping it secured properly is crucial.
Kunifer pipe is stronger so is far less prone the this. That said all pipes should be secured properly regardless of their metal properties.
Jan 23, 2021 21:55:43 GMT
Copper brake pipe is ok as long as its secured properly at regular intervals. Any vibrational movement in it can induce stress hardening which can cause it to crack so keeping it secured properly is crucial. Kunifer pipe is stronger so is far less prone the this. That said all pipes should be secured properly regardless of their metal properties. That's pretty much the message I took from the advice I was given. However with single circuit brakes I'm leaning towards doing anything I can to reduce the number of opportunities for Murphy's Law to get involved! Which has also reminded me I need to get a proper Girling master cylinder ordered in so I can implement a brake fluid level warning light. That's very much on my list of "essential instrumentation." If something happens and I'm losing fluid I want to know about it!
Jan 23, 2021 22:34:35 GMT
As said above copper is not as bad as some make out, all materials need supporting properly and if done so copper will outlast the vehicle, the 2 pipe failures I have had have been steel, one through corrosion (god knows how it had an MOT) and one through fatigue when the clips failed, I've had copper on cars for 25 years with no problems.
glenanderson
Jan 23, 2021 23:06:19 GMT
How long is the front hose? Land-Rovers are a cheap source of flexihoses, front brake ones are particularly useful.
How long is the front hose? Land-Rovers are a cheap source of flexihoses, front brake ones are particularly useful. It's a decent length. I'd need to actually measure it. Flare fitting at the top and banjo at the wheel end.
TessierAshpool
Club RR Member Number: 168
Copper brake pipe is ok as long as its secured properly at regular intervals. Any vibrational movement in it can induce stress hardening which can cause it to crack so keeping it secured properly is crucial. Kunifer pipe is stronger so is far less prone the this. That said all pipes should be secured properly regardless of their metal properties. That's pretty much the message I took from the advice I was given. However with single circuit brakes I'm leaning towards doing anything I can to reduce the number of opportunities for Murphy's Law to get involved! Which has also reminded me I need to get a proper Girling master cylinder ordered in so I can implement a brake fluid level warning light. That's very much on my list of "essential instrumentation." If something happens and I'm losing fluid I want to know about it! Re: level warning, would it be possible to retrofit a cap that has an integrated level sensor?
That's pretty much the message I took from the advice I was given. However with single circuit brakes I'm leaning towards doing anything I can to reduce the number of opportunities for Murphy's Law to get involved! Which has also reminded me I need to get a proper Girling master cylinder ordered in so I can implement a brake fluid level warning light. That's very much on my list of "essential instrumentation." If something happens and I'm losing fluid I want to know about it! Re: level warning, would it be possible to retrofit a cap that has an integrated level sensor? That's the plan. It's got an aftermarket one fitted just now because it's what was available cheaply when I was recommissioning the car and I wasn't 100% certain if it was the cylinder at fault at the time. Plus it had been an expensive few months. Once I've got a proper Girling master back in it will just be a matter of finding the correct reservoir cap including the level float. Already have a warning light with integrated lamp test in the seat pocket in the car.
How long is the front hose? Land-Rovers are a cheap source of flexihoses, front brake ones are particularly useful. Range Rover P38 front hoses are pretty long as well. Banjo on the caliper end. Here's one I measured earlier!
Last Edit: Jan 24, 2021 3:10:52 GMT by georgeb
Jan 24, 2021 20:30:34 GMT
How long is the front hose? Land-Rovers are a cheap source of flexihoses, front brake ones are particularly useful. Range Rover P38 front hoses are pretty long as well. Banjo on the caliper end. Here's one I measured earlier! That looks like it may well be ideal...will try to remember to measure what's in there tomorrow. -- -- -- Let's finish the job we started yesterday. It was still cold. Somewhere down the line once the garage is actually sorted out I'll have to think about getting some heating installed. Step 1...Do what I should have done yesterday and spend ten minutes taking the seat out. Today this is the corner we were doing battle with. The first retaining nut came off without too much bother. Was still a bit of a struggle, but nothing too dire. Of course the last one decided to be an absolute pain. Not helped by having to do everything 1/32 of a turn at a time and access precluding getting any serious leverage involved. If I hadn't managed to wedge that one spanner against the chassis rail I reckon I'd probably still be there. It felt like a LOT more than an hour and a half later when we finally had the old hose out. Getting the new one in was only made slightly more awkward by virtue of the fact that the flare on the line to the wheel cylinder wouldn't spin on the pipe so I had to screw the pipe onto the union rather than the other way around. By this point I could barely stand from my legs and back cramping so I called it a day. Jobs for tomorrow will be to bleed the brakes, adjust the handbrake, clip all the lines back into place and do a VERY thorough leak check. While I have the seat out there are a couple of minor jobs in that area I might attend to at the same time. Looks like I might have a very slight blow from one exhaust to inlet manifold gasket, or it could just be a bit of dirt...I'll look more closely tomorrow. I'd like to attach that fuel line to the chassis rail to keep it from sitting and rubbing against the top of the engine mounting cradle too. I'm thoroughly glad that these hoses are fitted now...Not a job I want to do again! Such a simple job made a million times more awkward because of the positions that you have to contort yourself into to get to anything.
