Sept 16, 2019 3:33:37 GMT
Normally I don't get to the gingerbread stuff until much later in a build. But I messed up my hand a bit last week, so I'm looking for some light fab work until the stiches come out... I have a couple of pics of Nuova Abarth's, and both of those cars had full size shields & badges ( not the much smaller trim used on the later 500 based Abarth's ) There is a repro version available, but from what I can see, it doesn't fit right. So I decided to modify an old shield I've had for a long time ( it was attached to a Fiat 600 with woodscrews, and I saved it by offering more than it was worth ) I don't think it is original Abarth ( the badge is, the shield is probably not ), but I've seen them on racers so they were used in the period . It was pretty beat up, and the mounting tabs on the back were messed up. But it is made out of aluminum, so I can do something with that.
Sept 16, 2019 3:37:24 GMT
This is the look I'm going for. Vs. this...
Sept 16, 2019 3:45:09 GMT
I took some of the dents out, and made a template to lengthen the top & upper sides. Transferred to aluminum. Welded in and hours of hammering and filing. ( very careful, its super soft aluminum, and it is very thin )
Sept 16, 2019 3:49:02 GMT
Trimming it to fit. New tabs on the back. And mounted on the car, with a Fiat Badge ( reproduction, but correct for the period )
Sept 16, 2019 3:54:17 GMT
Pretty happy with that. (pics to compare)
Sept 16, 2019 4:01:07 GMT
My old green car had an aluminum dash. The cluster was a very rare casting that somebody had brought over from Italy, but never used. I've seen clusters that looked similar, but those were made out of fiberglass. So as a nod to my green one, I bought the only one I could find in aluminum. Unfortunately, some of the holes for the gauges were not right for the gauges I have. So they had to be opened up.
Sept 16, 2019 6:21:44 GMT
Hope the hand is on the mend....they don’t grow back very well 😂 Stay safe 😊
Sept 16, 2019 6:22:01 GMT
Very cool project, glad you're sharing it here. I'd seen the frog-eyed 500 before, but I didn't know it was US spec. They're quite charming on the car. My Lancia Montecarlo has pop-up headlights, huge bumpers and other indignities that allowed it for import at the expense of aesthetics & performance... It's slowly going back to Euro spec.
After seeing what you gave to the Zagato, I've no doubt that you're the right guy for this car. I like seeing the big Dellorto carb hanging off an aftermarket manifold bolted to a 500 cc 2 cilynder motor, pure fun. Best wishes for your hand's recovery, you're going to need it : )
Sept 16, 2019 7:55:19 GMT
Hope the hand is on the mend....they don’t grow back very well 😂 Stay safe 😊 Thanks, man. Yeah, totally preventable and stupid. Fortunately not too much damage, very lucky...
Sept 16, 2019 8:02:40 GMT
Sept 16, 2019 8:39:31 GMT
The engine was in the yellow spaceframe 500 racecar. It is based on a latemodel Fiat 126 block, 650cc. It has some nice stuff in it. Polished aluminum rods, a better crank, big cam, 4 port Panda 30 head ( dual intake ports, like a dual port VW ), matching Alquati intake manifold, 40 Dellorto, etc. Sounds beautiful with a open pipe... My buddy who built it said it put out about 50Hp, but even if it is a couple of HP less than that its still 3 times the original HP... It came with a Alquati oilpan, but I'll replace that with a original 4litre Abarth oilpan. Cooling is the Achilles heel with these engines, and you can buy a specially modified oilpump housing that can reroute the oilflow through a cooler. But that is a expensive setup, and puts more strain on the pump that is on the small side already. So I have something else in mind, but I'm still gathering info on that... I'll make some modifications to the aircooling too, which should make it a little more efficient. I'll show all that when I get to it...
Sept 19, 2019 22:10:08 GMT
I love it! I guess this will really be the only Nuova America Abarth. Is the car a roll top, because it only seems to have a roof in one photo? Really liking the two tone paint and stepped chrome trim on that car in the black and white pictures.
Sept 19, 2019 23:14:13 GMT
Nuova America Abarth. Yeah, kinda... I'm building the one that never was. Mine came with the full length roof, but they got half way into the conversion to a short one before they realized the early cars ( like mine ) didn't come with the 2nd set of pivot points to make it work. They already cut up the roof frame, but fortunately those are being reproduced now.
My buddy who owns the Zagato sent me a vintage aftermarket steerinwheel. Its a really nice Fiat 600 steerinwheel ( but in black, so that may also be aftermarket ) with a horn button that includes a horn ring. With a couple of marble pattern plastic to dress it up. Very '50s era correct... The horn button didn't work ( maybe it never did, or maybe some parts got lost/mixed up), but after some time on the lathe and adapting parts off a stock 600 horn button, it does.
Last look. Before this happened. I had the rotisserie that the Zagato was in anyway, so it was only a very small amount of work to adapt it to the 500. And it makes it so much easier to deal with the floors.
Fortunately they started making the correct floors for a Nuova, some time ago. Before that the only option was to use 500F/500R floors which works, but doesn't look right. These are nice thick steel, pretty good fit. Well worth the extra cost.
Nice work there, keep going!
Missed this before.
Lovely.
jamesd1972
Club RR Member Number: 40
1958 Fiat 500 Nuova Americajamesd1972
@jamesd1972
Club Retro Rides Member 40
Loving the grill gives it a nice face, kinda with a moustache ! Nice home for all the bits and loving the ethos of can go back to normal and I suppose this also keeps the long term value as well. Heal well - those are skilled hands look after them ! James
Thanks guys...
