Club RR Member Number: 160
1947 ford ranger...Rich
@foxmcintyre
Club Retro Rides Member 160
Sept 18, 2021 15:47:18 GMT
Pad fitting is pretty in line with most cars now, stainless shims to prevent the pads rusting into the carrier and jamming, so instead the rust builds up under the shim, and jams the pad that way instead š Nice work as always dude. Shame about the glass!
1947 ford ranger...Dez
@dez
Club Retro Rides Member 34
Sept 19, 2021 11:34:09 GMT
Pad fitting is pretty in line with most cars now, stainless shims to prevent the pads rusting into the carrier and jamming, so instead the rust builds up under the shim, and jams the pad that way instead š Nice work as always dude. Shame about the glass! The obvious answer would be to not make the caliper carriers out of garden furniture grade cast iron I guess, but what manufacturer cares what theyāre like after 5 years these days? š¬
@dez
Sept 19, 2021 12:06:19 GMT
I made that bracket to terminate the brake/clutch lines on the firewall. Well I didnāt 100% make it, I reworked the old one. It started with this bit facing up that I chopped off. The bit thatās clamped in the vice is what Iāve added. The new mounting tabs I added as one piece, even though they needed to be separate. Itās easier to weld one bit on then cut the slot afterwards. Slot cut, mounting holes added, corners rounded. The notch is to allow the longer central line to pass down behind the bracket. This is why I reused half the old bracket rather than starting from scratch. Although the main bracket is straightforward, it has these anti-rotate plates welded to the bottom side so itās easy to do up the unions, which is the important part. Iāve painted it and thatāll get fitted when I take the front end off again, as itās another bit thatās Impossible to get to with the front end on. Seeing as I had the flaring kit out for doing the brake pipes, I decided to do the power steering hardlines too. These are harder as theyāre bigger diameter (8mm and 10mm) and I had to salvage, clean up and paint the fittings off the old steel pipes. With that done I used some steel wire (think old coat hanger type) to rough out the length and bends needed before cutting some line. 10mm kunifer is difficult to work compared to the 3/16ā (4.8mm) of brake pipe that can be bent by hand. The box end needed some pretty tight bends too. I use a fairly ancient Sykes pickavant flaring tool, mostly because out of all the ones i had itās the only one that covered all sizes, so I sold the others off. it gives good results too though. For the bending I use a super cheap eBay special bending tool like this. For the price they are I was sceptical at first, but Iāve not broken it yet and you only have to get one bend kink up before youāve wasted more in materials than you saved in not buying the tool, so everyone working hardlines should have one. I have the Sykes pickavant pliers type ones for doing sharp bends on brake lines too. This is the box end all in place. You can see the pipes arenāt quite parallel where they go under the rad, but thatās becuase theyāre not clipped down yet, and I canāt get both hands in there to do the final tweaks, so again thatāll be a front end off job. Iām prettt happy with how theyāve turned out though. They then cross the car on top of the front crossmember, under the rad. This is a tight space- You can see there where the smaller one meets up with the hose off the pump. Iāve kept the standard hose rather than modifying it in case it ever needs replacement. The return then kicks back inside the chassis rail and has a rubber hose up to the reservoir. Again this all needs clipping down and hose clips adding, but the fundamentals are in place with all major components fitted so I know of anything gets in the way or anything else, and itāll be finished off with the front end off. So thatās another bit loosely put it place, if not fully ticked off just yet. Another bit that was ticked off was reattaching the towbar hitch, as I got fed up of tripping over it. Some new m16 bolts (as I had to cut the old ones to get it apart) and now I can bash my shins on it instead š¬ It means I can now do all the wiring on the back end now though.
Last Edit: Sept 19, 2021 12:09:06 GMT by Dez
Sept 19, 2021 12:22:34 GMT
Beautiful brake work, and lovely way the plate has been re-engineered.
That tool is brilliant at the price, and being 3-in one even better.
As always I have nothing of value to add but admiration for the work you do.
Sept 19, 2021 17:51:14 GMT
Very neat lines indeed. That rear glass breakage would have pissedmeoffnoend
mk2cossie
Club RR Member Number: 77
1947 ford ranger...mk2cossie
@mk2cossie
Club Retro Rides Member 77
Sept 19, 2021 21:49:25 GMT
A man after my own heart with that brake and PAS fluid line work And I've never had any luck with 6 or 8mm pipe bending tools at work, shall have to splash out on one of those very expensive tools to try it out Lovely looking pipe work indeed Dez
@dez
Sept 20, 2021 18:02:44 GMT
A man after my own heart with that brake and PAS fluid line work And I've never had any luck with 6 or 8mm pipe bending tools at work, shall have to splash out on one of those very expensive tools to try it out Lovely looking pipe work indeed Dez Donāt come looking for a refund if youāre not happy, i canāt be dealing with that amount of outlay š If youāve ever used one of the big plumbing pipe benders for 15/22mm, theyāre just the same to use.
Sept 20, 2021 18:14:27 GMT
I did break mine last week bending 8mm kunifer, the alloy bar on the side snapped across one of the holes, works fine now with a piece of steel bar to replace it though.
misteralz
Sept 20, 2021 18:59:16 GMT
Funnily enough, that was what killed mine. Went back to vice handles, bike frames, and beer bottles for forming curves after that...
@dez
Sept 20, 2021 19:08:45 GMT
Well, this update is all a bit heavy and techy. After the fire I knew Iād lost a box of parts, some of which I knew I actually needed. But the issue was I wasnt entirely sure what was in that box, as Iād also lost all my notes and the labelling on the parts that corresponded to the labels on the remaining truck engine/running gear. Some of it was easy to diagnose, stuff like the brake master cyl, booster and pedal assembly was easy to recognise as missing and replace. What wasnāt was parts of the quite convoluted and complicated engine management and emissions system, especially as some of it had already been bypassed or removed by previous owners, so I didnāt know what was actually still there and couldnt remember what it looked like. This lead to trawling the net for diagrams to show the bits that should be there, and to compare them to what was remaining. This got WAY deeper than I envisaged, given I basically only had 3 unconnected vac pipes to account for! Which were this one on the turbo actuator- And these two off the back of the manifold, which ran up to two more steel pipes that then went all the way across the firewall and then stopped at the opposite side of the engine bay. Figuring out what these were for was going to be key. These engines use the vacuum system for a number of operations, with a mixture of sensors and solenoids talking back and forth to the ECU. the 3 major systems are- *EGR system with ISV- Inlet Shutter Valve. *swirl flaps in the inlet manifold, which Mazda call VSC- Variable Swirl Control *the turbo, which is apparently āvariable geometryā and with VBC- Variable Boost Control All this lot interconnects by one hell of a crazy āmanifoldā made out of a lot of bits of steel pipe of varying size soldered together- I ascertained that 3 out of 4 of the solenoids attached to the motor (two under the inlet and one on top of it) control the EGR and inlet shutter valves (basically a back feed from the EGR That closes a throttle butterfly). The remaining one is for the swirl flaps. This picture was key. It turns out I was missing two more solenoids, confirmed by finding two plugs for them on the loom. Not only that, but I was also missing a large vacuum reservoir too. (No.s 3-5) Above it is shown as part of the turbo control system, but here it is shown again as part of the EGR system too. Meaning the EGR also uses the vac reservoir. Further reading confirmed that. So, that determines what all my unconnected pipes are actually for, which is good. What aināt good is I have an incomplete EGR system as the EGR cooler has been bypassed, presumably because itās rubbish and leaks like they all do. What Iām currently unsure on is how easy (or not) it is to totally bin it, including the shutter valve system. Some are ok with that being removed, some are not. Further investigation and reading is needed. Although the fact that Ford made a factory branded EGR blank that you can order is promisingā¦.
Last Edit: Sept 20, 2021 19:38:51 GMT by Dez
75swb
Beta Tester
Club RR Member Number: 181
1947 ford ranger...75swb
@75swb
Club Retro Rides Member 181
Sept 21, 2021 7:54:24 GMT
Do I recall a blanked egr being an mot fail nowadays? Or so long as the check engine light is mapped out and the blank done neatly is it unlikely to be noticed?
@dez
Sept 21, 2021 19:03:04 GMT
Do I recall a blanked egr being an mot fail nowadays? Or so long as the check engine light is mapped out and the blank done neatly is it unlikely to be noticed? Iām not sure tbh, I donāt really play with stuff new enough to be effected by such legislation that often. Ford obviously donāt really give that much of a damn if you blank em though, given they sell these- If thatās not an admission your EGR system is cr4p and is gunna fail I donāt know what is!
@foxmcintyre
Sept 21, 2021 19:34:52 GMT
Just make it look like it was never there, and it's fiiiiine.
Last Edit: Sept 21, 2021 19:35:54 GMT by Rich
@dez
Sept 21, 2021 21:42:11 GMT
I did break mine last week bending 8mm kunifer, the alloy bar on the side snapped across one of the holes, works fine now with a piece of steel bar to replace it though. Funnily enough, that was what killed mine. Went back to vice handles, bike frames, and beer bottles for forming curves after that... Iāll keep an eye on it, like I say at the price I wasnt expecting much but itās done all the fuel/PAS/trans cooler lines on 3 cars now, which is quite a lot of bends, all 8mm and 10mm kunifer. Stupidly itās one of those tools I donāt think you can actually buy a āgoodā version of.
@dez
Sept 21, 2021 21:58:46 GMT
Just make it look like it was never there, and it's fiiiiine. I knew youād know š¤£ Tbh that factory Ford plate gives an air of credibility over a bit of random steel plate. I still think itās funny as f-k they sell em. It has a cat thatās still there at the moment (but a pukka decat downpipe that looks factory is like Ā£40) and doesnāt have a DPF. Tbh all I ever see is bolloxed, coked up EGRs, I really doubt if they actually have any environmental benefit at all. All it does is remove a marginal amount of pollution from the tailpipe, store it up then put it all over my workshop floor in big claggy lumps š If I do remove the system as itās compromised. Iāll get it mapped to make maximum advantage so itāll Probably run cleaner anyways.
Last Edit: Sept 21, 2021 22:00:34 GMT by Dez
Sept 21, 2021 22:16:14 GMT
It is so worth the time and trouble to nicely form pipes. Makes the job right. Nothing worse than random wrinkly pipes. I too have one of those strange bender things. We are not exactly friends but we rub along. Not dared try anything more challenging than 8mm kunifer though.
On diesels, all the EGR does is knock down the NOx output. It does this by lowering combustion temperatures by partially choking the engine on its own waste products.... An efficiency spoiler if you like.
My old A6 used to smoke like a wet bonfire whenever you booted it hard after period of pottering. Think finally blasting past a tractor after following it for 5 miles..... it was embarrassing, nothing in the mirror but a great swirling fog bank - with following traffic bursting out of it, coughing and blinking in the sunlight..... And it used to take all 6 attempts to pass the MoT smoke test. This was normal. They all did it.
Then I made a little copper gasket... without a hole in it. And the problem went away. Of course, because the thing had already done 180k, I had to dig about a kilo of compacted soot out of the intake manifold and ports to get the full effect. No more embarrassing fog banks, MoT pass, first pass, every time, all 140 horses back at full strength and another 3 - 4 mpg, for the next 155k so far.
Nick
Last Edit: Sept 21, 2021 22:20:29 GMT by vitesseefi
@dez
Sept 22, 2021 19:23:39 GMT
vitesseefi The ākilo of soot out of the inletā sounds familiar. Basically what I had to do with this to get it clean enough to weld when shortened. Iāve always regarded EGR setups on diesels as nonsensical. They work quite well on petrol engines, but a diesel is a much different animal, and show me a diesel that doesnāt sludge up its EGR system. They ALL do it, especially when the PCV fumes meet the EGR fumes and it all turns into a sooty, sludgy mess.
@dez
Sept 22, 2021 19:30:50 GMT
Well, I now have one of these. This accounts for the remaining unaccounted for plugs on the loom and the errant vac lines, so Iām now happy Iāve got the system as complete as I can (or as complete as it was when i got the truck) so I have something to work backward from. Just got to find somewhere for it to live and make/adapt a bracket for it now. The remaining space in the engine bay is filling up rather quick!
@dez
Sept 24, 2021 18:02:48 GMT
In my ongoing quest to fit 2 pints of curse word into a pint pot, Iāve now got to sort out a battery tray. Itās going to go in the gap between the back of the head and the firewall, over the top of the gearbox. The first set do brackets I made didnāt work as they mounted it too high, so I flipped them upside down and hammered out one of the folds, then fitted them to the sides of the battery tray instead. This worked in one respect, but failed in another. It dropped the battery down which was what I wanted, but it made the tray a fraction wider so it didnāt fit in the recess. At this point I was still trying to reuse the original ā47 tray I had saved. So I had a look online at some battery dimensions, and decided I could make it 3/40 narrower and still get an adequate battery. Rather than narrow the existing one, I just made a new one. Itās just some 1.6 sheet, but made appropriately fanceh by the medium of holesaws and dimple dies. Battery fits (well one the same dimensions, the new one will be only a fraction taller and wider but much higher CCA, but this one is sufficient for mock-up). I then welded it rocketed, and Hereās the first half decent pic of where it will sit. It was then levelled and squared, and tek screwed into place Itās tight on the other side š Itāll have spreader plates on this side, and bolt all the way through. Once Iāve made em anyway. Itās actually really unobtrusive once fitted, and quite a sensible location in terms of wiring. Thereās also still room under/around it to mount things to to hide em away. So itās worked out quite well. Just got to lengthen the cables a bit (only about 6ā or so) to connect it up.
1947 ford ranger...stealthstylz
@stealthstylz
Club Retro Rides Member 174
Sept 24, 2021 18:13:50 GMT
Don't you be slagging EGR systems off they partially keep me in a job. I think they should do more EGR, almost closed loop but with a little dump valve.
