Jun 13, 2020 13:37:41 GMT
Permission to ask a really basic question...what glue should I be using to re-glue my bits of dashboard back together as I carry out my RHD conversion?
I have tried Humbrol Poly Cement, Loctite Super glue and even UHU. None have allowed the parts to bond back together 🤔 Any suggestions would be very welcome.
Club RR Member Number: 160
Jun 13, 2020 19:57:21 GMT
Permission to ask a really basic question...what glue should I be using to re-glue my bits of dashboard back together as I carry out my RHD conversion? I have tried Humbrol Poly Cement, Loctite Super glue and even UHU. None have allowed the parts to bond back together 🤔 Any suggestions would be very welcome. Some of the WPL parts are a weird plastic that doesn’t like gluing. I tend to plastic weld my parts like this with a hot knife. You can do it with any blunt-ish soldering iron though. Just don’t be tempted to use a cable tie as filler rod, use some sprue or offcut if you need filler rod.
Jun 14, 2020 17:48:55 GMT
Made a quick montage video to bring us up to speed on the wrecker, clip of it running as a chassis cab is in the middle of the video if you wanted to just watch that. Few new pics right at the end.
Jun 14, 2020 18:39:50 GMT
Great stuff Rich - just the kind of inspiration I need right now! 😎
drseg
Jun 15, 2020 17:48:17 GMT
yayyy my complimentary screws arrived there wernt enough no.6 shanked screws for rear suspension pivots. I have the metal upgrades but think I will build as standard just so I can see the difference as I plan to get a few more 16th scale vehicles, looking on ebay theres also a jeep 12th sscale I think that could be modified to look like my car see avatar pic to thee left.
Jun 15, 2020 19:51:59 GMT
yayyy my complimentary screws arrived there wernt enough no.6 shanked screws for rear suspension pivots. I have the metal upgrades but think I will build as standard just so I can see the difference as I plan to get a few more 16th scale vehicles, looking on ebay theres also a jeep 12th sscale I think that could be modified to look like my car see avatar pic to thee left. JJRC Q65 could indeed be built up like yours, would be a fun build too!
drseg
Jun 15, 2020 20:09:16 GMT
weird,sorting screws theres 2 kinds of screw number3 one has thread half way up one just a quarter of the way confused me as now got 7 types of screw... doesn't take a lot
Last Edit: Jun 15, 2020 20:10:36 GMT by drseg
drseg
Jun 15, 2020 20:26:04 GMT
jjrc q65 is 1/10 scale not 12
Jun 15, 2020 20:54:14 GMT
jjrc q65 is 1/10 scale not 12 Probably isn’t 1/10 looking at photos I’ve seen of them, that rubber ruler again. Got a link to the one you are looking at?
drseg
Jun 15, 2020 21:04:25 GMT
loads and loads on ebay all seem same in desert, green or blue with or without "tent"
Jun 15, 2020 21:36:41 GMT
loads and loads on ebay all seem same in desert, green or blue with or without "tent" This one? www.ebay.co.uk/itm/323627257478Can’t see any others on a quick search. Must admit that ones a bit different.
drseg
Jun 15, 2020 21:54:48 GMT
Jun 15, 2020 22:00:13 GMT
That’s the one I said about, it’s not properly 1/10, it’s like you say about 1/12. Uses the same running gear as the RTR WPL stuff so easy to swap wheels etc to get the right look
drseg
Jun 15, 2020 22:05:34 GMT
theres landrovers too once 6 x 6 built may get a bit spendy!
markbognor
Club RR Member Number: 56
theres landrovers too once 6 x 6 built may get a bit spendy! My C34's aren't even here yet and I'm already planning an MN Land Rover!
markbognor
Jun 18, 2020 14:21:03 GMT
Still no trucks, but my B1 tyres and half my shiney wheels have come. I will probably going with four of these, the dually rear wheel set up but with the inner wheel machined off. This will give me a wider, and less massively negatively offset wheel. I also have a set of MN90 wheels and tyres comming that have much rounder shoulders. I'm hoping that the outer wheel diameter is close to the WPL, so that I can cut off the larger diameter rear bead seat and glue it to the back of a metal wheel. I'll have to see when they get here.
markbognor
Jun 19, 2020 14:07:33 GMT
Jun 22, 2020 13:06:22 GMT
Hi folks, I have had all my upgrade bits arrive this morning so am hoping to make some progress with my C44 KM build. As you may remember, the front axle supplied with the kit was warped and wouldn't allow the internals to run freely despite various adjustments. I therefore decided to buy upgrade axles from Bangood '2PCS-Titanium-Color-Metal-Front-Rear-Bridge-Axle-Set-For-WPL-HengLong-1-16-Military-Truck-RC-Car' which run beautifully and are even ready greased. As happy as a happy person could be, I attempted to mount them to my WPL upgraded metal 'Traction Link Base' (the black carrier with the 'E' shape bit in the middle). Things have not gone well! Basically the holes do not line up properly and are 0.5-1mm out. Do I: 1. Just file the holes out a bit? 2. Cut the Link Base and then Araldite (or similar) a metal bridge to it to make it wider (will still require the bottom holes to be enlarged) 3. Have a little cry and put the new axles and possible the rest of it in the bin? In other news the body work is looking ok with the painted trayback section. Here it is minus axles sporting the 'slammed look' having been hit with a 1:12 scale lowering stick.
moglite
Club RR Member Number: 144
Jun 22, 2020 13:27:51 GMT
There looks like a reasonable amount of "meat" on those axle mounts - get out your needle files is my vote
1967 Morris Oxford Traveller 1979 Toyota LandCruiser BJ40 1993 Daimler Double Six 2007 Volvo XC70 2.4D
Jun 22, 2020 16:13:24 GMT
There looks like a reasonable amount of "meat" on those axle mounts - get out your needle files is my core Yup - the needle files did the trick 👍 it is now on its wheels!
